8600 GTS Driver? Problem - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 06-28-2009, 02:22 PM - Thread Starter
^reflect!'s Avatar
Rep: 0
First of, I have been trying to fix this problem for the past 6 hours, with tons of reboots, driver uninstalls and 'driver-cleans' using programs such as "Driver Cleaner Pro" and "Nasty File Remover".
I recently have been playing Counter-Strike: Source, every time an enemy threw a flash grenade at me, my screen would turn white (as normal) but then these distinct lines would appear. This at first was not a big issue, but got more frustrating as time went by. I decided to check the nVIDIA driver page to see if there were any new drivers for my 8600 GTS card. (Hoping they may fix this issue) There were so I went ahead and downloaded the newest one and installed. I rebooted and this is when it all started. My NVIDIA Control Panel dissapeared from my right-click menu and checking my display settings showed a very different display. Before the "Display:" would read my samsung monitor now all it says is "Default Monitor". Something also noticeable to me was the 'laggyness' of moving windows around which led me to believe that the default windows vga drivers were being used in place of my NVIDIA ones. I decided to downgrade to the 182 drivers that I still had the install for, they still cause the same problem. To further add to the mess, when I go to Device Manager and disable and enable my video cards, everything goes perfectly back to normal and works great, my NVIDIA Control Panel comes back and everything is as good as new.
My guess is that the VGA drivers are kicking in instead of the NVIDIA ones, is this a common error? I certainly have never seen it before...
Any help would be greatly appreciated. Thanks
^reflect! is offline
post #2 of 5 (permalink) Old 06-28-2009, 04:55 PM
Rep: 195 (Unique: 167)
Were you trying this with 185.85 or 186.18? I've had plenty of problems with 185 drivers.
Did you uninstall the vga drivers?
crashnburn_819 is offline
post #3 of 5 (permalink) Old 06-28-2009, 05:47 PM
Acroma's Avatar
Rep: 53 (Unique: 50)
roll back to the 182.50 they are the best for a 8600GTS the newer one's don't like those cards.
Acroma is offline
post #4 of 5 (permalink) Old 06-28-2009, 05:54 PM
ghost2501's Avatar
Rep: 45 (Unique: 45)
I had tons of problems with mine on 185 the 186 arent too bad at all seemed to fix it, and I never tried the 182 But I will try that instead of the 186 next time.
ghost2501 is offline
post #5 of 5 (permalink) Old 06-29-2009, 08:31 AM - Thread Starter
^reflect!'s Avatar
Rep: 0
I tried both. Both the 185.85 and the 186.18. Same issue both times. :/
I didnt uninstall the vga drivers. How would I go about doing this? My device manager just shows my two video cards with a "!" symbol and then the name, when I click on properties it shows the cards as "Unable to start"
I'm on 182.50, and after just restarting, I still had to do the things I mentioned above to get my drivers right and working. :/
Yeh , stick with what works I guess.
