GTX 460 Default Voltage and Max Safe Voltage - Page 4 - Overclock.net - An Overclocking Community
post #31 of 33 (permalink) Old 07-24-2011, 06:25 PM
Ore Wa Gundam
EvoBeardy's Avatar
Rep: 187 (Unique: 158)
Originally Posted by ConsciousInsanity View Post
Thanks but that guide is a bit confusing. i saw some stuff about shaders which im not worried about. My shader and core are linked and I just leave it at that. Im going to try upping the voltage by .013. And by the by is their an unsafe increment to up a voltage by. I was told for OC'ing to not increase a clock by more than 15MHZ at a time. Is there a similar rule for voltage increases?
Yeah, as Mikecdm kindly pointed out, my intention was just to show you it's a similar thing as with the straps that are used for Core, Shader and Memory frequency increases, wherein it's by increments, and not every number.
Sorry about that, didn't mean to add confusion.
Originally Posted by Mikecdm View Post
I think he means that the voltage goes up in increments as well, similar to how shader straps worked on the 200 series and below. The stock limit on my 460 is 1.1v. I personally wouldn't have a problem running at 1.1v 24/7. I ran it at 1.3v the other day on stock cooling to test it out. Turns out it doesn't clock too well on stock cooling, regardless of voltage.
Yup, I got some copper heatsinks, scraped the gunky T4000 off them and put some nice Sekisui Thermal Tape, then plonked 'em on the MOSFETs, the stock cooler on this is really pants though.
At 1.0v I can do 815/1050 OCCT stable (64c Heaven), [email protected] (84c OCCT, 74c Heaven) [email protected] 1.075 (OCCT- Toasty, 81c Heaven). and I stopped bothering there.
Will test again with a decent cooler, these really don't like 72c and over.
Unicorn SD
Astraea
(8 items)
l Intel® Core™ i7-5820K l
l MSI X99A SLI Krait Edition l
l MSI GTX 980Ti Gaming 6G l
l Corsair Dominator® Platinum (4x4GB) DDR4 3Ghz l
| Samsung PM951 M.2 PCI-e NVMe 512GB |
l Samsung 840 Evo 500GB l
l Toshiba X300 4TB 128MB Cache l
l Toshiba MD04ACA400 4TB l
l Toshiba DT01ACA300 3TB (x3) l
l Samsung F3 1TB l
Optical Drive
l Pioneer BDR-209EBK l
l EVGA SuperNOVA G2 850w l
l NZXT Kraken X61 (2x Noctua NF-A14-2000-IP67) l
l Phobya MaxGuide 6 Controller l
l CM Storm Stryker™ l
Operating System
l Windows 7 x64 Customised. l
l LG M2380D 1080p l
l Acer Predator XB240H 144Hz G-Sync l
Keyboard
l Logitech G19s l
Mouse
l Logitech G502 l
Mouse
l Razer Vespula l
Audio
l Steelseries Siberia V2 MSI Gaming Edition l
Audio
l Logitech Z506 5.1 l
Audio
l Creative Fatal1ty HS-800 V2 l
G3258 @4Ghz
MSI Z97I Gaming AC
MSI GTX 460
Crucial Ballistix Sport 1600MHz 8GB
Samsung 840 Evo 128GB
Toshiba DT01ACA100 1TB
Optical Drive
Optiarc 7170S
Cooler Master Silent Pro M2 520w Modular
Corsair H60
Cooler Master Elite 130
Operating System
Windows 7 x64
Keyboard
Logitech K400 Wireless Touch
Mouse
Logitech M187
i5 460m
MSI Intel HM55
Onboard Intel HD
Kingston PC3-8500F
Kingston PC3-8500F
Toshiba MQ01ABD100H [Hybrid]
Optical Drive
Optiarc AD-7580S
Operating System
Windows 7 X64 nVidia Ed.
EvoBeardy is offline
post #32 of 33 (permalink) Old 08-29-2011, 12:38 PM
[CyGnus]'s Avatar
Rep: 211 (Unique: 168)
I would say safe voltages for stock air cooling 1.037v aftermarket cooling (Accellero xtreme plus 2) 1.1v and WC 1.15v i would not use more. I am sitting at 1.062v @ 925/1850/2000 WCed
[CyGnus] is offline
post #33 of 33 (permalink) Old 08-12-2016, 03:06 PM
jerramie's Avatar
Rep: 0
why would you OC your ram? IDK what ram you have but i have 8 gigs of ddr3 running @ 1866 with GTX 460 standard clock. i run BF4 @ max and i only use 40% of my ram and about 33% of my cpu. OC gpu - yeah but only if you have to.. for games i see no reason to OC your ram or cpu. Don't get me wrong.. i am a big fan of - GO FASTER! but i must say... I never had a problem with a gpu until i started OC'n them. I have burned out at least 4 of them over the years and i just burned out another 460 last week. I never had issues with heat or instability during OC once i got them running smooth via increased voltage. I have used MSI afterburner and similar utilities and it seems that every time.. no matter what.. the card burns out in less than a year. After they burn out - I like to bake them in the oven to get them running again and use them to experiment. BTW : GTX 460 standard voltage is 0.912 V
jerramie is offline
