[HELP] Artifacts on 8800GTX - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 03-12-2011, 07:30 AM - Thread Starter
-HOOT-'s Avatar
Rep: 0
Hi Guys,
Hope you can help me out on this one, I'm pretty sure I will have to buy a new GPU because of this problem, but before spending any money I wanted to have an opinion from people who have greater experience than me (Rig. Specs in my signature) thumb.gif
Last Wednesday I was trying out the Crysis 2 beta when suddenly my computer crashed and I had a blue screen. Restarted it and everything was ok; on Thursday I decided to give it another go but this time, when I started playing, the computer froze so I had to manually shut it off. When I restarted it, I got all sorts of artifacts on screen right from startup, in the BIOS and obviously in Windows 7. I have already tried installing new drivers for the 8800GTX but that did not help, furthermore from the 1920x1200 native screen resolution of my 24" monitor it has now reset to 640x408 and cannot be changed. frown.gif
I suspect its the video cards RAM that has gone bad, here are a couple of pics. of the artifacts I get on screen:
(Here you can clearly see the resolution being fixed at 640x408)
P.S. I have OPSEC'd some of the personal data, hence those squares added in paint.
-HOOT- is offline
post #2 of 14 (permalink) Old 03-12-2011, 07:32 AM
Intense's Avatar
Rep: 35 (Unique: 34)
have you tried baking it??
heres a guide: http://www.evga.com/forums/tm.aspx?m=696061&mpage=1
boy, you should have seen my ex girlfriend do a gigaflop. Then she starting doin tetraflops, i knew it was over then.
both my 570 and 8800 squeal at load... rolleyes.gif I just tell them to fold faster...
Intense is offline
post #3 of 14 (permalink) Old 03-12-2011, 07:37 AM
Emmanuel's Avatar
Rep: 385 (Unique: 316)
Yeah at that point if you have no warranty, bake it.
2nd Amendment supporter
Emmanuel is offline
post #4 of 14 (permalink) Old 03-12-2011, 07:39 AM
adizz's Avatar
Rep: 226 (Unique: 187)
Yea baking would be your best option. But remember it won't fix your card permanently so you should consider a replacement ASAP.
http://files.overclock.net/images/smilies/smile.gif
Mystery Machine
(15 items)
Intel 1
(10 items)
i5 8400
Asus TUF B360-Plus Gaming
Sapphire Nitro+ RX580
Corsair Vengeance
Kingston UV400 240GB+Seagate Barracuda 1TB+WD Black 500GB
Optical Drive
LG HL-DT-ST GH24NS72
Corsair TX650 V2
lapped TRUE 120
Corsair Carbide 400R
Operating System
Windows 10 Pro x64
BenQ G2220HD
Keyboard
Razer Lycosa Mirror
Mouse
Razer Deathadder 3.5G
Mouse
Razer Goliathus Fragged
Audio
Onboard
Intel C2D E7200
GA G31M-S2L
Palit GTS250
2GB Transcend
Seagate Pipeline 320GB
Seagate Barracuda 80GB
Stock
Generic
Operating System
Windows 7 Ultimate
Samsung 17" CRT
adizz is online now
post #5 of 14 (permalink) Old 03-12-2011, 09:00 AM - Thread Starter
-HOOT-'s Avatar
Rep: 0
If it wasn't for the link I would have thought you guys were joking ! biggrin.gif I think I might give it a go, since the gpu is an ASUS EN8800GTX and AFAIK the warranty is 3 years and I bought it in 2007 so I can't RMA it. frown.gif
In case I need to change it what do you guys think would be the best option out of these three solutions ?
- 1x Nvidia GTX 570
- 2x Nvidia GTX 460 SLI
- 2x Ati Radeon HD 6850 CrossFire
Cheers and thanks for the help.
-HOOT- is offline
post #6 of 14 (permalink) Old 03-12-2011, 09:04 AM
OverTheBelow's Avatar
Rep: 53 (Unique: 50)
Theoretically, it would work until he gets the card up to or above 90C again.
Support PC developers - act against piracy.
OverTheBelow is offline
post #7 of 14 (permalink) Old 03-12-2011, 10:38 AM
Chewy's Avatar
Rep: 205 (Unique: 183)
Chewy is offline
post #8 of 14 (permalink) Old 03-13-2011, 04:06 AM - Thread Starter
-HOOT-'s Avatar
Rep: 0
If I decide to change it do you guys have any suggestions out of the three possibilities I listed ?
-HOOT- is offline
post #9 of 14 (permalink) Old 03-13-2011, 04:10 AM
MightyMission's Avatar
Rep: 74 (Unique: 58)
gtx 460 x2:)
MightyMission is offline
post #10 of 14 (permalink) Old 03-13-2011, 04:33 AM
Volvo's Avatar
Rep: 395 (Unique: 323)
Try putting it in the oven, or using the self bake method.
Which is to remove the heatsinks on the card, slot it in a PCIe slot and let the core get hot.
The solder will re-flow itself that way, and its safer than the oven method because only the core gets heated; other parts are unaffected.
Volvo is offline
