9800gx2 problems? - Overclock.net - An Overclocking Community
9800gx2 problems?
post #1 of 13 (permalink) Old 03-30-2008, 01:31 PM - Thread Starter
niCe99's Avatar
Rep: 0
the card overall just performs poorly on my system
and games such as conflict denied ops...half of the screen will just go away whilst playing...
the funny part is...my frames are awesome
whats the deal?
could i have no enough power going to it? currently have a corsair 620hx
niCe99 is offline
post #2 of 13 (permalink) Old 03-30-2008, 01:32 PM
Mhill2029's Avatar
Rep: 873 (Unique: 579)
Power is fine, use the latest BETA's. Some of the drivers are problematic.
Intel Core i7-6950X @ 4.0Ghz
Asus Rampage V Extreme [Bios:3101]
4x EVGA GeForce Titan X SC Editions in SLI
2x EVGA 1080ti Hybrid FTW3's in SLI
32GB (4×8) Corsair Dominator Platinums (3000Mhz)
Samsung 950 Pro 512GB M.2 Nvme
2x 256GB Vertex 4 SSD (RAID-0)
2x 2TB Seagate Barracuda [Storage]
Optical Drive
Pioneer BDR-207DBK Blu-ray Writer
Corsair AX1500i Digital ATX 80 Plus Titanium
Corsair H105 (Push/Pull)
Lian Li PC-O8WX ATX Cube Case
Operating System
Windows 10 Pro x64
2x 27" Asus PG278Q ROG Swift 144hz
Audio
Logitech Z906 5.1 Surround
Mhill2029 is offline
post #3 of 13 (permalink) Old 03-30-2008, 01:34 PM
Rep: 116 (Unique: 105)
That's usually the case with new cards. Just wait a month or so and the drivers will mature and performance should increase.
igob8a is offline
post #4 of 13 (permalink) Old 03-30-2008, 01:35 PM
Retired Staff
Murlocke's Avatar
Rep: 912 (Unique: 541)
Yup power should be fine.
Try the 174.74 betas that were just released... make sure you uninstall your drivers, and restart your computer before installing them.
Also did you switch GPUs and not reformat windows? You'll likely need to either reformat or run a driver cleaner... but I don't think there are any good free driver cleaners for vista.. the one I use cost $. CCleaner cleans it pretty well though.
Murlocke is offline
post #5 of 13 (permalink) Old 03-30-2008, 01:41 PM - Thread Starter
niCe99's Avatar
Rep: 0
i switched from a 8800gts and i did the entire driver cleaner ect ect when changing drivers
i tried the 174.53 and currently using the 174.74
still nodda
would reformating fix this situation?
niCe99 is offline
post #6 of 13 (permalink) Old 03-30-2008, 01:42 PM
Mhill2029's Avatar
still nodda
Formatting solves pretty much all problems....give it a go.
I'm weird, whenever i install new h/w i format.
Optical Drive
Operating System
Windows 10 Pro x64
Audio
post #7 of 13 (permalink) Old 03-30-2008, 01:43 PM
Retired Staff
Murlocke's Avatar
still nodda
Reformating usually fixes most problems but this is most likely caused by immature drivers.. the 8800s were rather bad for the first few months... and they still arn't anywhere near perfect. New hardware = Lots of problems.
If I was you i'd reformat just because reformating doesn't bother me.. but no promises it will fix your issues.
You DID enable SLI in the control panel correct? Pretty sure with 1 9800GX2 you still get the option to enable/disable the built in SLI?
Same.. and the longest I go without reformating is 2 months tops. Storage drives FTW, takes like 30 mins to reformat.
Murlocke is offline
post #8 of 13 (permalink) Old 03-30-2008, 01:45 PM
Mhill2029's Avatar
It enables by default with a single GX2.
Optical Drive
Operating System
Windows 10 Pro x64
Audio
post #9 of 13 (permalink) Old 03-30-2008, 01:48 PM - Thread Starter
niCe99's Avatar
Rep: 0
alright i'll give it a try tonight
another thing i noticed when i actually play games without having half of it gone...theres alot of screen twitching
anyone know whatup with that?
niCe99 is offline
post #10 of 13 (permalink) Old 03-30-2008, 01:48 PM
!TopGear!'s Avatar
Rep: 4 (Unique: 4)
I wouldnt trust that Conflict Denied ops is 100% bug free itself, it could be that this game has issues with the GX2.
Try something like CSS or Crysis which are known to work fine with the GX2.
Also disable any AA you have on cos the current drivers don't support it when in SLi mode, could be whats causing oyur probs.
!TopGear! is offline
