Aftermarket cooling / Mod for the Asus Turbo - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 02-21-2018, 06:45 AM - Thread Starter
Ticonderoga's Avatar
Rep: 0
I just purchased the Asus GTX 1080 Turbo secondhand for a really good Price.
I did watch some youtube videos before buying the Card and decided I could put
up with the cooler considering the Price.
However after having the Card operate under full load yesterday, something needs
to be done to cut down the noise.
What options are there?
Most of the videos mention that the turbo Card isn't 100 % identical to the ref. Cards.
The DIY / AIO cooler solution is no good for me. I would have a hard time finding a spot to fit the radiator, not
to mention it would be costly since I have to buy both the bracket and the AIO Cooler.
I also thought about modding the original turbo cooler by removing the fan and the plastic shround but keeping the baseplate and heatsink. I would then add a bracket to the pci slot below the Card with 2 fans blowing onto the now exposed baseplate and heatsink, but I don't know if it would Work.
Any input / experiences would be appreciated.
Ticonderoga is offline
post #2 of 9 (permalink) Old 02-21-2018, 06:53 AM
alanthecelt's Avatar
Rep: 1 (Unique: 1)
start simple
pull the cooler and replace the TIM
add a cold air feed to the gpu with some decent case fans and go from there
And yer, as i recall i had a couple of these... and they were horrible sounding, perfect for custom looping up
Lian Li V3000
(10 items)
8700k
gigabyte z370 Gaming 5
RTX 2080TI
32Gb corsair 3200
Samsung 950 NVME 256GB
Samsung 850 1TB
EK XE480 and CE420 radiators Corsair ML fans
Lian Li V3000
Asus ROG PG34
Panasonic 55" 4k UHD TV
alanthecelt is offline
post #3 of 9 (permalink) Old 02-21-2018, 06:57 AM
BakerMan1971's Avatar
Rep: 105 (Unique: 78)
My old R9 290 Twin Frozr IV had a fan fail, I took off the shroud/fans and used those round 120mm fan grilles to allow me to mount 2 x 120mm high static pressure fans, dropped temps quite well
This page (from post 13) shows me modding my GPU https://www.overclock.net/forum/18083...-system-2.html
♦░▒█▓▒░♦MSI X99S Motherboard Owners Club♦░▒█▓▒░♦
X99 Cooltek W2 Build Log
Pew Pew Reactor
Z87 Corsair C70 Build Log
meet "Twisting Get"
BakerMan1971 is offline
post #4 of 9 (permalink) Old 02-21-2018, 08:23 AM
Overclocker in training
ThrashZone's Avatar
Rep: 62 (Unique: 48)
Hi,
Post the serial number of the card
Options would be a evga hybrid kit or a ek... water block bottom line.
Vaper
(4 items)
i9-9940x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Audio
Built in realtek with Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Samsung 970 Evo 500gb M.2 for os/ Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 9 (permalink) Old 02-22-2018, 01:46 AM - Thread Starter
Rep: 0
I didn't have time to play too much with the Card yesterday, but I did set up an side intake
fan which feeds the gpu fan directly.
The noise is ok now, but the Cards still reached 82 degrees C during benchmarks and starts to throttle.
#4
I will look up the serial no when I get back home today, but I really don't want to watercool.
I found this video on youtube (for a GTX 1060 Turbo) where he reuses the baseplate for vrm adn ram cooling and then adds the Dracula cooler for the gpu itself.
Unfortunately I cannot find this cooler where I live.
post #6 of 9 (permalink) Old 03-02-2018, 11:15 AM
ThrashZone's Avatar
Hi,
Yeah I wouldn't bother with a nickle water block either they are crap.
But the hybrids usually have copper plates not nickle plated so it might work.
Could be defective/ bad thermal paste and pads...
I do know the reference design "Single fan" is a total waste of money unless you put water on it some how sort of why I asked for the serial number to find it exact model number will work too link to it.
Vaper
(4 items)
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #7 of 9 (permalink) Old 03-06-2018, 09:33 PM
jura11's Avatar
Rep: 100 (Unique: 64)
Hi there
I would suggest get Raijintek Morpheus II cooler which is probably best air cooler for GPU
Add there two silent 120mm fans and you will be loving yours GPU and temperatures depending on ambient I would suspect you will be in low 40's or mid to high 50's with good OC as well
Hope this helps
Thanks, Jura
jura11 is offline
post #8 of 9 (permalink) Old 08-18-2018, 08:40 PM
NewType88's Avatar
Rep: 1 (Unique: 1)
I have a morpheus 2 on my OC 1070 turbo. I just have some noctua nf-s12a fans and temps during 100% load on fur mark didn't go above 60c at 1200 rpms, its a very quiet fan.. Granted those fans are not meant for heatsinks. So, get some fans with higher pressure, like the F12s and the temps will be even lower at the same rpms.
NewType88 is offline
post #9 of 9 (permalink) Old 08-20-2018, 04:45 AM
Kaplah!
Rep: 0
+1 for changing TIM dropped 10c doing that on my 1070
pwndirect is offline
