2080ti SLI Question - Best Mobo / Will my 1440p monitor bottleneck ? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 05-19-2019, 12:01 PM - Thread Starter
SixStones's Avatar
Rep: 1 (Unique: 1)
Hi guys. Before I pull the trigger on another expensive purchase, I just wanna be sure first and not end up regretting so I could use some advice.
Currently my build consist of a 9900k 5ghz watercooled / 64GB of 3200mhz RAM, z390 Matx mobo and a 850w PSU
I have a Aorus 2080ti waterforce currently and I’m intending to get the air cooled Aorus 2080ti XTREME. According to techpowerup both cards are the same size in terms of width and length so the nvlink slot shouldn’t be an issue.
Obviously I will have to change my mobo and PSU
I am contemplating between the Aorus Z390 Ultra vs Asus Z390 Pro. I’m also open to any option because I want my GPU to run at 16x/8x
Secondly will my 1440p monitor bottleneck the card ?
I know that scaling is not that great on some game but I’m pretty much contented even if I get decent scaling / improvements in FPS.
My main motive is to get that extra FPS in games since my monitor is 165hz and most games I run now at max settings are between 120-140fps and since I got some spare cash Lying around from selling plenty of old hardware I thought why not.
But now my main concern is which z390 motherboard is the best to get max performance and also will it be fine to run at 1440p? I’m not into 4K
SixStones is offline
post #2 of 8 (permalink) Old 05-19-2019, 12:01 PM - Thread Starter
SixStones's Avatar
Rep: 1 (Unique: 1)
Ps : I hope you guy can give me some advice as i will be heading to the store in the morning 🙂 thanks in advance!
post #3 of 8 (permalink) Old 05-24-2019, 04:24 PM
GosuPl's Avatar
Rep: 6 (Unique: 5)
1. 9900K and Z390 platorm is not best choice for SLI. Lack of PCI-E lanes.
2.850W PSU is to weak for your setup with 2x 2080Ti.
3.1440p will be bottleneck.
CPU - i9 [email protected] GHz + 3.1 mesh
Mobo- ASUS RAMPAGE Extreme VI
GPU - 2x RTX 2080Ti FE (Samsung GDDR6)@2085/15400 + PG348Q 100 Hz / 3440x1440p / G-Sync
MEM - 32 GB G.Skill Trident Z @3800 Cl 16.16.16 T
AUDIO - ASUS Xonar Phoebus Solo + Sennheiser HD 380 PRO
PSU - Corsair AX 1500i
Case - Phanteks Enthoo Elite
GosuPl is offline
post #4 of 8 (permalink) Old 05-24-2019, 04:40 PM
Monstieur's Avatar
Rep: 0
Sell it and buy a Titan RTX, or wait for the upcoming Super announcement. I had GTX 1080 SLI and it was a total waste of money. Your platform doesn't have enough lanes as a single RTX 2080 Ti is impacted by 4% at x8. 4% is a lot considering SLI scaling is already low.
Monstieur is offline
post #5 of 8 (permalink) Old 05-24-2019, 04:44 PM
The last VRM burner
Rep: 13 (Unique: 10)
I'm fresh after testing RTX2080Ti on my rig - it's more than 4%
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Sapphire Radeon RX580 8GB Nitro+
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Samsung 850 Pro
Toshiba HDWD10 (P300)
Corsair CS650M
Raijintek Tisis + Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
SteelSeries QCk Mini
Audio
Audio in Motion SC808
Audio
AKG K240 Studio 1st rev
Other
NZXT Hue+
Other
Mayflash F300
BroadPwns is online now
post #6 of 8 (permalink) Old 05-24-2019, 05:28 PM
bp7178's Avatar
Rep: 3 (Unique: 3)
Over the last few years I ran 1080, 1080 Ti and 2080 Ti cards in SLI. The 2080 Ti cards were on a X299 platform with a 7960x that was clocked pretty high so the PCIe lane limitation wasn't an issue, but I think the 4% figure may be a bit high depending on your particular use case.
With the 1080 on a ultrawide monitor with ultra settings in my game of choice, the second card kept me locked at 60 FPS in every instance at 3440x1440. When I upgraded to a 3440x1440 100hz panel, they weren't as good. Then came the 1080 Ti cards. They worked well. I anticipated getting a higher refresh ultrawide, so I knew I'd have issues with the 1080 Ti cards, keeping in mind SLI scaling isn't the best and is VERY dependent on your use case. I jumped on the 2080 Ti bandwagon, which in hindsight, I shouldn't have done. I'd rather have just gotten a Titan RTX if I was going to spend that amount of money, which is almost wasteful, IMO. I've gotten away from the ultrawide monitor in favor of two 1080p 240hz 24" (Asus XG248Q) which have been surprisingly good. 95% of the time with the ultrawide I'd be playing a game in a 1080p window, and watching something on YouTube on the other side of the monitor, so for my situation, two monitors really makes more sense.
All that being said...120hz is the sweetspot. 100hz is better than 60hz, but if you can hit 120hz you'll find the action nice and smooth. 144hz isn't as big of a diff as 100 to 120, just like 1440 to 240hz isn't all that much.
Poor scaling wasn't that big of a deal when the cards were $750, but at $1,300+, its a dumb place to spend money.
With a single 2080 Ti and the ultra preset in The Division 1, TD2 blows goats but that's another thread, I average in the high 100 to low 200s, which is more than enough.
bp7178 is offline
post #7 of 8 (permalink) Old 05-25-2019, 06:32 AM
GosuPl's Avatar
Rep: 6 (Unique: 5)
TITAN RTX @2085/15000 is 2-5% faster than RTX [email protected]/15000 in gaming. Not worth at all. I have both GPU's and for gaming TITAN RTX is worst TITAN ever compared to Ti.
GosuPl is offline
post #8 of 8 (permalink) Old 05-25-2019, 06:55 AM
Senior OCN Member
shilka's Avatar
Rep: 2727 (Unique: 1621)
SLI is a waste of time and money and the support is all over the map and in many cases is actually slower than a single card
So you are better off just sticker to a single card and if its not fast enough buy a Titan as said
What brand and model is your PSU naming the amount of wattge is not saying much
Seravee
(29 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 8 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
shilka is online now
