EVGA copper waterblock not fully contacting EVGA RTX 2080? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-13-2019, 08:24 AM - Thread Starter
zetswei's Avatar
Rep: 0
Hey guys,
I bought 400-HC-1189-B1 waterblock for my 08G-P4-2182-KR GPU but it seems like the waterblock isn't making fully contact with the GPU chip. Is this normal? I've checked to make sure nothing is blocking the plate but it's just simply not making contact unless I put on excessive amounts of paste.
The card + my CPU seem to be running high temps on 2 360 radiators.
I'm hitting 70C-75C under heavy load/stress testing with 5 GHz 9700k @ 1.265v and my 2080 having a +75 core and +700 memory overclock with +30% power slider.
The temps don't change a whole lot whether fans are up to 100% or at 50%.
This is my first custom loop so maybe this is normal? Just feels like the temps aren't as low as I was expecting.
Zetswei - The Supposed German Guy That Seem German But Probably Is Not
zetswei is offline
post #2 of 4 (permalink) Old 03-22-2019, 11:44 AM
Zfast4y0u's Avatar
Rep: 1 (Unique: 1)
flow rate is important too, its not same having pump running at 20% and 100% for example, temp differences can be as high as 10-20c
regarding bad contact, did u put correct thermal pad thickness in correct spots on gpu? btw, you complain about bad contact on gpu and high temps, and then give us cpu temps :/
Zfast4y0u is offline
post #3 of 4 (permalink) Old 03-22-2019, 12:27 PM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Only time I've had bad contact was because I used the wrong screws
EK sends long a short screws and I used the long and they were bottoming out on the plexi holes
Used short ones and boom much better just didn't think they were long enough
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #4 of 4 (permalink) Old 04-29-2019, 07:18 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Those temps aren’t right...I have the basically the same EVGA card and same waterblock, but I took it apart for air testing before running it with the waterblock, since I got it used. It had good contact with the GPU die when I took it apart and with the stock air cooler I never saw 70C ever, even over clocked. I assume you installed the bracket around the GPU and used the 4 screws without the springs from the stock air cooler right? Those are about the only different screws used from the stock air cooler that I saw.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
