Dual Kraken G10 7970 Crossfire Corsair Air 540 Question - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 01-16-2015, 06:59 PM - Thread Starter
OneSh0tmurd3r's Avatar
Rep: 0
hey! i was wondering if you guys think this setup is ok?
I got a sp120 quiet edition on each of my g10 with corsair h75 on each. My Cpu has a corsair h80i.
Idle:
Gpus avg 23-25
Cpu 26-30 / i5-4670k @ 4.42ghz
Load Battlefield 4:
Gpus Avg 43-52
Cpu avg 44-48
let me know!
OneSh0tmurd3r is offline
post #2 of 4 (permalink) Old 01-17-2015, 05:18 AM
AliNT77's Avatar
Rep: 14 (Unique: 13)
no of course its not okay
its superb bro :|
AliNT77 is offline
post #3 of 4 (permalink) Old 01-28-2015, 06:19 PM
InstaBurn's Avatar
Rep: 0
For whatever reason, overkill I guess, I put fans on both sides for a "push/pull" on both of my corsair H55's.
I had the space and the increase in cost was minimal.
What you have isn't bad... but if you can handle the extra space and have the $$ i would buy 3 more fans and 3 baggies of extra screws and maximize the cooling on my system... why not right?
You've gone down the road this far... no?
Current Rig:
Fractal Define R4, 4790k, 4gb x 4 GSkill 2133mhz RAM, Gigabyte SLI Mobo, Corsair H110 Dual 140mm w/ 4 Noctua's in Push/Pull, Dual 7970 Sapphire 6gb VaporX's with Kraken G10's and Corsair H55's to chill things out With Noctua 120mm's in push and 150mm's in pull, Seasonic 1200w Platinum P/S, Mushkin 1tb SSD for OS and Games... 4tb Segate for the rest, Lots of 4-pin fan splitters..hah.
InstaBurn is offline
post #4 of 4 (permalink) Old 02-10-2015, 06:12 AM - Thread Starter
Rep: 0
i went all out. got dual Antec 140mm ontop as exhaust http://www.newegg.ca/Product/Product.aspx?Item=N82E16835209051
Running dual sp120s quiet on each h55 for my krakens as front intake
Running Stock H80i dual exhaust rear
Got a front intake Antec true quiet 120mm ontop as 3rd mount
