Caps fell off 1080 Ti - how do I fix? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 02-11-2019, 11:21 AM
mouacyk's Avatar
Rep: 160 (Unique: 120)
Not have the GF handle any computer hardware in future
CPU: Q6600 X5470 2100T 1680V2 9900K 5950HQ
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is online now
post #12 of 14 (permalink) Old 02-11-2019, 12:20 PM
acquacow's Avatar
Rep: 2 (Unique: 2)
Those types of caps are super fragile and fall of easily when bumped, even without heat.
I usually just use a hairdryer and heat the board up to a too-hot-to-touch temp and then get on them with a soldering iron.
They aren't too hard to put back on if you have a sharp tip iron.
If you don't pre-heat the board, you won't have any luck putting them back on.
I'd re-tin the pads with clean solder and flux, then have at it.
HOW-TO:
-- Dave
acquacow is offline
post #13 of 14 (permalink) Old 02-11-2019, 01:48 PM
Kaltenbrunner's Avatar
Rep: 15 (Unique: 15)
Modern Lead-free solder gets brittle over time. It also needs a lot more heat to melt than Leaded solder. She would have burned herself on the card if the lamp was hot enough to melt the solder. I'd say it was just brittle and broke, (IDK why...I'm not going to blame anyone)
Kaltenbrunner is offline
post #14 of 14 (permalink) Old 02-11-2019, 03:07 PM
white owl's Avatar
Rep: 123 (Unique: 94)
Glad you got it fixed. No telling if it would have worked without it or not. Better to have it and not need it etc
I take it you won't be posting pix of the job? =(
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
