How to remove old, hard thermal compound from GPU die - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 02-18-2019, 06:25 AM - Thread Starter
johnvosh's Avatar
Rep: 4 (Unique: 4)
I am starting to replacing the thermal compound on all of my old computers and video cards. How do I go about removing this old, hard thermal pad from this GPU die without causing damage? I tried using 99% Isopropyl and a q-tip and it does nothing. the heatsink, I am just going to use a toothbrush, a small flat blade screwdriver, and the Isopropyl.
And let's see if anyone can guess what GPU this is!
Haswell
(17 items)
Intel Core i5 4670K
MSI Z87-GD65 Gaming
Gigabyte Geforce RTX 2060 Gaming OC 6GB
Patriot Viper 3 Series, Black Mamba Edition
Intel 520 Series, 240GB
Western Digital Green 1 TB
Optical Drive
LG Blu-Ray burner
Corsair HX650
Cooler Master Hyper 212 Evo
NZXT Full Tower, White
Operating System
Windows 7 Professional
BenQ G2420HD
Acer S230HL
Acer GN246HL
Keyboard
Logitech K350
Mouse
Logitech M510
Mousepad
Generic Blue mousepad
johnvosh is offline
post #2 of 16 (permalink) Old 02-18-2019, 06:32 AM
mmonnin's Avatar
Rep: 283 (Unique: 135)
A blade from a utility knife. Not with the knife but by hand. A screw driver is too narrow and one edge will dig in/scratch.
mmonnin is offline
post #3 of 16 (permalink) Old 02-18-2019, 06:32 AM
The last VRM burner
Rep: 34 (Unique: 19)
Soak paper towel with alcohol and scrape hard till it's gone.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 16 (permalink) Old 02-18-2019, 06:35 AM
Overclocked
scracy's Avatar
Rep: 116 (Unique: 83)
+1
ROG Maximus X Formula, Intel Core [email protected]/4.8Ghz Cache 1.344V (OCCT Load) (OCCT Stable), Corsair Dominator Platinum ROG Edition [email protected], EVGA GTX1070 SLI, Samsung 960 Pro x2 (Raid 0) (O/S), Samsung 850 Pro x4 (Raid 0) (Data)
ROG THOR 850W PSU, EK Custom Loop 2x PE-360 Radiators, Corsair ML120 Pro Fans, Phanteks Evolv X, Creative Soundblaster Z, Woo Audio WA7D, Sennheiser HD660S, ROG PG279Q 2560x1440 165Hz IPS Monitor, Windows 10 Pro Build 1809.
scracy is offline
post #5 of 16 (permalink) Old 02-18-2019, 06:59 AM
Not a linux lobbyist
rluker5's Avatar
Rep: 48 (Unique: 36)
I used some of this stuff from my garage to get some Chinese qc stickers off of the back of a couple of cpus: https://www.amazon.com/Goof-FG661-Pr...words=goof+off
If you are careful where it goes and wipe up the residue with ipa you should be fine. I was scrubbing that stuff on the little resistors and stuff on the middle underside of 2 cpus and it didn't melt anything it wasn't supposed to, but you can keep it to the gpu dies if you want to be as safe as possible. Using a hard screwdriver might scratch and very slightly reduce cooling performance if the scratch has an accompanying ridge.
And I've been a slob with isopropyl alcohol on my dies for years now and it hasn't hurt anything. I wouldn't worry about ipa touching nearly anything on a pcb if it were dry by the time I powered that pcb up.
L5
(17 items)
Lea2
(11 items)
L7
(11 items)
5775c
Maximus VII Hero
Aorus 1080ti Waterforce
16 Gb Gskill Trident @ 2400,cas10,1.575v
8 Gb Gskill Trident @ 2400,cas10,1.575v
1Tb Team ssd
seagate barracuda 3T
Optane 900p 480G OS
Optical Drive
Asus BW-16D1HT
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design R4 (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear, Nova 40, 598se, HE4xx, DT990pro w b.boost earpads
Audio
SoundbasterX AE-5, onboard
4770k
Asus Z87 Deluxe
Fury Nitro
8Gb klevv urbane 2133
ROG Raidr 240Gb pcie
1Tb WD blue
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
DIYPC P48-W
Operating System
W10 64 pro
40"tv
4980hq
Asus H81T/CSM
8Gb 1600 samsung
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
24" samsung 1080p
Keyboard
Logitech K400+
Other
Intel wifi ac card and noname antennas
rluker5 is offline
post #6 of 16 (permalink) Old 02-18-2019, 08:09 AM
Not New to Overclock.net
iSpark's Avatar
Rep: 9 (Unique: 9)
3D Rage Pro?
Soak compound with alcohol, use razor from something like a paint scraper and gently scrape away.
iSpark is offline
post #7 of 16 (permalink) Old 02-18-2019, 08:15 AM
rancor's Avatar
Rep: 102 (Unique: 93)
Plastic razor blades on the die or an old credit card. Use a paper towel to help soak the die in isopropyl. Mineral oil also may help loosen the thermal interface material but its a pain to clean up. Try it on the heat sink before the card to see if it even helps.
i7-4770K Overclock
Blue
(18 items)
Intel Core i7-4770K (4.4GHz 1.35V)
Gigabyte Z87X-UD4H-CF
XFX Radeon RX VEGA 64
16GB G.Skill Trident X 2400MHz 10-12-12-31
Samsung EVO 840 500GB
Corsair HX1050W
EK Supreme HF + mpc355 + 2 x Xspc RX360 + EK-FC Radeon Vega
Corsair 700D with Side Window
Operating System
Windows 10 Pro
Nixeus EDG 27
ASUS MG279Q
ASUS MG279Q
Keyboard
Xarmor U9BL-S
Mouse
Steelseries QcK+
Mouse
Roccat Pure Owl-Eye
Audio
Swan M50W
Audio
Odac+O2 & Sennheiser GSX 1000
Audio
Sennheiser 6XX
AMD Ryzen 2600X
GIGABYTE X470 AORUS GAMING 7 WIFI
Sapphire R9-290 Vapour-X
G.Skill Flare X
Samsung 960 EVO
Seasonic Prime Ultra Titanium 650W
Noctua NH-U12S SE-AM4
Fractal Design Meshify C - Dark
Pixio PX277
Audio
Swan M10
rancor is offline
post #8 of 16 (permalink) Old 02-18-2019, 08:47 AM
nexus35's Avatar
Rep: 1 (Unique: 1)
At first, I would put it in the dishwasher and before drying apply the alcohol.
nexus35 is offline
post #9 of 16 (permalink) Old 02-18-2019, 03:17 PM
pulverizor's Avatar
Rep: 0
acetone?
pulverizor is offline
post #10 of 16 (permalink) Old 02-18-2019, 03:25 PM
Graphics Junkie
UltraMega's Avatar
Rep: 35 (Unique: 31)
The word you are looking for is "spudger". Everyone who tinkers with electronics needs to have some quality spudgers around for things like this.
https://www.amazon.com/Quantity-Spud...-1-spons&psc=1
"Spudger" is such an uncommon word that most browsers and text programs don't know it's a word, but it is. Search for it on amazon and you will probably think "oh that's what those damned things are called" just like I did.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
