Is EVGA RTX the only one that does the clicking sound when the fan starts and stops ? - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 12-10-2019, 05:56 PM - Thread Starter
Subzero11's Avatar
Rep: 5 (Unique: 5)
So my friend has a 2070 EVGA card and the fan makes clicking sounds when starting and stopping. He doesn't mind but it would definitely bother me. Wanted to get a Gigabyte windforce 2070 or maybe a 2080 but do they also make that sound ? I'd like to get a EVGA super cause the card looks cool but I won't if it's making that clicking sound. Strix looks good but it might not fit.
Subzero11 is offline
post #2 of 18 (permalink) Old 12-10-2019, 06:08 PM
Malinkadink's Avatar
Rep: 108 (Unique: 84)
Set a custom fan curve and don't worry about the clicking? The only time it would click is at system startup since the fans aren't spinning, but otherwise when the PC is on the fans would always spin. I never understood the point of turning off the GPU fans if the temp was below say 60C. You can run the fans at a level below your other case fans and still never hear it and get idle temperatures in the 30-40C range and prolong the life of the GPU. Personally i have my GPU fans at 40% always on a gtx 1080 zotac amp extreme and it keeps temps in check and isn't loud.
Malinkadink is offline
post #3 of 18 (permalink) Old 12-10-2019, 06:35 PM - Thread Starter
Subzero11's Avatar
Rep: 5 (Unique: 5)
I'm not installing 3rd party software to set a fan curve.
post #4 of 18 (permalink) Old 12-10-2019, 06:41 PM
Rep: 12 (Unique: 11)
Use the manufactures software of what ever card you buy to set the fan curve...
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #5 of 18 (permalink) Old 12-10-2019, 06:47 PM - Thread Starter
Subzero11's Avatar
Rep: 5 (Unique: 5)
Guess I should have been more clear I'm not installing any software to control a fan curve, it should have been designed better. The MSI Gaming X and the Strix I read make no noise whats so ever but cost more unfortunately.
Just sure about this one though:
https://www.microcenter.com/product/...cie-video-card
post #6 of 18 (permalink) Old 12-10-2019, 06:55 PM
Overclocker in training
ThrashZone's Avatar
Rep: 119 (Unique: 79)
Hi,
How do you overclock your gpu ?
You realize this is overclock.net not defaultclocks.net right
Only option without software is unplugging the fans
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #7 of 18 (permalink) Old 12-11-2019, 05:43 PM - Thread Starter
Subzero11's Avatar
Rep: 5 (Unique: 5)
Quote: Originally Posted by ThrashZone View Post
Hi,
Overclocking and running programs is two different things I have enough programs running I don't want anymore. I got the MSI and it makes no noise.
post #8 of 18 (permalink) Old 12-11-2019, 05:45 PM
skupples's Avatar
Rep: 630 (Unique: 342)
yeaaaah... even triple fan coolers are designed with custom curves in mind, even when they have "quiet" and "boost" mode bios switches. Relying on the system's profile is akin to relying on the worst case scenario for operation.
so do you also not wanna track frame times, utilization, usage, memory allocation, etc? cuz that's what afterburner is for. Just ask MSI though i guess technically MSIAB is no longer third party when running an MSIAB card
how will you figure out where you can dial in more performance if you can't track usage, and don't have a tool to up clocks?
skupples is offline
post #9 of 18 (permalink) Old 12-12-2019, 05:22 AM - Thread Starter
Subzero11's Avatar
Rep: 5 (Unique: 5)
so do you also not wanna track frame times, utilization, usage, memory allocation, etc? cuz that's what afterburner is for. Just ask MSI [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG] though i guess technically MSIAB is no longer third party when running an MSIAB card [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
I'm just more interested in just playing the dam games, instead of trying to get one extra frame here and there. Good day
post #10 of 18 (permalink) Old 12-12-2019, 05:33 AM
Me too, I don't OC anything on my system but I do set fan curves, set-em and forget-em. It's about extending the life expectancy of my $4000 investment, heat kills electronics, waiting for the factory curves to kick in allows heat to build up inside the case which is stressful on other components. I don't give two s***s about a few extra frames, a few extra MHz processing power, or milliseconds response time, I never notice such things and the loads I put on a system don't really benefit from it. But quality equipment, well cared for, means I spend less in the long run.
To each their own hope you find the card that fits what your looking for
Open Air Build
i9
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Other
DIY Sleeved Cables
