GIGABYTE RTX 2080 Super Power Limit Hard Locked? - Overclock.net - An Overclocking Community
post #1 of 34 (permalink) Old 01-17-2020, 05:20 AM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
Hello, here is my new GPU:
https://www.gigabyte.com/uk/Graphics...8SWF3OC-8GD#kf
In software, I can only adjust the power target from 100% to 102%. I've tried using MSI AB, EVGA X1 and AUROS. How can I lift the limit? Most Super's support +124%. Thank you.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #2 of 34 (permalink) Old 01-17-2020, 05:35 AM
mfw
ToTheSun!'s Avatar
Rep: 451 (Unique: 219)
Power limit also depends on base power. A card with a 102% power limit might have a better power budget than one with, say, 105%.
It's not something you can change without installing a BIOS from another card with a higher power budget.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Rac3 RGB
Mouse
Glorious Odin
Mousepad
Gigabyte AMP500
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #3 of 34 (permalink) Old 01-17-2020, 05:53 AM
Rep: 17 (Unique: 10)
I had some similar issues with my gigabyte aorus xtreme waterforce. Maybe this will help. Close all gpu overclocking programs. If you use cam, disable the gpu oc feature. Open up aorus engine, reset to default, save, close aorus engine. Open up msi afterburner. Unlink the temp/power limit chain. From here you should be able to max out the limits, the voltage slider and set your clocks. I use afterburner instead of aorus engine now. Engine can be a bit buggy.
RGB GAMING
MSI GT83VR-6RE
(6 items)
[email protected] 4.78GHz/Cache HT/OFF ACDC/1 LLC/MEDIUM OFFSET/+120mv EIST/C3
Z390 AORUS MASTER BIOS/F11e
AORUS 2080Ti XTREME [email protected]/8000/366w
4x8GB [email protected] 15-15-15-32 1.58v/VDimm 1.3v/SA-IO
2x256GB SAMSUNG PM961 NVMe/RAID0
512GB AORUS RGB NVMe
500GB T-FORCE DELTA MAX RGB SSD
2x240GB HYPERX SAVAGE SSD/RAID0
480GB HYPERX SAVAGE SSD
EVGA 850w G+
NZXT KRAKEN X72
Fractal Define S2 Vision RGB
ALIENWARE AW2518HF 1080p/240Hz
[email protected]/4.2GHz Cache 1.27v/Load
2x GTX 1070/SLI
4x8GB [email protected]/3200MHz
500GB Crucial MX500 M.2 SSD
256GB Toshiba NVMe
2x Delta 230w(460w)
reachthesky is offline
post #4 of 34 (permalink) Old 01-17-2020, 06:03 AM - Thread Starter
Programmer
BradleyW's Avatar
The TDP is 250w so I think GIGABYTE have just hard locked it to a low limit. It is hitting the power limit at default clocks. It clocks in at 1920 @ 1.050mv.
I've never flashed a GPU BIOS.
Tried this, but it looks like the BIOS is at fault.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #5 of 34 (permalink) Old 01-17-2020, 10:06 AM
dajez's Avatar
Rep: 3 (Unique: 2)
102% doesn't look right to me. My xtreme waterforce wb has 140%, I guess it should be close to 130% or so for your card
Current
AMD Ryzen 3700X
ASUS TUF Gaming x570 plus wifi
Gigabyte RTX 2080 Super OC Waterforce WB
Crucial Ballistix Elite
Samsung 960 Evo
Samsung 970 Evo Plus
Corsair RM750x
Custom watercooling
Cooler Master Mastercase Maker 6 Pro
Operating System
Windows 10 Pro
Samsung C27HG70
Keyboard
Corsair k70 rgb
Mouse
Logitech G502
dajez is offline
post #6 of 34 (permalink) Old 01-17-2020, 10:47 AM - Thread Starter
Programmer
BradleyW's Avatar
After research, my card, the Wind Force, is 102%. The Wind Force Gaming OC (same card, higher clocks) is 120%. I've flashed the BIOS to the Gaming OC and now I can increase the power limit to 120%.
However, I've noticed with this card that no matter how much I increase the core voltage, the card doesn't seem to want to draw any more voltage..
Could the card be hard-locked physically not to draw more voltage regardless of what I set it to? Or is the card deciding not to draw more voltage to keep temperatures in check for the VRM's?
The card does 2010 @ 1.035v @ 63c. That's what RTSS reports in Superposition, Extreme.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #7 of 34 (permalink) Old 01-17-2020, 11:13 AM
jonkrmr's Avatar
Rep: 3 (Unique: 3)
The BIOS of your card has a max power limit of 255 watts. The Nvidia max power draw for reference board designs is 250 watt.
This is why you can only increase your power limit 2%. 2% over 250 watts is 255wats.
The only way you can get around this is by flashing the BIOS on the card to another one that will work on your card that has a higher max power limit.
There is nothing wrong with your card or your software and your software is reporting it right.
The GPU will only draw the voltage it needs. This can be from good silicon and or temp\power envelope algorithm GPU Boost of the GPU is using.
Pushing the voltage slider to max will not nessasarily mean the GPU will draw that voltage.
Turing chips do not really like more voltage anyway. Turing chips are sensitive to temp more than anything else.
jonkrmr is offline
post #8 of 34 (permalink) Old 01-17-2020, 11:33 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1276 (Unique: 691)
1) flash different BIOS
2) shunt mod
shunt mod will make your GPU think it's pulling <100% when it's pulling 100%, so your slider will still only go to 2% but it'll think it's only pulling <50% when it's pulling 102% and it'll be more or less unlimited anyway.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #9 of 34 (permalink) Old 01-17-2020, 11:45 AM
Super Noob
Delphi's Avatar
Rep: 90 (Unique: 82)
I have the same card as you and have been looking at bios modding it to this bios as I am always smashing the power limit on this card before anything else. Below is the bios I believe should work and gives an additional 45w.
https://www.techpowerup.com/vgabios/...er-8192-190708
Jack all Trades
(9 items)
Ryzen 3800x
Gigabyte x570 Aorus Elite
Giagbyte Windforce OC RTX 2080 Super
4 x 8GB Adata 3600mhz Ram
Samsung 860 Evo 1TB
Silverstone Strider 1000w
Fractal Celsius S36
Corsair 270r
Operating System
Windows 10 Pro
Delphi is offline
post #10 of 34 (permalink) Old 01-17-2020, 04:45 PM - Thread Starter
Programmer
BradleyW's Avatar
Thank you everyone for your kind support. I've learned a lot. I did some research prior to reading each reply. My research matches what has been discussed, with the power limits and BIOS limitations. I've flashed to the Gaming OC BIOS. The limit is now 120%, but the card still doesn't draw any more voltage, so the highest I can get my clock at very high load is 2010MHz. The card pulls 1.035v @ 65c.
Perhaps the shunt mod as suggested will now be a good step to take?
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
