Family PC having issues. Troubleshoot help please? - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 12-05-2019, 06:04 PM - Thread Starter
IMKR's Avatar
Rep: 38 (Unique: 28)
This is whats going on with the PC atm.
https://imgur.com/a/w2Hoy2I
And I am not sure where to start on troubleshooting. To try to keep timeline/events concise, ill keep it in steps
Original parts are (i forget exactly which one)
Haswell pentium (not the G3258)
H81m P33
4gb ram (forget exactly which one)
a used HD 5570 1GB that i picked up for like $5
1. Built in around 2014ish. had no problems until it first starting doing that (is that artifacting? never experienced it so IDK how it looks like. but ill call it that for simplicity sakes) artifacting in 2016/2017
2. it did it once in a while. and would stop eventually. so i ignored it. no problems at all
3. 2019 about 2 months ago it did it again, and this time showed no signs of going away.
4. I instantly assumed it was GPU (which is why i am still posting here) so i bought a used gtx 270 3 weeks ago. (EDIT: NOT GTX 270. it was a r7 240A. i remember now that it was listed as a 270. but looking at pic/gpuz it was an r7) Should have posted this on AMD GPU looks like now. sorry, initially thought it was the 270 again when looking back at purchase history
5. it worked just find until again, just today.... when its having the same issue.
Where do i being to start figuring out whats going on here?
I dont believe its the TV, as switching to a cable box, works fine.
but i dont know where to go from here
IMKR is offline
post #2 of 18 (permalink) Old 12-05-2019, 06:14 PM
Rep: 0
Have you unplugged the cable from the GPU and monitor and reinserted it? Have you tried switching to a different cable completely?
I'd start with that first, because cables can go bad or come loose over time and cause similar symptoms. Plus, that's the cheapest and easiest place to start.
skeksys is offline
post #3 of 18 (permalink) Old 12-05-2019, 06:34 PM
skupples's Avatar
Rep: 630 (Unique: 342)
cable >> monitor >> GPU.
somewhere in that pipe.
have you checked event viewer?
skupples is offline
post #4 of 18 (permalink) Old 12-05-2019, 06:46 PM - Thread Starter
IMKR's Avatar
no dice =/
what is event viewer? also the display is so bad i can barely see =/
also, idk if this will be relevant. but it has been a VERY long time since ive done a windows update on that PC. i believe 1 year (LOL. i know. not good) but its been going fine. on/off so i doubt thats the issue.
but the reason why i put it off so long is because 3 months ago, i tried to do my usual 3-6 month family PC windows update. only to be keep given the "windows had a failure updating some updates" message.
IMKR is offline
post #5 of 18 (permalink) Old 12-05-2019, 07:22 PM
professional curmudgeon
looniam's Avatar
Rep: 808 (Unique: 457)
btw, i don't understand this:
i can't tell what happened . . you (over)explained what gpu it was you bought - that doesn't matter. what matters is does #5 mean that it did work until today?
EDIT! nvermind, you are fine. its my reading skills that are the problem -sorry.
you sorta didn't need to do that. that pentuim has a little gpu itself aand motherboard has video outs:
now if you hook it up to that and it still happens after 2 gpus and 1 igpu - i would suggest to look at the cable/monitor. if it doesn't happen then the slot on the motherboard maybe suspect or you got unlucky with 2 gpus . . .
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #6 of 18 (permalink) Old 12-05-2019, 08:00 PM
skupples's Avatar
i'm exhausted, so this might be more scattered than usual -
event viewer (system software, search for it), critical tab, may provide info on where its coming from. Plausible still that its just the cable, do you have somewhere else you could slot the card? second PCIE slot, or second computer?
as to updates, side thought - windows doesn't like to update into build 1903 and beyond with a normal user account, make sure your user account control is set low enough to not require password, just yes/no.
also, if you CAN get into windows normally for a moment, you could always try to re-install the GPU drivers
skupples is offline
post #7 of 18 (permalink) Old 12-05-2019, 08:14 PM - Thread Starter
IMKR's Avatar
Quote: Originally Posted by looniam View Post
Attachment 310368
Attachment 310370
thats my bad lol. i got confused after i looked at purchase history to remind myself what GPU i replaced it with. but it is still AMD. (basically just wanted to point out taht i went from AMD to AMD again. NOT to nvidia)
but yeah it worked after i changed GPU. until today. (which is resulting in the EXACT same issue/pattern/look on the TV monitor.)
I cant use the igpu. TV monitor only has HDMI connection
I dont believe its the cabling issue or the TV monitor. using another HDMI showed same issue. and switching my TV monitor from HDMI input to the cable box, display has no issue.
I will check out event viewer. I am not quite sure what it is though/used for (other than the obvious name lol)
IMKR is offline
post #8 of 18 (permalink) Old 12-05-2019, 08:17 PM - Thread Starter
IMKR's Avatar
ty ill take a look at event viewer later.
I do have a second PC, but its my main PC. and I dont really want to do the whole change for it. especially since my main pc is using nvidia gpu.
the family pc is still w7. (googling what "build 1903" is, looks like thats w10 specific). but anyhow, theres no psw/acc settings set up on the family pc.
i will also try reinstall GPUs drivers ty
IMKR is offline
post #9 of 18 (permalink) Old 12-05-2019, 09:06 PM
Invalid Media
J7SC's Avatar
Rep: 43 (Unique: 22)
...might sound silly, but have you tried a different (ie 10 MHz lower or higher than stock) refresh rate via right click on desktop / screen resolution / advanced setting ? Same visual artifacts result ?
J7SC is offline
post #10 of 18 (permalink) Old 12-05-2019, 09:26 PM
looniam's Avatar
its a shame the tv is hdmi it would help if you could use the igpu. the more things you can easily swap out the better.
i see you have another rig. you don't need to tear it apart - test with just that monitor and cable.
if that works when the other is flaky at the same time, than it isn't anything on the mother board. i'm already of the mind that it isn't; the chances of 2 cards going bad the exact same way is pretty large. but a third test would be moving from suspect to confirmation.
your saying the tv is fine because of the cable box but isn't that a separate input? if so, then its not out of the woods yet. to be clear, once is a maybe, twice is suspect and a third time is confirmation.
and don't get weird about switching amd/nvidia/igpu because of drivers. microsoft's generic driver that comes w/windows will work fine just as in safe mode. maybe use DDU (while you have the second monitor plugged in so you're not blind!) and just get rid of the amd drivers anyhow.
finally re-seat the card in the pci slot again not just the power cables. though usually from what i've seen posted in past help threads - if the pci slot is going/gone bad than you wouldn't get a display at all. but if it starts "working" again, it would be time to give that a good visual inspection.
look, really, swap out the tv/monitor. i know you believe the tv is fine and i'm sure it probably is fine but just take 5-10 minutes and confirm it.
sorry if i sound harsh.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EKWB P280 kit
EK-VGA supremacy
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
looniam is offline
