Sapphire 5700 XT + Raijintek Morpheus II + VRM heatsink - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 02-10-2020, 03:27 PM - Thread Starter
Yuriewitsch's Avatar
Rep: 21 (Unique: 16)
Well, how to start this.
This is not my first cooling mod. I already got my hands on some AMD graphics cards:
- Gigabyte HD 7950 WF3
- Sapphire R9 290 and Gigabyte R9 290X
I was using my spare Arctic Accelero Xtreme 3 + some aluminium heatsinks to do some "magic", but this time I wanted to try something else, how to say it, more esthetical and pleasing for the eye. Yeah, black FTW. :-)
I bought a cheap reference Sapphire 5700 XT, nice black GPU cooler Raijintek Morpheus II Black and two aluminium heatsinks from Aliexpress.
My idea was to make a black full cover heatsink to cool VRMs and memory on the 5700 XT and for the core I was gonna use Morpheus.
Firstly, I made a template from transparent plastic foil to make my measurement a little easier.
Those two aluminium blocks from Aliexpress were glued together by two component adhesive. Then I used a paper tape to protect this black heatsink from scratching during my "work" with Dremel tool and files.
It took a very long time to get everything done and it was a "pita" job. Plus I sanded whole VRM a memory area with sand paper 1200 to get better contact with thermal pads. But this was only a bottom part of the hetsink.
"Top" part was even worse, I had to make room for Morpheus and its heatpipes around core.
It wasn't easy, I don't know how many times I checked clearance and gaps between Morpheus and full cover heatsink. There was always something in the way.
Between Morpheus and core I used Thermal Grizzly Kryonaut thermal paste and on memory chips and VRM I used Gelid GP-Extreme thermal pads (12 W/mK). Also I placed plastic washers between PCB and heatsink to get straight preasure on whole area.
On "backside" of the card I used original backplate with Phobya thermal pads under it to get even lower temps on those bloody memory chips. To avoid short curcuit I placed double sided thermal tape (I think Akasa or Alphacool) on almost every small component on PCB.
Fans choice, which would go on Morpheus, took also a long time, but I eventually chose this relatively cheap Arctic P12 PST CO fans.
To mount this heatsink to card I drilled 2,5mm holes into it and used M3 screw-tap to create an even thread. I think 20 screwes hold this beast, so it is fair to say that it's not going anywhere.
When everything was done I could finally screw everything together and "create" this beauty:
This is how it looks in my moded Jonsbo RM4 case (lots of modifications, I have to make a build log someday):
To check temps and noise I made it run through Fire Strike Ultra benchmark with my "sweet spot" 2100/900/1,15V settings and here is a result (ambient temp in the room was 24°C):
I really like how this mod turned out, it took hell of a time, but in my opinion it was worth it.
Frankly, I like this 5700 XT mod a lot.
Feel free to ask, share, comment, criticise, whatever...
I hope this mod will inspire others to not be afraid to get their hands on hardware, it's OVERCLOCK.NET anyway. :-)
Case: Jonsbo RM4 mod PSU: Corsair RM750 CPU: Intel Core i7-4790k RAM: Crucial Ballistix Tactical LP 4x4GB GPU: Sapphire 5700XT + Raijintech Morpheus mod
Yuriewitsch is offline
post #2 of 11 (permalink) Old 02-10-2020, 03:34 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1282 (Unique: 691)
looks sweet, make me one for my 1080 Ti
Morpheus II is the best upgrade I did in a long time, but using adhesive tape for the dollar store quality mosfet heatsinks surely felt really cheap for an otherwise solid product.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 11 (permalink) Old 02-10-2020, 03:51 PM
poah's Avatar
Rep: 7 (Unique: 6)
pretty good mod and temps - those arctic fans are really good. I have them on my rads
poah is offline
post #4 of 11 (permalink) Old 02-10-2020, 03:52 PM
Ha-Nocri's Avatar
Rep: 110 (Unique: 71)
75c junction temperature, that is impressive. Good job.
I'm curious tho, why didn't you decide to put an AIO on the GPU? You would get better results and my guess is it would be easier to install.
AMD
(12 items)
Ryzen r5 3600
MSI B450 Tomahawk MAX
Gigabyte 5700 XT Gaming OC (2070/940 MHz)
G-Skill TridentZ 16GB 3600MHz b-die (3800MHz CL16 1.375V)
Samsung 970 EVO Plus 1TB
Samsung 860 EVO 1TB
Seasonic Focus+ Gold 750W
Corsair H115i PLATINUM
Fractal Design Meshify C
ASUS MG279Q (1440p) + ASUS 22''
Mouse
Logitech G502
Audio
Kingston HyperX Cloud II
Ha-Nocri is offline
post #5 of 11 (permalink) Old 02-10-2020, 03:57 PM
9 Cans of Ravioli
The Pook's Avatar
more expensive and makes your rig look like a disaster for temp differences that are negligible.
that was my reasoning, at least.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Mouse
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #6 of 11 (permalink) Old 02-10-2020, 04:18 PM - Thread Starter
Amen.
Only air - all day long, it wouldn't be fun for me to not do this mods. Now it's like a hobby. :-)
post #7 of 11 (permalink) Old 02-10-2020, 04:59 PM
PC Evangelist
ZealotKi11er's Avatar
Rep: 1802 (Unique: 1176)
I am trying to do something similar. I separated the stock plate from the cooler and plan to install an AIO. I have to make some cuts to fir the AIO.
Yamato
(10 items)
Ishimura
AMD Ryzen 7 3700X
ASUS TUF Gaming X570-Plus (Wi-Fi)
AMD Radeon RX 5700 XT
G.SKILL Trident Z RGB (2x8GB) DDR4 3200MHz CL14
Samsung SM961 512GB
HGST DeskStar NAS 6TB
EVGA SuperNOVA 750 P2
Gamdias Chione M1A-280R
Fractal Design Meshify C TG
Operating System
Microsoft Windows 10 Pro 64 Bit
Intel Core i7-3770K @ 4.8GHz
ASRock Z77E-ITX
AMD Radeon Vega Frontier Edition
AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
SanDisk Ultra II 960GB
Toshiba X300 5TB
EVGA SuperNOVA 750 G3
Corsair H100i GTX
Fractal Design Define Nano S
Operating System
LG OLED55C7P
Keyboard
Cooler Master MasterKeys MK750
Mouse
Finalmouse Air58 Ninja
ZealotKi11er is offline
post #8 of 11 (permalink) Old 02-18-2020, 04:55 AM
Rep: 0
Hi Guys,
I bought a 5700 XT recently, the junction temperature is the thing that I'm concerned about. I hit 110*C quite quickly, while maintaining the GPU temp at about 60-65 on stock cooling. I replaced the thermal paste yesterday, nothing has changed. What temps did u have on stock cooling? Is there any way to lower the hot spot temperature by mounting the cooler in a certain manner?
1gordon1 is offline
post #9 of 11 (permalink) Old 02-18-2020, 05:30 AM
Ha-Nocri's Avatar
Which 5700 XT did you get? Reference or some AIB model?
AMD
(12 items)
Ryzen r5 3600
Samsung 860 EVO 1TB
Mouse
Logitech G502
Audio
Ha-Nocri is offline
post #10 of 11 (permalink) Old 02-18-2020, 05:53 AM
solon's Avatar
Rep: 0
the backplate at picss is from reference
Ryzen 7 3700X,Asus Crosshair VI Hero,16Gb G.Skill FlareX @3800C15,5700 XT Reference,Samsung970 Evo 250Gb,Seagate 2Tb,Enermax Galaxy 850,Custom Loop.
solon is offline
