Help The Noob Pick A Graphics Card - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 04-27-2009, 08:34 AM - Thread Starter
Rep: 2 (Unique: 2)
Hey guys,
As I posted in the new members section, I finally broke free from the grasp of mainstream PCs (Gateway) and I built my first system. Some of the parts were carried over from my Gateway, including my mediocre graphics card.
So now I would like to upgrade to a decent graphics card. I would like to stay under $150, so I'm basically looking at a 9800 or a GTS 250. I'm going to get it from Newegg, so if it's one that's offering free COD WAW, that would be a plus, but not necessary.
Something that keeps cool enough on its own would be a plus also, I don't want to raise my temps that much (even though my current 8500GT is running at 66C).
Thanks in advance.
-HAZE- is offline
post #2 of 39 (permalink) Old 04-27-2009, 08:48 AM
Rep: 164 (Unique: 145)
Get an ATI HD 4830. Its a better value than the 9800GT/GTS 250 (which are the same thing, BTW)
You guys saying IE is fine, you do realize it can't render correctly, which, I'd like to note, is the entire point of a web browser?
timw4mail is offline
post #3 of 39 (permalink) Old 04-27-2009, 08:49 AM
Rep: 43 (Unique: 28)
Is that 8500GT running 66c at IDLE!!!?
I jawdropped :|
BIGWORM is offline
post #4 of 39 (permalink) Old 04-27-2009, 08:52 AM
Nalty's Avatar
Rep: 25 (Unique: 24)
or a 4770
What would you possibly be running that would get your CPU to 90c under water?
Thermaltake Big Water
Nalty is offline
post #5 of 39 (permalink) Old 04-27-2009, 08:53 AM
Rep: 54 (Unique: 43)
9800GT = 8800GT
9800GTX+ = GTS 250
So they are not the same
Edit: To the OP. Go with a GTS 250. The reference design cooler is awesome, stays very cool. Even the non reference XFX model is good and comes with the free game. EVGA has the step up program so maybe you'll want to use that to get an even better card in 90 days. If not, XFX has the double lifetime warranty that makes it easier to sell your used cards.
Shooter116 is offline
post #6 of 39 (permalink) Old 04-27-2009, 08:57 AM
Rep: 297 (Unique: 218)
All GPU's run hot with the stock cooler on them...if you want a cold card you need aftermarket cooling. It's worth it for the OC you can get.
DIRTYDUCK is offline
post #7 of 39 (permalink) Old 04-27-2009, 08:59 AM
Retired Staff
el gappo's Avatar
Rep: 389 (Unique: 261)
gts 250 is a great card for the money, and if you get a palit version the temps are very cool, mine is clocked to 810/110/2009 and barely ever goes above 40C, and that is the stock cooler
Twitter @el_gappo @Overclocknet
Redhat: "The datasheet is clear so its pretty hard to read without an overhead projector"
el gappo is offline
post #8 of 39 (permalink) Old 04-27-2009, 09:20 AM
zmyth770's Avatar
Rep: 9 (Unique: 9)
i love my little 8500 with a Stock heatsink no fan, Runs load at 54C
Anyways i advise for $150:
Nvidia - http://www.newegg.com/Product/Produc...82E16814127423
Reason : Good card, Excelant cooling, Free WAW and a MIR.
ATI - http://www.newegg.com/Product/Produc...82E16814161244
Reason : Good card, ICEQ4 Turbo, Free game, MIR
My guide on how to build a computer
Current Upgrade allowance : $4.20CAD
zmyth770 is offline
post #9 of 39 (permalink) Old 04-27-2009, 09:29 AM
linskingdom's Avatar
Rep: 3468 (Unique: 1499)
It will be nice if the budget is $15 or $20 more, then pick a GXT260 216 for long haul. For $150, 4870 is a good option. Also, as mentioned in OP, GTS250=9800GTX+=4850 is also good for that LCD.
linskingdom is offline
post #10 of 39 (permalink) Old 04-27-2009, 09:29 AM
GuilT1's Avatar
Rep: 65 (Unique: 62)
If you don't mind open box items, you can usually get a 4870 under $150. http://www.newegg.com/Product/Produc...2E16814121288R
(RESERVED FOR SOMETHING CLEVER)
GuilT1 is offline
