2080Ti lightning "Dead" after XOC bios Flash. - Page 5 - Overclock.net - An Overclocking Community
post #41 of 116 (permalink) Old 03-08-2019, 10:48 AM
Overclocker in training
ThrashZone's Avatar
Rep: 41 (Unique: 33)
Hi,
Some msi 2080ti sea hawks have shown up locally at micro center so this is interesting
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #42 of 116 (permalink) Old 03-08-2019, 10:57 AM - Thread Starter
Slovak_Killer
dangerSK's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by ThrashZone View Post
Hi,
i dont really understand what are you talkin about.. if u want good XOC card wait for Kingpin or buy used OC Lab.
LN2 Beast
(6 items)
i9 9980XE
Evga X299 Dark
MSI RTX 2080Ti Lightning Z
G-skill 3200 c14 Trident Z
Kingpin F1 Dark
EKWB Loop
dangerSK is offline
post #43 of 116 (permalink) Old 03-08-2019, 10:58 AM
Invalid Media
J7SC's Avatar
Rep: 2 (Unique: 2)
Quote: Originally Posted by dangerSK View Post
Dont think so. The card was all time in idle, probably something went wrong on SMBs side.
First, kudos for informing others re. the potential XOC Bios issue. I've done cross-flashing before as well, i.e. Asus Strix XOC Bios onto a 900 series EVGA KPE - surprisingly it worked, kind of > During boot, I had to kick up the voltage via EVBot first, otherwise continuous black-screens. As already mentioned before in another thread, I think you might be running either into a 2x 8 pin XOC Bios flashed onto a 2x 8 pin PLUS 1x 6 pin...or, and this has been mentioned as well during several other cases with the '1350' issue on RTX, there my be some weak Eprom chips out there.
As to RMAing, I share my one and only (and very recent) experience with MSI, which was actually quite pleasant. As context, in the build in the spoiler below, there is a lot of 'stuff' and I had to do a lot of 'squeezing', not least as I was using an e-ATX board (MSI X399 Creation) on a Core P5 which is 'tight' re. cable-throughput. In any case, there was a lot of tension on the 24v cable so I decided to get out the Dremel tool and proceeded to unscrew the mobo stand-offs nuts, but w/o removing the 24v cable tree under tension first...
...oopsie > the tension pulled the mobo off the stand-offs by itself and shaved off a cap or two next to the top center screw hole...board would still complete half a boot cycle but then reboot by itself, and Bios screen could only be accessed every 3rd or 4th time. So I took it out to bring back to the local retailer but during prep got klutzy - now, I had forgotten to disconnect the USB 3, and the top black part of the USB receptacle broke off
The dealer then showed me what had happened to the caps at the top - and I figured as long as I could find out which caps were there before, I could get some new ones and solder them on as this was at an accessible and easy to understand location on a very expensive mobo. The USB 3 port didn't much bother me as there are two anyhow, and even the first one still worked, just looked bad. When I called MSI, I told them exactly what had happened and that it was my fault. Surprisingly, MSI gave me an RMA# and when the mobo got back, I was only charged (a bit over $US 40) for the fix for the USB 3 receptacle, the secondary issue.
Finally. as the '1350 MHz' problem is not a unique phenomenon, I think MSI might help w/o asking too many questions. In any case, good luck getting it sorted !
Spoiler!
J7SC is offline
post #44 of 116 (permalink) Old 03-08-2019, 10:59 AM
ThrashZone's Avatar
Hi,
I'm saying I had my eye on the sea hawk and your thread cross flashing has sort of closed that eye on the msi card
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Operating System
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #45 of 116 (permalink) Old 03-08-2019, 11:08 AM - Thread Starter
Slovak_Killer
dangerSK's Avatar
Rep: 3 (Unique: 3)
Spoiler!
Sure if i can prevent even one gpu death its worth it. Also thanks for sharing your story i hope MSI wont ask too much questions. I know about 1350mhz issue on other cards seems common however its just a sign something is wrong, if your card doesnt boosts and stays at 1350mhz it means its in safe mode because something failed to pass "health" check. Kinda similiar as when you get check engine in your car.
LN2 Beast
(6 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
dangerSK is offline
post #46 of 116 (permalink) Old 03-08-2019, 11:47 AM
Invalid Media
J7SC's Avatar
Rep: 2 (Unique: 2)
The 1350 MHz safe mode issue (even w/ potentially different causes) is common enough across RTX that I suspect that vendors have an internal tech bulletin on it for their RMA staff, and that would make your claim a bit easier.
BTW, what are you going to do if they send you a replacement for your Lightning-Z and then the 2080 Ti KPE is (finally !) out to be purchased, EVBot-ready and other Bios goodies et al included ?
J7SC is offline
post #47 of 116 (permalink) Old 03-08-2019, 11:58 AM - Thread Starter
Slovak_Killer
dangerSK's Avatar
Rep: 3 (Unique: 3)
i will sell it In our local store theres option that you can request money instead of replacement, well i dont rly care i will be happy if i can get anything
LN2 Beast
(6 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
dangerSK is offline
post #48 of 116 (permalink) Old 03-08-2019, 12:01 PM
ComansoRowlett's Avatar
Rep: 0
I know there was an issue on 2080ti's with mounting pressure, it can cause the 1350MHz bug (info from buildzoid with my exact card). Not entirely sure what caused it but might be because it's too tight, but he also said it happened randomly when using the Morpheus ll on it so... Figure it might be worth a shot to remount it with some new TIM. Good luck!
Ryzen 2700X
Asus X470 Crosshair VII Hero
2080Ti FE (Buildzoid edition)
G.skill Trident Z 4600MHz CL19
Leadex Superflower 1000W platinum
Corsair H150i Pro
Phanteks Enthoo Evolv
ASUS PG278QR
ASUS MG28U
Keyboard
Corsair K70
Mouse
Corsair Schimitar
Other
Samsung 970 pro 1TB
ComansoRowlett is offline
post #49 of 116 (permalink) Old 03-08-2019, 12:09 PM - Thread Starter
Slovak_Killer
dangerSK's Avatar
Rep: 3 (Unique: 3)
hmm i can try, i have waterblock on lightning and he is screwed very tightly, but i dont think its related because this bug happened after bios flash and i didnt move around the card.
LN2 Beast
(6 items)
i9 9980XE
Evga X299 Dark
Kingpin F1 Dark
EKWB Loop
dangerSK is offline
post #50 of 116 (permalink) Old 03-08-2019, 11:38 PM
nycgtr's Avatar
Rep: 91 (Unique: 67)
Hi,
I can't recommend this tbh. I have 2 one is out for RMA as it artifacts the moment load is applied. Bad draw but the block performance is very meh. I've had like 3 different manufacture RTX blocks at this point but in total like 6 rtx 2080ti assorted blocks. I also have a trio with a non ek block. Yet to test it but yeah I wasn't too fond of the strix bp block performance and this ek one for the trio is worse.
nycgtr is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
