GPU upgrade from 6850? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 06-04-2012, 11:21 PM - Thread Starter
Arv3n Level 1
Arv3n's Avatar
Hello all,
I want to upgrade from a 6850 so I can play Battlefield 3 better. What should I upgrade to? My PSU only has 2 PCIE connectors and the 2 it has are already used on my 6850. Budget is $350.
System is:
Corsair 650D (I just bought it and love it!!)
Asus M5A99X Evo
8GB Corsair Vengeance 1600mhz
XFX 6850 DD
Phenom II X4 975 OC'd to 3.9ghz
Seasonic 620W modular psu
Arv3n is offline
post #2 of 16 (permalink) Old 06-04-2012, 11:34 PM
raghu78 has a spectacular aura about raghu78 has a spectacular aura about raghu78 has a spectacular aura about raghu78 has a spectacular aura about raghu78 has a spectacular aura about raghu78 has a spectacular aura about raghu78 has a spectacular aura about raghu78 has a spectacular aura about
raghu78's Avatar
Originally Posted by Arv3n View Post
Hello all,
System is:
Asus M5A99X Evo
XFX 6850 DD
what resolution is your monitor ?
raghu78 is offline
post #3 of 16 (permalink) Old 06-04-2012, 11:40 PM - Thread Starter
Arv3n Level 1
Arv3n's Avatar
1080P.
Arv3n is offline
post #4 of 16 (permalink) Old 06-04-2012, 11:42 PM
Linux Lobbyist
ITS OVER 9000! is an unknown quantity at this point ITS OVER 9000! is an unknown quantity at this point
ITS OVER 9000!'s Avatar
I would get a 7850. Or I would crank that budget a little more and get a 7950-670
ITS OVER 9000! is offline
post #5 of 16 (permalink) Old 06-04-2012, 11:43 PM - Thread Starter
Arv3n Level 1
Arv3n's Avatar
Why not a 7870?
Arv3n is offline
post #6 of 16 (permalink) Old 06-05-2012, 12:01 AM
Ironman517 is on a distinguished road Ironman517 is on a distinguished road Ironman517 is on a distinguished road Ironman517 is on a distinguished road Ironman517 is on a distinguished road
Ironman517's Avatar
A 670 is one of the best cards to get for BF3. BF3 favors nvidia more when it comes to min-fps. And min fps is really the FPS that matters, max does not matter in gameplay. But having a high min fps will result in less noticable FPS lag.
For example:
GPU 1:
Max: 70 FPS
Average: 50 FPS
Min: 30 FPS
GPU 2:
Max: 55 FPS
Average: 50 FPS
Min: 45 FPS
Both GPUs have the same average but GPU 1 has more varying FPS results. You are more likely to notice FPS lag from GPU1 over GPU2 since in GPU2 the min FPS is so close to the max. The numbers I used are rather dramatic, but it was to prove a point. thumb.gif
Software Engineer in Satellite CommunicationsFaceepalm Quotes (Click to show)
Office + 3 monitors = more than 8gb.
A PC from 2000 can play Crysis at 20FPS. Playable.
how come i get 30 more fps with 16 gb than 8gb?
Your motherboard burst into flames.
No, you cannot use it.
Clubs/Validations (Click to show)
Ironman517 is offline
post #7 of 16 (permalink) Old 06-05-2012, 02:25 AM
raghu78's Avatar
Why not a 7870?
spend a little bit more. get the sapphire HD 7950 950 Mhz edition . amazon price USD 390.
http://www.amazon.com/Sapphire-PCI-Express-version-Graphics-11196-10-40G/dp/B0082D58P4/ref=sr_1_23?s=electronics&ie=UTF8&qid=1338884367&sr=1-23
card uses ref HD 7970 PCB. 8 pin + 6 pin power. clock for clock HD 7950 is close to HD 7970 perf. a user has posted the card's pics , overclocks etc .
http://hardforum.com/showthread.php?t=1695577
https://www.overclock.net/t/1196856/official-amd-radeon-hd-7950-7970-owners-thread/11260#post_17357026
the user hit 1200 Mhz at stock volts. even if you don't get as good a card 1200 Mhz is achievable with sapphire trixx and bit of voltage tweaking.
A HD 7870 at 1200+ Mhz will be slower by atleast 25 - 30% to the HD 7950 at 1200 Mhz. HD 7950 (1200) will trade blows against a GTX 670 (1300) thumb.gif
raghu78 is offline
post #8 of 16 (permalink) Old 06-05-2012, 02:27 AM
Swift Castiel Level 1
Swift Castiel's Avatar
670 for sure if you can manage to sell your current card. It's not that it's bad, but the 670 hits the price/performance sweet spot in the States at the moment. If you want to stay AMD, a 7850 to a 7950 would be fine. Personally I wouldn't bother with the 7870, since (from what I noticed on spec sheets), it's just clocked a bit faster (I'm probably wrong about that though).
Swift Castiel is offline
post #9 of 16 (permalink) Old 06-05-2012, 02:40 AM
FromUndaChz Level 1
7870 is in your price range and is a great card.
7950 is a beast if you OC it... but I think the GTX 670 is a better value if you jump to the $400 range.
FromUndaChz is offline
post #10 of 16 (permalink) Old 06-05-2012, 02:59 AM
d6bmg Level 1
Get a 7850 or 7870.
If you can increase your budget to ~$400, GTX670 would be the best choice.
My Knowledge is My Weapon
1. BitFenix Recon Review:: 1. Forum Link 2. Review Page Link
Recommended Power Supplies
d6bmg is offline
