RX 590 or GTX 980? - Page 2 - Overclock.net - An Overclocking Community
RX 590 or GTX 980?
post #11 of 15 (permalink) Old 01-20-2019, 04:30 PM
crazycrave's Avatar
Rep: 4 (Unique: 4)
I heard that a card like the Red Dragon RX570 8Gb is the same RX580 2048 Stream Processors card with just higher clocks as i got one on Black Friday for $149 with 2 Free Games = $50 video card brand new with 8Gb of memory and should run near RX 580 if you overclock it .
Xeon X5660 @4.2Ghz
EVGA x58 3way Sli rev 1.2 bios 83
OCZ Gold ram 6 Gb
Corsair 950 watt powersupply
Sapphire R9-280
crazycrave is offline
post #12 of 15 (permalink) Old 01-21-2019, 10:29 PM
MegaTechPC
Majin SSJ Eric's Avatar
Rep: 1089 (Unique: 517)
The 590 seems to simply get scoffed at as just another AMD rebrand, but from what I've seen it actually is far and away the best performance-per-dollar card you can buy right now, at least new. But as was mentioned above, if used cards are an option I would heavily consider a refurb or used 980Ti as that is still one heckuva card and can be had for as little as $220 or so.
3DMark11 - P25138
3DMark Firestrike - P20998
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
Majin SSJ Eric is offline
post #13 of 15 (permalink) Old 01-30-2019, 11:43 AM
Rep: 0
If I have to choose between them I will go with RX590. Also you can get GTX1060 in your budget.
Bradleym is offline
post #14 of 15 (permalink) Old 02-09-2019, 09:32 PM
crazycrave's Avatar
Rep: 4 (Unique: 4)
A few more drivers and Hawaii should over take the 980 GTX http://www.3dmark.com/fs/17964596 as yet another victim to GCN .
Xeon X5660 @4.2Ghz
OCZ Gold ram 6 Gb
Sapphire R9-280
post #15 of 15 (permalink) Old 02-09-2019, 09:39 PM
Quesoblanco's Avatar
Rep: 196 (Unique: 159)
I would wait the 1660 ti comes out in a week or 2.
Quesoblanco is offline
