GTX 1080ti air, then water cooled - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 09-26-2018, 07:55 AM - Thread Starter
in da freezing hell
termathor's Avatar
Rep: 4 (Unique: 4)
Hy there,
So I think I'm settled for my rig's update:
- buy a new 1080ti air, use it for a while
- then build an open loop with GPU + GPÜ
Question: I understand waterblocks need to be adapted to the very layout of the components (VRMs, etc ...).
But, all you have to do, to convert to water, is remove the previous cooler, put TIM where relevant, and bolt the water block ? Am I right ? Can every 1080 see their cooler removed or only some ?
Sorry for potentially candid question, I'd prefer not throw 500 E to something that can't do the above plan
Marvin
(16 items)
Intel Core i5-4690K [email protected] GHz
ASUS Maximus VII Impact mini-itx
Asus GeForce GTX 970 DirectCU Mini
Trident X, 2 X 8 Go, 2400 MHz, CAS 10
Samsung 850 EVO SSD, 512GB
Seagate Desktop SSHD, 2TB
Corsair HX850i
Corsair H90
Thermaltake Core V1
Operating System
W7
Operating System
SteamOS
Big Samsung TV screen, sofa operated
Keyboard
Logitech K810
Mouse
Logitech G602
Audio
Bose Soundtouch 1300
Other
Steam Controler
termathor is offline
post #2 of 2 (permalink) Old 09-26-2018, 08:22 AM
Totally Tubular
MNMadman's Avatar
Rep: 50 (Unique: 41)
Your best bet is to buy a 1080 Ti that uses the reference design. That will have compatibility to the most GPU blocks. Otherwise, you will be limited to specific blocks that are designed specifically for that model of graphics card.
And yes, it is as easy as removing the air cooler and screwing on the new water block. You'll have to have thermal paste for the GPU itself (some blocks come with paste but some don't), but the kit will also include thermal pads for the GPU's RAM and VRM. Typically, a first-timer will take about an hour to convert the GPU from air to water.
I highly recommend Watercool's Heatkiller IV GPU blocks and backplates. They have great aesthetics and cool extremely well. Plus, their backplates actually help to cool the GPU and VRM areas on the back side.
Previous Project: Heatripper Threadkiller Build Log
Previous Project: TT-Green Build Log (external link)
Previous Project: RED Glare Build Log (external link)
AMD Ryzen R7 2700X (1826SUS)
ASUS ROG Crosshair VII Hero (Wi-Fi)
NVIDIA TITAN Xp COLLECTORS EDITION (Jedi Order)
G.Skill Trident Z F4-3200C14D-16GTZRX
Samsung 960 Pro 2TB NVMe
Corsair HX1000i 1000W ATX
EKWB EK-Supremacy EVO AMD RGB Nickel-Plexi
Watercool Heatkiller IV for TITAN X and GTX 1080Ti - ACRYL Ni-Bl w/ eBC Backplate
Watercool WCP D5-VARIO Pump with Heatkiller D5-TOP
Watercool Heatkiller Tube 150 w/ MultiPort Top
Watercool MO-RA3 360 LT Radiator - White
Barrow G1/4" Thread 3/8" ID 5/8" OD Compression Fitting - Black
Koolance QD3 Quick Disconnect No-Spill Coupling w/ 10mm x 16mm Compression Fitting - Black
PrimoChill PrimoFlex Advanced LRT 10/16mm Tubing - Crystal Clear
Mayhems Pastel Coolant - Yellow
Be Quiet Silent Wings 3 120mm PWM High Speed Fans (9)
PrimoChill Praxis WetBench - White/Black
Operating System
Windows 10 Pro 1803 64-bit
Acer XB270HU bprz 1440p 144Hz G-Sync Gaming Monitor
Keyboard
Logitech G Pro RGB USB
Mouse
Mousepad
Logitech G440 Hard Gaming Mouse Mat
Audio
Logitech G633 7.1 RGB USB Headset
MNMadman is offline
