Had some conductonaut left over so I thought, what the heck. - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 08-28-2018, 07:54 PM - Thread Starter
AMD Fanboy Using Nvidia
vmatt1203's Avatar
Rep: 18 (Unique: 17)
After repasting my GF's XPS 15 and my Dell G7 with the liquid metal I had plenty left over so I thought what the heck might as well do my 1080 while I'm at it. The results are amazing. I just got done with a 2 hour gaming session of For Honor and holy crap. Fan curve only reached 40% and it never broke 66c and it stayed pegged at its 2011MHz overclock the whole time. At 100% fans it seems to hit a wall at 55c under sustained load. This stuff is amazing, and with new cards around the corner I don't mind the risk. My only worry is the shroud around the heat pipes on the card is aluminium and I worry it might overtime settle down onto the area but so far so good.
Just thought Id share!
vmatt1203 is offline
post #2 of 12 (permalink) Old 08-29-2018, 06:46 AM
8051's Avatar
Rep: 30 (Unique: 21)
I've read that in the long term liquid metal is a losing proposition because it reacts even w/copper and/or nickel.
8051 is offline
post #3 of 12 (permalink) Old 08-31-2018, 12:32 PM
Facepalm
Falkentyne's Avatar
Rep: 463 (Unique: 321)
Easiest thing to do is simple prep work which also lowers the risk of LM drying out and all of the Gallium being absorbed into the copper (exposure to oxygen increases the effect of gallium absorption until enough is absorbed that the battery differential effect becomes close to 0 (between the coppper-gallium alloy and the LM on the outside, which stops more absorption): But anyway:
1) Remove the existing LM.
2) wipe the heatsink of the old LM and make sure any HARDENED residue is removed, but leave the silver stain--this will help reduce rate of gallium absorption.
3) apply Super 33+ tape around the edges of the GPU in four strips. The tape is thin enough to cover the resistors fully, but make sure the GPU core is clear and raised above the edge of the tape. Make sure the tape coverage over the SMD parts is complete so LM cannot leak into the resistor area and short something out. This is important to do, because LM can also eat away at the soldering job and cause those little parts to fall off.
Alternatively, you can apply 3 coats of transparent nail polish (wait 5 minutes between each coat) on the SMD's around the GPU core as well. I'm not sure which method will help insulate against any tiny oxygen molecules getting in, but I would not apply BOTH tape and nail polish at the same time, because that will raise the surface area and may possibly interfere with heatsink pressure (a common problem when people do both tape and nail polish on laptop BGA CPU's, as the CPU core is only 2mm above the green housing, and just tape by itself can cover that distance).
Finally, to prevent any LM runoff (guaranteed to stop any from ever getting onto the PCB), find a VERY highly compressible foam packing material (the thickness has to be less than 4mm) and it has to be VERY VERY compressible, literally down to <1mm with your fingers with no resistance. Then cut a square out in the size of the GPU entire housing area, then cut out an inside "square" in the shape of the GPU itself, leaving about 2mm to spare so the foam won't touch the GPU. But do not apply it yet.
Then you should trim the foam with some very sharp scissors (something like Titanium scissors will work) by "slicing" it in half (if that makes sense), but that will be a very long process without tearing the foam. Once you slice it in half, there should now be a foam dam about 2mm thick. Then if you want to be perfectionist, try to trim it down "section by section" to about 1mm and no more than 1.5mm with the scissors (this will require surgical precision). Doing this will *greatly* reduce any foam resistance of downwards heatsink pressure on the GPU (these low pressure heatsinks need as much help as they can get), while even the extremely thin cut out foam barrier will completely block all liquid metal from going anywhere if it happens to escape.
Sounds like a lot of work but if you want your hardware to be safe, you need to do the prep work.
In the attached picture, the far right trimmed foam dam is decent for a GPU, as long as the final trimmed thickness is <2mm.
These foam dams are NOT to be used to protect the SMD resistors! They are only to trap LM from escaping onto the PCB. Do NOT use foam dams to be lazy and not use Super 33+ tape or Nail polish at all. Best insurance: Foam dams+Super 33+ tape, or Foam dams+transparent nail polish (3 coats).
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is online now
post #4 of 12 (permalink) Old 08-31-2018, 01:37 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1453 (Unique: 733)
You don't need to cover the SMDs with anything unless you put too much LM. Even if you do put too much ... unless you have a vertical mount GPU it's not going to go anywhere.
I put liquid metal on my 950 in 2015 and it's still doing just fine. Never bothered putting it on my 1060 because my 950 only dropped a few C.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #5 of 12 (permalink) Old 02-11-2020, 04:12 PM
NotStockClock's Avatar
Rep: 0
I love this guide.
I recently purchased a 2070 Super Ultra Xc and plan on re pasting with lm.
I like the extra step of protecting the pcb with the simple foam barrier.
In your opinion, would using .05 mm thermal pad, cut to fit, be a bad idea?
I would like to gain the protection and add a little bit of extra heat dissipation into the cooler while the card is open.
NotStockClock is offline
post #6 of 12 (permalink) Old 02-11-2020, 04:34 PM
9 Cans of Ravioli
The Pook's Avatar
Quote: Originally Posted by NotStockClock View Post
I love this guide.
use conformal coating.
https://www.amazon.com/MG-Chemicals-.../dp/B008O9YIV6
goes on like a liquid but dries into something that sort of resembles (dried) hot glue.
that's 3x the price it should be but it's what I use, just price shop or buy locally.
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
WD Blue 4TB SSD
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Keyboard
Mouse
Logitech G603
post #7 of 12 (permalink) Old 02-12-2020, 08:10 AM
Rep: 0
Awesome !!
Thank You !!
post #8 of 12 (permalink) Old 02-12-2020, 08:18 AM
Rep: 0
I just did a little research and found that this compound is great for waterproofing.
I own a drone repair shop, Personal Drone Repair.
I am going to look into drone waterproofing.
Thanks Again Man !
Great Find!!
post #9 of 12 (permalink) Old 02-12-2020, 08:32 AM
StAndrew's Avatar
Rep: 20 (Unique: 12)
You can "brush" coat the Cu with Nickle very easy. What you need:
-Nickle anodes x2 or cut in half https://www.amazon.com/Grobet-PLANOD...1525357&sr=8-5
-Old phone charger + alligator clips https://www.amazon.com/WGGE-WG-026-P...xpY2s9dHJ1ZQ==
-Nickle mix from online (expensive) https://www.amazon.com/Gold-Plating-...1525244&sr=8-4
or
-Vinegar
-Salt
-Cut the USB port off the old phone charger and wire the alligator clips to the positive and negative (use a multi-meter to know which is positive and which is negative; it'll be important later.
-Mix vinegar and some salt (about a tablespoon) and place the nickle anodes.
-Connect the alligator clips to the nickle anodes and let it sit until the vinegar becomes dark green. You should see bubbles forming on one of the anodes.
-Once the vinegar is dark green remove the anodes and connect the NEGATIVE clip to your heatsync; anywhere as long as its electrically connected to your copper base
-Wrap some cloth or heavy duty paper towel around the Positive anode and secure with a zip tie so that the cloth extends over the edge of the nickle anode about 1/4". This is your brush
***THE NEXT STEP WILL RELEASE A GAS AND SHOULD BE DONE IN A WELL VENTILATED ROOM OR OUTSIDE***
-With the positive anode still clamped on the nickle anode, dip the brush in the nickle solution and without letting the anode touch the Cu, brush the wet cloth/towel over the copper deliberately in a pattern without letting the cloth remain in one place for too long.
-If you see black marks form, no worries, you are just brushing too slow. Brush faster and those marks will eventually disappear
Depending on how green the vinegar solution is (greener = faster), you shouldn't have to brush more than 5-10 minutes.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #10 of 12 (permalink) Old 02-12-2020, 08:45 AM
StAndrew's Avatar
BTW, if you ever consider switching to the dark side, my 1080 ti watercooled + liquid metal never gets over 34*. With extra fan noise, I can keep it under 32* and clocks are stable up to 2126 until temps reach about 36*.
StAndrew is offline
