2080Ti lightning "Dead" after XOC bios Flash. - Page 18 - Overclock.net - An Overclocking Community
post #171 of 225 (permalink) Old 05-29-2019, 04:42 AM - Thread Starter
Slovak_Killer
Rep: 14 (Unique: 11)
Quote: Originally Posted by ALSTER868 View Post
Can you please tell more about this bios and what more difference is there from regular LN2 bios? PL? Is ity suitable for air?
Its regular LN2 bios, i just found out it probably doesnt have fans bug. Also in the future if someone leaks Afterburner extreme for 2080Ti lightning it will work only with this bios.(if i dont count NDA one)
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
MSI RTX 2080Ti Lightning Z
G-skill 3200 c14 Trident Z
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
ASUS ROG Crosshair VIII Impact
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
post #172 of 225 (permalink) Old 06-08-2019, 09:14 AM
Glerox's Avatar
Rep: 6 (Unique: 6)
Hey Dangersk,
are you sure your bios doesn't have the fan bug?
I tried it and my system completely freezes, like it did for all bioses with the fan bug.
I'm back on the LN2 bios MSI gave me now.
Glerox is offline
post #173 of 225 (permalink) Old 06-10-2019, 01:39 AM - Thread Starter
Slovak_Killer
Quote: Originally Posted by Glerox View Post
Hey Dangersk,
Thats what i wanted to know thx for feedback, the thing is i dont have any issues regarding Fan bug, i was curious if it was because of this bios or mods ive done to card
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
post #174 of 225 (permalink) Old 06-14-2019, 09:24 PM
Rep: 0
This thread saved me! Thank you all.
I put my Asus dual OC 2080 Ti on water about a month ago and sure enough about 2 weeks in it started doing the 1350/0.7V/50% power thing. I went in and tried to flash several different BIOS onto the card... but none of it helped the behavior...
so I...
-Put the "no-fan" bios onto it (from LN2Retail125Slovak.rar)... Thanks dangerSK... mine says that version is 90.02.17.40.9D... but your link says it's 90.02.17.40.89... is that weird?
<didn't solve it... but it was wishful thinking that it would once it was already in safe mode maybe>
-Took it back out of it's water block and connected it to it's stock cooler (and fans)... re-installed into PC on air and now it's working great.
So... Now of course I want to take it back off of air and plumb it back into the loop... With the one worry being that I will have to do this again in a couple weeks if the bios I put in doesn't fix the safe mode issue.
Has anyone put their cards back on water and had the issue re-appear with the no-fan bios?
Again... This forum saved me an RMA... Thank you all for that alone. Very much appreciated.
-jbow7
jbow7 is offline
post #175 of 225 (permalink) Old 06-16-2019, 06:33 PM - Thread Starter
Slovak_Killer
so I...
-jbow7
Hi, Im glad I helped help someone and saved money/time for you, the thing is there are certain "actions" that trigger NO FAN BUG (Reinstalling drivers, an unplugging system for a longer period of time, changing/flashing bios etc) so u can try to avoid these and u will see for yourself... Just to be sure u can try to plug some DIY fan plug or something.
That bios isnt 100% fixing the issue, but what u know, maybe it will work for you. If something u can ask here for advice from me or others.
btw once the card is stuck in safe mode only thing that can revert it is plugging back fans.
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
post #176 of 225 (permalink) Old 07-11-2019, 05:31 PM
Rep: 0
There it goes again...
Well i had about 2 weeks again... Card is back in safe mode. I have avoided any of the new driver updates or doing any flashing... I suspect there is something that runs a check every so often and kicks on the safe mode after a scheduled check.
Well... I am thinking for long term sustainability of having the card on water I will have to set up some sort of fan plug to trick the card. I will do some research... I have seen the actual plug attachments available (14 pin i think, will have to double check)... but will need to do some research on what the fan characteristics "should be" to pass the monitors. I am hoping it would just be a couple of resistors or something. Maybe even just a continuity check.
I will say that I am AMAZED that this isn't a bigger issue with the water cooled community in general. With the amount of water blocks available for the RTX cards... I would think that thousands of people would be seeing this. But maybe it's a specific vendor card issue or something...
jbow7 is offline
post #177 of 225 (permalink) Old 07-18-2019, 08:16 PM - Thread Starter
Slovak_Killer
hi, sorry for late response. Yeah its pain in the ass, im working on a workaround for this "bug", it will probably require soldering (more like unsoldering ) We know that its pretty random... well nothing new for now, MSI isnt rly making progress.
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
post #178 of 225 (permalink) Old 07-23-2019, 06:38 AM
Rep: 0
No worries. I have been doing a bunch of forensics on the fans, the connector, and fan emulators. I think I have a path that should work... Essentially pin a wire harness into the card connector, create a little wire harness, and have it terminate with a couple of fan emulators. Relatively small, cheap, and hopefully would be a long term fix... I plan on working through it this weekend. Will let you know how it plays through.
jbow7 is offline
post #179 of 225 (permalink) Old 08-01-2019, 05:04 AM - Thread Starter
Slovak_Killer
I found another problem, even with shunt mod my Lightning is still PWR perfcaping, its reading like 60% PL but still throttles. I had to flash my 1000W bios to stop this.
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
post #180 of 225 (permalink) Old 08-02-2019, 05:59 AM - Thread Starter
Slovak_Killer
So its 99% confirmed Lightning checks PL through current and calculates power draw from vcore*current = pwr
this means shunt is nothing and u need bios
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
