GPU 4 pin fan to PWM CPU Adapter - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 08-10-2019, 04:06 AM - Thread Starter
Rep: 0
GPU in question: Asus GeForce GTX 780 Ti DirectCU II OC (GTX780TI-DC2OC-3GD5)
I had an issue with the fans so I decided to upgrade to Accelero Xtreme IV. Turns out it comes with a 4 pin fan connector whereas the GPU has only a 5 pin socket. I plugged it in either way but it seems like I'm unable to monitor the fan speed or change it in any way (fan speed does not show up on HWMonitor/Asus GPU Tweak).
Couldn't find much googling. But I did think of perhaps getting an adapter to a CPU PWM socket.
Accelero fan pin looks like this: https://i.imgur.com/NcZzlYX.png
Adapter: https://www.dazmode.com/store/shop/c...-for-gpu-50cm/
Will it be able to not only power up the fans but also show stats for the fans?
pinpin25 is offline
