980ti memory or vrm overheating - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 11-27-2018, 01:48 AM - Thread Starter
Sugita2Junko's Avatar
Rep: 2 (Unique: 2)
EVGA 980ti rebooting from overheated VRM or Memory. Fixable?
I use a Raijintek morpheus cooler on my EVGA 980ti (06G-P4-4995-KR) for the past 3 years. GPU core temp was always 50-55c while gaming, pretty cool, but recently it started hard rebooting suddenly. Discovered after troubleshooting for a long time the VRM or memory is overheating.
The 980ti doesn't have VRM temperature monitor so I placed a thermal probe on top of the GPU plate, right above one of the VRM or memory chips. Idles around 25-30c, but around 50c it would reboot, usually takes 2-3hrs of gaming, pretty sure the chip underneath is actually hotter than that. Read VRM often are rated at 100-120c. Not sure about memory.
If I limit GPU power to 60% using msi afterburner the probe temp will be around 42c, it won't reboot, could play all day. However, my 980ti performance has been reduced to that of a 970 or worse.
Has my GPU degraded beyond hope or repair? What are my options? Will replacing the thermal pad in between the plates help?
Sugita2Junko is offline
post #2 of 23 (permalink) Old 11-27-2018, 02:45 AM
AMD OC'ing Enthusiast
mattliston's Avatar
Rep: 107 (Unique: 85)
dont use power limit to reduce vrm temps. That simply makes the card struggle to stay stable even more flipping back and forth with voltages and frequencies.
Use Afterburner to reduce clocks and voltage directly.
Id say a good negative 300mhz core offset with a big chunk of voltage reduction would be better than lowering the power limit. If it was a VRM temperature issue, it will "solve" the issue right then and there.
This does not rule out a component failure though, simply a temperature issue.
mattliston is offline
post #3 of 23 (permalink) Old 11-27-2018, 03:41 AM
Desolutional's Avatar
Rep: 165 (Unique: 101)
Have you tried running Furmark on it yet? Let that run for a few hours, it will max out the power target, might help you crash earlier than 2-3 hours.
CPU: i7-6950X @ 4.1Ghz (-0.08V/1.30V Adaptive = 1.22V); Cache: 3.2GHz (1.07V); VCCIN: 1.90V @ LLC 5 12hr AVX2 Stable
RAM: 64GB @ 3000MHz (14-14-12-31 1T, 1.35V) 12hr GSAT Stable
GPU: EVGA Hybrid GTX 1070 @ 2076MHz Core, 8.6GHz VRAM, Stock Voltage 24hr [email protected] Stable
Desolutional is offline
post #4 of 23 (permalink) Old 11-27-2018, 12:25 PM - Thread Starter
Rep: 2 (Unique: 2)
Max I can lower for core clock is -90 and memory clock -201. Core voltage the slider is at the min, seems I can only add voltage.
What component failure as in PSU or Mobo? I've replaced the PSU thinking it was at fault but turns out didn't fix it.
post #5 of 23 (permalink) Old 11-27-2018, 12:27 PM - Thread Starter
Rep: 2 (Unique: 2)
Furmark last about 5 seconds if it has already rebooted prior and still hot.
From normal/cold state it would die around 15-20m
post #6 of 23 (permalink) Old 11-27-2018, 12:36 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1332 (Unique: 704)
Don't use Furmark and stop suggesting people use it. It serves 0 purpose and most cards will cripple themselves to a lower P state if it detects it's running. Just run a benchmark if you want to test things out.
@Sugita2Junko : Where did you put the temp probe on? You said the "VRM" but the VRM consists of chokes/coils/inductors/capacitors/MOSFETs/voltage regulators and not all of them really put out that much heat or need a heatsink. The only one that should have one are the mosfets.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #7 of 23 (permalink) Old 11-27-2018, 12:42 PM - Thread Starter
Rep: 2 (Unique: 2)
http://images.hardwarecanucks.com/im...X-980-TI-1.PNG
It has a back & front plate covering. I just put the probe on the front plate which I felt was hottest, so hot I can't leave my finger for more than a sec. In between the expose mosfet (square things?) & gpu core.
post #8 of 23 (permalink) Old 11-27-2018, 12:50 PM
9 Cans of Ravioli
The Pook's Avatar
The bigger gray square "things" in that picture are chokes and they don't need a heatsink.
The partly melted thing in this picture is a mosfet and what you should be checking the temps of. If it doesn't have a heatsink, stop using the card until you get some on it.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Operating System
MX Linux
Keyboard
Mouse
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #9 of 23 (permalink) Old 11-27-2018, 01:07 PM - Thread Starter
Rep: 2 (Unique: 2)
https://i.imgur.com/GmS9JK7.jpg
These are the areas too hot to touch for me. I circled it green. I only touched the plate. Probe location is in between there in red circle.
https://www.fudzilla.com/images/stor...ti_sc_pcb1.jpg
Those square chips surrounding the GPU core are VRAM?
https://qph.fs.quoracdn.net/main-qim...838524ae8118-c
The VRM when I touched it was scorching hot too. Didn't put a probe on it to know how hot.
post #10 of 23 (permalink) Old 11-27-2018, 01:39 PM
8051's Avatar
Rep: 30 (Unique: 21)
The green areas look like where the VRAM is located.
What kind of fan do you have blowing down on the VRM side of the card? You might want to consider putting a more powerful shrouded fan over that location.
8051 is offline
