Ongoing Pascal latency problems - Hotfix doesn't work for everyone. - Overclock.net - An Overclocking Community
post #1 of 1683 (permalink) Old 07-10-2016, 11:55 PM - Thread Starter
bugsixx's Avatar
Rep: 3 (Unique: 2)
OK we found a system we were able to reproduce this on. Thank you all for your assistance. Once I have further information I will update everyone.
I just upgraded to a PNY GTX 1080 FE and unfortunately, even though the performance is great, all my games and videos on youtube or netflix now stutter sometimes with crackling sound.
As I already had some experience with crackling sound on an old configuration of mine, I decided to check the DPC Latency with DPCLat (I am on Windows 7 x64 SP1). To my surprise, I found out that the DPC Latency is around 350-400us when the PC is idle and it is around 900us with spikes up to 1500us when in game or netflix.
You can check your DPC Latency with any of these two tools:
Latency Checker
Latency Checker doesn't work on anything past Windows 7, LatencyMon is recommended.
LatencyMon
This is a GTX 1080 @ load.
This is how it should look like:
For reference, here's a healthy 750Ti under max load with LatencyMon:
"Current measured interrupt to process latency" and "Highest Reported DPC Routine Execution Time" are the most important value with LatencyMon (LatencyMon is compatible with Windows 8/8.1/10)
"Current measured interrupt to process latency" is your current DPC latency in real time, "Highest Reported DPC Routine Execution Time" are your DPC spikes.
LatencyMon is intended to troubleshoot audio issues, such as crackling and dropping audio streams. Not GPU "stutter", but ideally your DPC readings should be as low as possible, under gaming loads anything below 50us is PERFECT, below 100us is AWESOME, below 200us is OK, above 200us is not OK, anything close and above 500us is a serious problem.
Your idle readings must stay below 20us at all times, ideally you should have less than 5us for "Current measured interrupt to process latency", you can basically ignore the Pagefault readings as these are just the amount of commands loading the RAM from your storage and OS drives.
Your load readingsmust stay below 50us at all times, ideally you should have less than 30us for "Current measured interrupt to process latency".
If your nvlddmkm.sys causes the high latency it means the Nvidia driver is the main source of DPC latency in your system, post in the Nvidia thread so they can find a solution, coming from a R9 290X to a GTX 1070 G1 I hope Nvidia fix this soon or I'll probably regret going green.
SOURCE
UPDATE 1:
A fix seems to be in the works.
Here's the knowledgeable user Cookieboyeli with great insight on what your target DPC latency should be and why.
Cookieboyeli's useful post.
UPDATE 2:
NVIDIA Display Driver Feedback is a survey born from this issue, I urge anyone with Pascal GPUs to check Cookieboyeli's post before using LatencyMon and then filling Nvidia's survey if you encounter any problems, it should help tremendously on the process of fixing this elusive bug which as many have said has been (to a lesser extent compared to Pascal) affecting several generations of Nvidia cards.
NVIDIA DISPLAY DRIVER FEEDBACK.
According to Manuel Guzman, NVIDIA's rep on Geforce.com forum :
A fix will not make it in time for the next driver so it will likely be included as part of the following driver. If a fix is ready and validated much sooner I will push for a hotfix driver to get it out to everyone as soon as possible.
It varies (DPS latency) by users configurations/drivers. If you see it on your system, swapping it for another 1080 card would give you the same DPC numbers. Our drivers are within Microsoft Windows specification for DPC but we are able to reduce it which should address this issue for users.
Hotfix driver now available to try.
http://nvidia.custhelp.com/app/answers/detail/a_id/4202
Link to old thread (closed but with more info)
https://www.overclock.net/t/1605618/nv-pascal-latency-issues-hotfix-driver-now-available
bugsixx is offline
post #2 of 1683 (permalink) Old 07-11-2016, 12:12 AM
d0mini's Avatar
Rep: 65 (Unique: 60)
Does this happen with other Nvidia cards as well?
Just asking for no reason in particular just maybe because I have an nvidia card that isn't one of those, for entirely selfish reasons and because I'm too lazy to google for my answer
EDIT
Saphira Mk-III
(27 items)
[email protected], 1.36v (4.5GHz uncore)
Maximus VII Impact
MSI 980 Ti Gaming 6G
Corsair Dominator Platinum 16gb 2133 CL9
2x 840 EVO 500GB
Toshiba XG3 1TB (M.2 NVMe SSD)
MX 500 2TB
EVGA G2 850 PSU
EK Supremacy Evo & VGA
11x ML 120 PRO fans
5x Gentle Typhoons 1850rpm intake, 1x GT 1450rpm exhaust
PE-240; XT45 120; SR-2 360; XSPC RX 360; 2 x XSPC RX 480 rads
Corsair Commander Pro
Aquaero 6 LT; Splitty 9; Hubby7
2 x Ek Xres 140 pump/res
Phanteks Enthoo Elite
Operating System
windows 10
Acer Predator XB271HU
Keyboard
Corsair Strafe RGB
Mouse
Logitech G Pro Wireless
Mouse
MX Master AMZ
Mousepad
XXL neoprene mousemat goodness
Audio
Sennheiser HD 650
Audio
Senheisser Game Zero SE
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
[email protected], 1.23v (4.5GHz uncore)
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
2x Gentle Typhoons 1850rpm exhaust
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Acer Predator XB270HU
Keyboard
Corsair Strafe RGB
Mouse
Mouse
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
post #3 of 1683 (permalink) Old 07-11-2016, 12:15 AM - Thread Starter
bugsixx's Avatar
Rep: 3 (Unique: 2)
EDIT
It seems it only happens on GTX 1080 and 1070 on drivers which are for them (meaning last 3). Some people changed their 1080 in their system back to their older card (titan x , 980) and instantly the latency went back normal.
Just my luck, i bought 1080 because i wanted a fast card going from radeon 390 which was acting goofy also
Now i'm having the flickering and this DPC latency issue......i swear.....
Oh! And welcome to OCN :
bugsixx is offline
post #4 of 1683 (permalink) Old 07-11-2016, 12:22 AM
Junglist
Swiftes's Avatar
Rep: 403 (Unique: 305)
I am getting this with my new 1070, just thought it was Just Cause 3 being a buggy mess as it is all I got around to playing yesterday!
Ni-Ten-Ichi-Ryu
(18 items)
Intel i7 4790k
Asus Maximus VII Gene
Zotac GTX1070 Founder's Edition
16GB Samsung LV Green [2.4Ghz / 11 - 11 - 11 - 27 -2T / 1.5v]
Corsair Force 3 [120GB] [x2]
Seagate 7200.14 [2TB]
Optical Drive
LG Blu - Ray Writer [Slot Loading]
eVGA Supernova 750W G2 [White Braided Cables]
Corsair H100i V2
Corsair Obsidian 350D [High Airflow Kit]
Operating System
Windows 10 x64
LG 29UM68
Dell U2412M
Keyboard
Microsoft Sidewinder X4
Mouse
Steelseries Sensei
Audio
Focusrite Clarett 18i20 (mk1)
Audio
Yamaha HS-7 / Beyerdynamic DT880 Pro / Sennheiser HD-25
Swiftes is offline
post #5 of 1683 (permalink) Old 07-11-2016, 12:24 AM - Thread Starter
bugsixx's Avatar
Rep: 3 (Unique: 2)
Seems a lot of people are having this. Post in the nvidia thread and fill out the survey which was posted on page 10 by the nvidia rep so they can get a fix faster.
Also the more people will report it, the higher possibility of them fixit it.
https://forums.geforce.com/default/topic/941579/geforce-1000-series/gtx-1080-high-dpc-latency-and-stuttering/post/4922866/#4922866
bugsixx is offline
post #6 of 1683 (permalink) Old 07-11-2016, 12:41 AM
@ASUS
Silent Scone's Avatar
Rep: 402 (Unique: 225)
This is nothing new, as such. Nvidia have always had dpc efficiency 'issues'. Unless you are noticing any detrimental performance or audio dropouts, it's not something you should really concern yourself with.
Silent Scone is offline
post #7 of 1683 (permalink) Old 07-11-2016, 12:43 AM - Thread Starter
bugsixx's Avatar
Rep: 3 (Unique: 2)
I am getting micro stutters in all of my games.
Gsync monitor, was supposed to be butter smooth, but with this i'm getting these annoying choppinness.
Also i get cracking audio in cities skylines out of my games i tested.
bugsixx is offline
post #8 of 1683 (permalink) Old 07-11-2016, 12:50 AM
Oh god, my GTX 1070 comes tomorrow, this have killed all my excitement.
Hell, I won't even install my GTX 1070 and I will keep using my 290 until Nvidia release a new fixed driver.
And people say AMD drivers suck but they are the best on this regard... The irony.
Dargonplay is offline
post #9 of 1683 (permalink) Old 07-11-2016, 12:56 AM - Thread Starter
bugsixx's Avatar
Rep: 3 (Unique: 2)
If i knew this beforehand i would not buy this 1080 mad.gif If Nvidia will not fix this i might be stuck with a stuttering card.
bugsixx is offline
post #10 of 1683 (permalink) Old 07-11-2016, 06:30 AM
Quad Core? Quad Damage!
XenoRad's Avatar
Rep: 50 (Unique: 46)
I have a 1070 and I can't quite say that I've noticed this - or at least I didn't know what it was. I may check those tools when I get home.
I've had an R9 290X until recently and AMD really did step up their game beginning with the Omega and then the Crimson drivers. The only caveat was that on certain AAA games the initial performance wasn't that great until they released some optimized drivers.
XenoRad is offline
