How to remove old, hard thermal compound from GPU die - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 02-18-2019, 03:55 PM
AMD OC'ing Enthusiast
mattliston's Avatar
Rep: 104 (Unique: 82)
Hardened, dried thermal paste comes off very easily if you let it soak with rubbing alcohol.
take a few q-tips, dunk them in the rubbing alcohol, and roll over the dried paste. Just cover the paste continually until it falls off nearly.
It takes less than 5 minutes.
mattliston is offline
post #12 of 16 (permalink) Old 02-18-2019, 04:07 PM - Thread Starter
johnvosh's Avatar
Rep: 4 (Unique: 4)
Thanks everyone for the suggestions. I was able to get the old thermal pad removed from the die by soaking paper towel in isopropyl alcohol and let it sit on it for 5 minutes, then used a plastic putty knife and a q-tip. Then used a razor blade to remove it from the heatsink.
Is there a way to check die temps on these older cards? I tried using HWinfo32 but it doesn't tell me the temp.
The card is a ATI Radeon 9700 128MB AGP video card.
Haswell
(17 items)
Intel Core i5 4670K
MSI Z87-GD65 Gaming
Gigabyte Geforce RTX 2060 Gaming OC 6GB
Patriot Viper 3 Series, Black Mamba Edition
Intel 520 Series, 240GB
Western Digital Green 1 TB
Optical Drive
LG Blu-Ray burner
Corsair HX650
Cooler Master Hyper 212 Evo
NZXT Full Tower, White
Operating System
Windows 7 Professional
BenQ G2420HD
Acer S230HL
Acer GN246HL
Keyboard
Logitech K350
Mouse
Logitech M510
Mousepad
Generic Blue mousepad
johnvosh is offline
post #13 of 16 (permalink) Old 02-18-2019, 05:00 PM
Graphics Junkie
UltraMega's Avatar
Rep: 35 (Unique: 31)
damn AGP... so old. GPUz might work. If not, probably nothing will.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #14 of 16 (permalink) Old 02-18-2019, 05:21 PM
8051's Avatar
Rep: 25 (Unique: 19)
Would brake cleaner or throttle body cleaner cause any problems if applied to a q-tip and used to clean off the dried TIM?
8051 is offline
post #15 of 16 (permalink) Old 02-18-2019, 06:38 PM
Graphics Junkie
UltraMega's Avatar
Why wouldnt you just use cleaning alcohol?
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
post #16 of 16 (permalink) Old 02-19-2019, 09:19 AM
mattliston's Avatar
brake cleaner and throttlebody cleaner are not only much more expensive in relation to rubbing alcohol (which is like $1 at walmart), but far more corrosive to plastics and adhesives.
You run the risk of damaging other components, and even the PCB itself.
The most aggressive I would get is electronics cleaner, such as what partsstores offer for cleaning alternators and starters. They generally specify safety for rubber and plastics.
Still, rubbing alcohol is the safest, you could even dump a bottle over an operating computer, and be safe.
Then, something simple like a duster air can, or TIME, to get stuff dried out!
