Any way to disable "fail-safe" from driver to stop 100% fan speed? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 01-18-2019, 09:52 AM - Thread Starter
Rep: 0
I have an older card, a GTX 970 G1 GAMING and a few days ago a fan started failing. Three years passed, so I can't RMA it, sadly. I tried everything to make the fan work again, but at the end I had to disconnect the fan from the connector on the card.
But the problem now is, that the other two is spinning at 100% all the time. There's a fail-safe in the nVidia driver which possibly detects if one of the fans can't go above a specific RPM, and protects against overheating. When I remove the driver with DDU, or just disable the adapter from Device Manager, the fans are running at low speed, so it must be the driver.
I tried using MSI Afterburner to tune it down, but I don't think the software can even detect the speed properly now (RMP 0, speed at minimum 33%).
So, I'd rather take the risk of overheating than listening the card at full speed all day...
The only thing I need is to have my fans working like they are supposed to be again. So I can tweak them and worry about the cooling MYSELF! I extracted the BIOS with GPU-Z and lowered the RPM (like this), just to see if it uses these values at all, but nothing changed.
There's probably an "emergency" state which is active right now, with the 3rd fan being disconnected, and THAT'S what I'd like to disable.
Does anyone have a solution for this? I'm willing to do some risky stuff just so I can get rid of this airplane in my room..
Devvie is offline
post #2 of 6 (permalink) Old 01-18-2019, 09:57 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
why not just buy a replacement fan?
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #3 of 6 (permalink) Old 01-18-2019, 10:03 AM
Rep: 0
Connect the fan rpm cable to the 3. fan connector, so that 1 fan provides the rpm signal to both connectors.
gt86 is offline
post #4 of 6 (permalink) Old 01-18-2019, 11:27 AM
Packet Pusher
Renegade5399's Avatar
Rep: 230 (Unique: 145)
Ebay, AliExpress, the tech version of Wish called Geek (I think).
If not just the fan, then replace the whole cooler with either a good OEM one from ebay or one of the Arctic Cooling (or other) aftermarket ones.
I replaced the coolers on BRAND NEW Zotac 1080Ti AMP Editions because I modded them to AMP Extremes and the stock cooler at 100% fan speed kept the card at a balmy 91°C load temp.
My Sauce Is Much 13373|2 Than Yours
What's in your hardware wallet?
[Gigabyte Aorus 1080 Ti Owner's Club]
Project Blackout
(24 items)
i9 7900X Delidded
ASUS TUF X299 Mark 1
EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING
G.SKILL Trident Z Royal Series 16GB - Samsung B-die DDR4 4000
G.SKILL TridentZ RGB Series 16GB - Samsung B-die DDR4 4000
4x 1TB Western Digital Black
2x 480GB Kingston HyperX Savage SSD
2x ADATA Ultimate SU800 1TB 3D NAND
Intel 660p Series M.2 2280 1TB PCI-Express 3.0 x4
INTEL® RAID ADAPTER RSP3DD080F
2x 2TB Western Digital Green
CORSAIR HX Series HX1000
Custom Water Cooling Setup
Bitspower MonoBlock ASX299TUF RGB-Nickel
Thermaltake Core X71 Tempered Glass Edition Black
Operating System
Winders 10 Pro 64bit
Pixio PX276h 27"
Acer GN276HL 27"
HP EliteDisplay E222 22"
Keyboard
Corsair K95 RGB PLATINUM - Cherry MX Speed - Gunmetal
Mouse
HP Omen Reactor
Mousepad
Corsair Gaming MM800 RGB Polaris
Audio
Sades SA926 Gaming Headset
Renegade5399 is offline
post #5 of 6 (permalink) Old 01-18-2019, 01:09 PM - Thread Starter
Rep: 0
Thanks for the replies!
It takes too much time
But yeah, I'll probably do that in a few weeks. However, I wanted to do something about it as soon as possible!
Will this actually work? So there's no way to do it in BIOS, right?
But I'll definitely try this one out, if I manage to take my card apart.. (I'm more like a software guy, hah) Thanks again!
Devvie is offline
post #6 of 6 (permalink) Old 01-18-2019, 01:38 PM
Rep: 0
Iam quiet sure that it will work.
If the fans are alle the same or at least spin with roughly the same rpm it should work for sure.
Atleast when the missing rpm is the problem (which sounds quiet possible). If thats not the reason (which i doubt), then the card could measure the current => apply a resistor to fake the fan.
But first try it with the rpm signal cable.
gt86 is offline
Tags
bios , driver , fan
