needs help to 'fix' my 980 ti - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 02-28-2019, 10:55 PM - Thread Starter
Rep: 0
hello everyone, recently i got a 980 ti (reference version), it works fine, but when under high work load, the inductor start buzzing.
and after tear down the backplate, i found that some capacitors(MLCC) was lost (marked in picture), and has someone can tell me why my card can work without this capacitors?
and is the lost capacitors make my inductor buzzing? and finally, what type of capacitors i should buy to fix my card?
I would be grateful for any suggestion!
csomnia is offline
post #2 of 5 (permalink) Old 03-01-2019, 02:43 PM
Rep: 0
Please post a picture of your card where the caps are "missing"?
A card won't run at all if anything is missing from it and most likely what you are describing is a model difference between yours and whatever picture you're referring to.
Neural0 is offline
post #3 of 5 (permalink) Old 03-03-2019, 06:30 AM - Thread Starter
Rep: 0
thanks for your reply, here is the picture. and this card was repaired before, you can see some solder's mark around capacitors.
csomnia is offline
post #4 of 5 (permalink) Old 03-08-2019, 08:24 AM - Thread Starter
Rep: 0
anyone can give suggestion?
csomnia is offline
post #5 of 5 (permalink) Old 03-08-2019, 08:40 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1170 (Unique: 664)
if it works, it's likely fine. no way any of us can tell you if the missing components caused the "buzzing." if it was fine before they came off, probably.
buy the same SMDs and solder them on if you want to replace them.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
