Originally Posted by DuckieHo
The Mushkin Io is better... it is a Barefoot + Samsung 40nm NAND... just like the OCZ Vertex.
The RiDATA uses the slower JMicron JMF212 controller.
They both support TRIM.
jesus christ how did you figure that out, I couldn't find a single website showing which controller it used. If you google jmf212, you don't even get anything. You mean the 612?
-Asus P6t Deluxe OC palm
-I7 920 @ 3.6 ghz
-12 gb OCZ platinum 1600 c 7
-evga gtx 275 superclocked
-160 gb wd velociraptor
-500 gb wd black
-1 tb wd black
-psu corsair 850 w
-noctua cpu cooler
-cooler master haf full tower
as i know, there is a marvel yukon controller on this board. does this help or matter?
for a SSD first time user, do i have to know that SSD should be configured as AHCI? do i have to install it with F6 while installing windows or win7?
I saw on mushkin IO the stated a vibration resistance, how come? it's not mechanical, so why vibration?
Should I put the Callisto in considaration also with sandforce controller?
thanks you DuckieHo for your reply, plz consider the following msg:
If this help, my system is :
-I7 920 @ 3.6 ghz
-500 gb wd black
-1 tb wd black
-psu corsair 850 w
-noctua cpu cooler
1-as i know, there is a marvel yukon controller on this board. does this help or matter?
2-for a SSD first time user, do i have to know that SSD should be configured as AHCI? do i have to install it with F6 while installing windows or win7?
3-I saw on mushkin IO the stated a vibration resistance, how come? it's not mechanical, so why vibration?
1) Use the ICH10R controller, it's MUUUUUUUCH better.
2) Run the controller in either RAID or ACHI mode. Windows 7 already has the drivers integrated..
3) All SSDs have a high resistence to vibrations due to being solid-state devices. They won't break if you shake them in use.
1- how can i choose? all what i know, that i can disable marvell in bios and keep hdd as it's auto setup, is it right, or any way to choose btw ichr10 and other?
2-since i have 1 ssd, i cant run raid, so i will install it as ahci during installing win7? is it right?
thank you again for your help and fast reply, much appreciated and helping
Don't question the Duckie...he was born with this knowledge
It's in the BIOS. There is an option called SATA Mode and set it to AHCI.
This has nothing to do with the seperate Marvell controller (which might also have a SATA Mode option.)
thank you, will order the callisto and try it, hope it will not disappoint me
Related Threads
Ask a question
Ask a question
Overclock.net
27.8M posts
541.5K members
Since 2004
