Min fan speed too high??? - Overclock.net - An Overclocking Community
post #1 of 21 (permalink) Old 01-13-2020, 01:39 PM - Thread Starter
Undervolter's Avatar
Rep: 521 (Unique: 256)
Hello, i need some help from the GPU gurus... I just bought a Gigabyte single fan 1650 ITX card and all is fine, except for one thing... The minimum fan speed is 56%. There is no way to change it. Even MSI Afterburner when you first launch it, it shows 56% on the extreme left of the sliding bar. I can only increase the fan speed (max fan speed is 2955rpm, sounds like an airplane). This 56% produces 1655 rpm, which on an 80mm fan, is noisy. The fan correctly revs up as the GPU heat rises, but never goes lower than 56%. I tried also the "AORUS Engine" program by Gigabyte, which shows 35 as initial value, but doesn't really work either. You can manually only raise the rpm, not lower it.
Now, i 've googled a lot and ironically, i 've found a similar EVGA case:
https://forums.evga.com/1070-FTW-Hyb...-m2606227.aspx
I 've also contacted Gigabyte support, but it's not like i trust them, so i thought to ask here. Is this "normal"? A BIOS hardlocked value perhaps? Or could it be a defect? I find it odd, that a card that is made to fit very small cases, would be locked to min fan at 56%, which is noisy. UNLESS, they thought that since ITX is small, better give it high RPM to avoid overheating?
I can of course dismantle everything and put on it an arctic accelero L2 plus cooler, since i have one. But i had to ask.
I also found a thread mentioning that sometimes you can edit BIOS to change the values or rpm speed. Is there such a tool that i could use for 1650 (Turing?).
Ryzen 2600 - MSI B450 Gaming Plus - 16GB Corsair 3000Mhz C15 - GTX 1650 Super
Undervolter is offline
post #2 of 21 (permalink) Old 01-13-2020, 01:58 PM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
How about if you click off auto on the fan and set a fan curve.
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS With Lizzard Grip 3m Tape
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 Sonar Producer
Turtle Rig is offline
post #3 of 21 (permalink) Old 01-13-2020, 02:05 PM - Thread Starter
I tried it. It doesn't work. It simply ignores anything lower than 56%. You can increase speed, but can't decrease it. At first, i thought the fan PWM wasn't working. But then i stresstested and saw that the fan speed increases as expected when the heat goes up. Only you can't make it go down.
It's a crazy GPU. Its clock even goes beyond the declared boost. In HWInfo, i saw a max boost clock of over 1700Mhz, without me running OC or something, while the offficial max boost is 1680Mhz, as per Gigabyte website.
post #4 of 21 (permalink) Old 01-13-2020, 02:12 PM - Thread Starter
Here it is... Theoretically, max boost is 1680Mhz (both the Gigabyte site and GPU-Z say it). Well, in practice, it boosts to 1740Mhz! Without me OCing or anything. Right now i haven't even Afterburner installed and i only run the basic nvidia driver (without the "Geforce gaming experience" part or whatever the name is).
It's like someone in Gigabyte was having fun and created a supercharged BIOS which boosts...everything.
post #5 of 21 (permalink) Old 01-13-2020, 03:36 PM - Thread Starter
This GPU gets weirder and weirder... I tried a game (Shogun2) and the GPU boosts to...1935Mhz! At first i thought it was HWInfo misreading. So i ran at the same time GPU-Z. Average is 1741Mhz. Still, neither should be happening on paper, but it happens...
post #6 of 21 (permalink) Old 01-13-2020, 03:39 PM
Imprezzion's Avatar
Rep: 102 (Unique: 89)
Totally normal. Advertised boost is the minimal boost it will run. The dynamic boost will clock it higher if temps and power limit is not reached.
Cars:
-Crashed: (not my fault ) '94 Nissan 100NX GA16DE (a.k.a. NX1600). Renault Laguna Phase I facelift '99 1.6 K4M. (Broke a strut and smacked a tree).
-Sold: '00 Nissan Primera P11-144 QG18DE, '97 Honda Prelude F20A4, 03 Ignis Sport.
-Current daily: '07 Ford Focus 1.6 Futura.
-Current funcars: '03 Peugeot 206CC 2.0 RFN fully riced and tuned (Turbo coming soon)
Full-On Rainbowbarf
(16 items)
P45 power!
(9 items)
i9 9900K @ 5.1Ghz 1.248v
MSI MEG Z390 ACE
MSI Armor GTX1080 Ti w/ Accelero IV @ 2063/6500Mhz
Corsair Vengeance RGB B-Die @ 4200 16-17-17-28-280-2T 1.54v
Samsung 850 EVO 500GB x2
Samsung 970 Evo 1TB
Seasonic Focus Plus Gold 750W
EK MLC-Phoenix 280 Kit
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro X64
Samsung S27B350H @ 1080p 75Hz OC
Iiyama GB2788HS @ 144Hz
Keyboard
Logitech G710+
Mouse
Trust GXT31
Mousepad
Corsair MM300 Large
Audio
Steelseries Siberia V2
Intel Core 2 Quad Q6600 G0 @ 3Ghz (333x9)
MSI P45 Neo2-FR
MSI GTX760 Gaming X
6GB completely random 1 and 2GB sticks. All 4 different ones.
A-Data 120GB SSD
AOpen 350w
Some huge aluminum Xeon heatsink
Cartboard box.
Operating System
W10 Pro x64
Intel Xeon E3-1270v1 @ 3.8Ghz
ASUS P8H61-i R2.0
Sapphire R9 280X Vapor-X @ 1230Mhz core.
16GB Kingston HyperX Savage 2400CL11 @ 1333CL6
Kingston 240GB SSD
Corsair CX600
Corsair H110i GTX
Custom open test bench made from a cut-up CM690 v1
Operating System
W10 Pro X64
Samsung 23" cheap thing
Keyboard
Cheapest one Aldi had
Mouse
Mousepad
The desk...
Imprezzion is offline
post #7 of 21 (permalink) Old 01-13-2020, 03:52 PM - Thread Starter
Oh, much like the CPUs then! GPUs have evolved more than i thought! So the only strange matter remains the fan speed... Thank you!
post #8 of 21 (permalink) Old 01-13-2020, 04:11 PM
deepor's Avatar
Rep: 483 (Unique: 328)
On the old cards from years ago, there was a minimum fan speed value that was set in the card's vBIOS. You would then not be able to go lower than that speed setting with your manual fan speed setting. Maybe it's still the same on the current cards?
The way to solve it in the past was by modding the vBIOS (there were simple to use tools to do that), and then flashing that modded vBIOS. I don't know if that's still possible. I heard something about NVIDIA using encryption to prevent modding.
deepor is offline
post #9 of 21 (permalink) Old 01-14-2020, 05:47 AM - Thread Starter
Yeah, i am pretty sure it's a BIOS problem, i just don't know if it's common to all GPUs of my model or it's a defect with mine... I found a flash utility and a bios from MSI Aero ITX 1650 which seemed very similar in specs and i managed to crossflash it. That didn't go well... I thought i bricked the card, because all screen was pink with small squares and a bit was coming out of this pink cloud when you were clicking and i barely managed to flash back the original bios (thank God i had it backed up).
No reply from Gigabyte support yet. The problem is, even if i put an artcic accellero on it, it will still run at 56% at idle. Which should be around 1200 rpm. Which should be much quieter than the current fan. But what if it's a defective GPU and not just a BIOS quirk common for the model... The reply from the esupport would be welcome at this point, but i doubt it will come soon...
As for EDITING the current BIOS, i found nothing useful by googling and i 've no idea how to do it myself if it involves ASCII and such.
post #10 of 21 (permalink) Old 01-14-2020, 06:29 AM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Easy way to fix it.... water cool it
Sent from my iPhone using Tapatalk
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
