Hybrid cooing a 1080 Ti with pump off? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 12-14-2018, 07:11 AM - Thread Starter
Rep: 0
I have a plan to watercool a Zotac 1080 Ti Mini with a "DIY" hybrid cooling, similar to NZXT G12 Kraken - I have a Swiftech H220-X available.
Right now my computer is really silent when idle / light use - and that is most of the time - all the chassis fans stop, graphic card has bios changed so it has zero fan mode. I would like to water cool a graphic card because Zotac 1080 Ti Mini has really quite crappy cooler, it is loud when gaming and it still throttles due to heat. But I'm not too excited to listen to pump chugging all day long when it doesn't even need to - but Swiftech H220-X doesn't really support powering off the pump via PWM signal - if there is no signal, the pump is at 100%, PWM controls it in 1200 ~ 3000 RPM range. It is very quiet at minimum pump speed, but still audible in my quiet room and extremely quiet computer.
Is it really a bad idea to wire a switch to pump leads and simply keep it off when not gaming?
- I can imagine constantly powering it on and off isn't good for the pump, but I will keep this to a minimum.
- Can the switched off AIO keep the idle 1080 Ti cool enough? There will still be a 92mm fan, wired to GPU and controlled via Afterburner curve for cooling VRM and memory modules.
- I imagine accidentally forgetting to switch the pump on and starting a game or a benchmark could potentially destroy the graphics card by overheating it very quickly.
What do you say? Anyone has any experience with this?
Bwaze is offline
post #2 of 5 (permalink) Old 12-14-2018, 07:14 AM
Overclocker in training
ThrashZone's Avatar
Rep: 65 (Unique: 51)
Hi,
Like most AIO's it's best to wait for them to die of natural causes
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 5 (permalink) Old 12-14-2018, 07:22 AM - Thread Starter
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
Yeah, I replaced the AIO as a CPU cooler (to air cooling) after two years because there were so many reports of them dying and taking most of the computer with them in some cases...
But I have a good backup strategy now.
Bwaze is offline
post #4 of 5 (permalink) Old 12-14-2018, 07:29 AM
ThrashZone's Avatar
Hi,
Yep not pretty when an aio pump fails I've been there on my x99/ 5930k
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 5 (permalink) Old 12-14-2018, 08:44 AM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
Watercooling aren't designed to work with the pump off, the GPU will overheat even at IDLE. Just keep at 1200RPM
I7 8700K@4.7Ghz / Z370-A / 2X8GB 3200Mhz ADATA Spectrix D40 / 1TB Intel 600P / EVO 850 250GB / 4TB WD Gold / RTX 2080 GAMING OC / NZXT Noctis 450 ROG / EVGA G2 850W@ECO
Heatkiller REV 3.0 / XSPC EX360 / DDC 3.25 + EK-XRES / 3x Venturi HF-12 PWM
lexer is offline
