Cooling RTX 2080 in a CRAMPED Case - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 08-13-2019, 01:00 PM - Thread Starter
Rep: 1 (Unique: 1)
Hi so I have a 2080 (says it's an MSI Gaming X Trio) that regularly goes up to 80 Celsius+ in any sort of demanding game. I am wondering if anyone knows of a way to cool it for ~$150 Canadian? The case size is a restricting factor and I only have about 51mm below the GPU (pic below). Thank you.
Gutsdes is offline
post #2 of 8 (permalink) Old 08-13-2019, 02:03 PM
Kill Confirmed
speed_demon's Avatar
Rep: 77 (Unique: 64)
Have you tried removing the pci brackets and leaving them off? It allows air to more freely exit the case and made a small but helpful improvement on my last build.
You could also look into fitting larger and or better flowing fans like the Arctic Cooling F14 PWM for your intake.
speed_demon is offline
post #3 of 8 (permalink) Old 08-13-2019, 02:05 PM
Custy
Rep: 12 (Unique: 8)
vertically if space allows
https://www.amazon.ca/s?k=16X+Riser+Card+Cooler+Stand
slot coolers and other solutions
https://www.newegg.ca/p/pl?d=gpu+cooler
lite installs keeping things minimal on mine, haven't seen over 70c pushing my tiny card
(can rename Nvidia installer from .exe to .7z, and open with Bandizip to remove bloat, or..)
Nvslimmer (edit; Nvidia drivers have a DCH version, works best with this)
https://www.majorgeeks.com/files/details/nvslimmer.html
https://www.ghacks.net/2018/10/01/nv...vidia-drivers/
Rocklin is offline
post #4 of 8 (permalink) Old 08-13-2019, 02:29 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1092 (Unique: 633)
You can buy a new case for less than half your budget.
Alternatively, undervolt your GPU and set a custom fan curve. Costs $0 and will lower temps.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #5 of 8 (permalink) Old 08-13-2019, 02:43 PM
I <3 narcissists
bigjdubb's Avatar
Rep: 219 (Unique: 136)
I'd ditch the hard drive cage and mount the disk to the underside of the optical drive cage or flat to the bottom, that should get some more fresh air to the card.
You could probably add an AIO and stay within your budget if you want to really cool it instead of just improving the temps a little bit.
Out of curiosity, have you adjusted the fan profiles? The factory cards will sit in the 80's unless you tell it to keep it cooler than that.
Gaming Rig
(12 items)
Couch Gaming Rig
(10 items)
Work rig
(11 items)
Ryzen 7 3700x
Gigabyte X570 Master
EVGA RTX 2080ti FTW3
G.Skill TridentZ RGB
HP EX920 m.2
Intel SSD6 m.2
Intel SSD6 m.2
EVGA G3
CORSAIR H150I PRO
LianLi PC-O11 Dynamic
Operating System
Win 10 Home
LG 32GK650G
Ryzen 5 3600
Asus x470i
Radeon VII
Samsung 970 evo
InWin A1
NZXT M22
InWin A1
Operating System
Win10 Home
Vizio 4k TV
AMD Ryzen 7 2700X
Asrock X470 Taichi Ultimate
GTX 750
Patriot Viper
HP EX920 M.2
EVGA G3
CORSAIR H150I PRO
NZXT Source 210
Operating System
Windows 10 Pro
BenQ PD3200Q
LG 32UD59
bigjdubb is offline
post #6 of 8 (permalink) Old 08-15-2019, 06:16 AM
majestynl's Avatar
Rep: 98 (Unique: 48)
Agree!
Change the case also with more intake fan options! Even better to find a case where you can vertically mount the gpu! Doable for 150!
majestynl is offline
post #7 of 8 (permalink) Old 08-16-2019, 04:23 AM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
Move more air than the competition and blow them away useing 120x38s &#x1f604;
3770K @ 4600 1.31v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/8GB G.Skill BBSE @ 1066 9-9-9-24 2T 1.65v
EVGA GTX 980 Classified @ 1490/2000 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/6x 120x38 @ 7v-12v/CM Silent Pro M2 850
Owterspace is offline
post #8 of 8 (permalink) Old 08-24-2019, 07:28 PM
Kaltenbrunner's Avatar
Rep: 17 (Unique: 16)
Well I run with the side panels off all the time. The only thing I find loud is usually the single HDD, and ok the GPU fan in games is louder. But overall, my system is pretty quiet compared to a lot of people with a full case.
Also less dust builds up for sure. And yup it's cooler for sure. I should put the panels back on to see how much cooler. I don't use any case fans, just a 2x140mm SilverArrow and a monster cooler on a Zotac rtx 2070 AmpExtremeCore
Kaltenbrunner is offline
