Water cooling the ASUS 1080 Ti Turbo - Page 7 - Overclock.net - An Overclocking Community
post #61 of 70 (permalink) Old 09-21-2017, 04:47 AM
speedyMaldo's Avatar
Rep: 2 (Unique: 2)
Originally Posted by sl06bhytmar View Post
Alright have been running my Asus GTX 1080 Ti Turbo on water a while now and fixed mounting issues. Because ghetto setup, temps are not best but they're okay... GPU die max temp (2 hours PUBG 4K gaming): 57C, idle: 26C.
Block: Arctic Cooling Accelero Hybrid II block in Accelero Hybrid I shroud + stock memory / vrm cooling plate.
Pics: Warning: Spoiler! (Click to show)
I had to cut away one side + corners from bracket to make it fit with stock VRM & memory cooling plate
I would purchase a thermal thermometer and check your vrm and vram Temps, I was extremely unsatisfied with those. This gpu is easy to cool, it's the power delivery and memory modules that get really hot.
speedyMaldo is offline
post #62 of 70 (permalink) Old 09-21-2017, 04:49 AM
Rep: 2 (Unique: 2)
Originally Posted by Says Who View Post
Im about to build something like this build by Smicha, So question is if the blocks are thin enough for that. I know he dident use backplates on his last build to get them in.
Can you use Bitspowers block whitout backplate to gain some mm?
https://www.overclock.net/t/1598765/build-log-watercooled-7x-980ti-the-word-impossible-is-not-in-my-dictionary
You need the backplate to affix the block
post #63 of 70 (permalink) Old 09-21-2017, 05:08 AM
Rep: 0
There is a pretty good airflow on VRM thanks to shroud fan blowing directly on it.
Well my finger test tells me VRM area plate is about 60C and memory area 55C under load, so no big deal. (compare to 85C with stock cooler).
sl06bhytmar is offline
post #64 of 70 (permalink) Old 09-21-2017, 06:28 AM
Rep: 2 (Unique: 2)
I used a thermal thermometer and got as high as 84c during testing(gaming, not prime95 or furmark). I used the fan that came with the g12 bracket and it had lots of airflow going to it (3x noctua industrial ippc 3000rpm fans). So definitely take that for maybe my card just being hotter than most, but I would do more than a finger test on a 700 dollar graphics card
post #65 of 70 (permalink) Old 09-24-2017, 01:24 PM
Says Who's Avatar
Rep: 0
Got 4 of them now up and runnig, temps under 40c at full load. Wanted more Cards but with this block you cant use more than 4 Cards. But gues this will have to do for now. wink.gif
Says Who is offline
post #66 of 70 (permalink) Old 12-05-2017, 09:36 AM
fsinko's Avatar
Rep: 0
I did this same mod, and rather than raspberry heatsinks, I used thermal dissipators like gum. I however noticed that part of the stock cooler could be used, specifically the plate that hold the stock cooler. Since it's metallic, I think in conjunction with the thermal pads I put, could work better. Thoughts?? This is an image so you know what I'm talking about.
fsinko is offline
post #67 of 70 (permalink) Old 12-12-2017, 01:54 AM
Linux Lobbyist
mnemo_05's Avatar
Rep: 11 (Unique: 9)
looks like one can install an AIO in there without removing the mid-plate. the mid-plate looks decent, I would add some low profile heatsinks on it still just to increase the surface area.
mnemo_05 is offline
post #68 of 70 (permalink) Old 03-30-2018, 10:02 PM
Rep: 0
Wink I water cooled my GTX 1080ti Asus Turbo
Hey all, for those of you wondering if/how you can water cool an ASUS GTX 1080 ti Turbo... here is the guide I created for it. Just know this voids your warranty but the results you get from it are astonishing. After an hour of stress testing, I was still showing stable temps of 44 degrees Celsius. Overclocking here I come!
https://youtu.be/UtxCrzWP3SQ
I_Am_Evan is offline
post #69 of 70 (permalink) Old 04-05-2018, 02:13 AM
philuxbown's Avatar
Rep: 0
Cool
I have the 1080 ti turbo from asus as well and will not water cool it as I don’t want to void my 3 years warranty and because I get a lot of bangs for my bucks with this card...
I know it is running hot but if it breaks I will get a new one for free as if I start messing with it and it breaks it will be my fault...
philuxbown is offline
post #70 of 70 (permalink) Old 07-07-2019, 05:08 AM
Shehrevar's Avatar
Rep: 0
So I'm raising this thread from the dead as I am still rocking an ASUS GeForce® GTX 1080 TI 11GB Turbo, but it currently has a Raijintek Morpheus II Core Edition strapped on it. This cooling solution works rather well as it isn't even allowing my card to go over 60 degrees Celsius (used two Noctua NF-F12 iPPC 2000 PWM fans on it), but it's a freaking 3.75-slot monster because of it (strangely, very minimal GPU sag).
I'm planning to move into a smaller case and motherboard once I upgrade to Ryzen 3000 near the tail end of the year, but I'm keeping the GPU, so I've been looking for a water block for it. I've heard recently that Corsair dove into the custom water cooling scene, and I checked out their GPU block solution for the GTX 1080Ti cards...
https://www.corsair.com/ww/en/Catego...-compatibility
The site claims that it's compatible with the custom PCB of our special snowflake card.
Update: I can't seem to find it in any of my usual US-based online retailers. I guess you can only buy it from Corsair's store for now.
Shehrevar is offline
