Overclock when coil whine? - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 02-25-2019, 08:29 AM - Thread Starter
madmax911's Avatar
Rep: 3 (Unique: 3)
As my topic says i am wondering if its safe to OC my inno3D GTX 1080 TI though it has coil whine. The coil whine is only noticable at very high FPS in games.
At the moment the only OC i made was putting power limit to max, 116 in my case. And then 50MHZ oc on the core. Giving me 2050MHZ on core and 5700 on RAM when i run Furmark.
Also games crashes at a mere oc of 100MHz on the core and nothing on RAM.
Im skeptical but should i unlock Vcore and mess with that.
Kinda dissapointing sitting with an expensive custom water block and the temp hits 50c max but I cant OC much
Air is for breathing, water is for cooling.
madmax911 is offline
post #2 of 2 (permalink) Old 02-28-2019, 10:09 AM
Plurant's Avatar
Rep: 0
it is safe, most gpu's have coil whine at high fps or when you draw lots of current ( my 980ti was doing this while drawing 400w)
Try to set vcore to max and see from there what stable oc you get.
Über PC
(22 items)
Intel i9 9900K
Msi z390 Meg Ace
Gigabyte 980ti GV-N98TXTREME
Corsair 16Gb LPX DDR4 2400Mhz CL14
Sandisk Extreme Pro nvme 1Tb
Samsung 850 evo 500Gb
Corsair RM 750x
EKWB Velocity CPU Block | Acetal Nickel Plated RGB
EK-Coolstream SE 240MM
EK-Coolstream PE 360MM
EKWB D5 Pump reservoir PWM RGB
EKWB Full cover GPU Block | Acetal Nickel Plated
Soft tubing 12-16 ACF Fittings.
Corsair WWML120 X3 White LED
Corsair SP120 X2
Corsair 570x White
Operating System
Windows 10 | Arch linux
Keyboard
Razer blackwidow chroma
Mouse
Steelseries sensei wireless
Mousepad
Steelseries QcK limited
Audio
Steelseries Arctis 7
Plurant is offline
