Graphics Card VRM Cooling - Concern of Shorting Out? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 02-20-2019, 07:57 PM - Thread Starter
Mac by Day, PC by Night
Rep: 0
Hey everyone,
I recently added an Arctic Accelero aftermarket cooler to my NVidia 980, which has vastly improved cooling performance. While I also put aluminum heatsinks that came with the cooler on the memory chipset, I did not place them on the VRM for concern of shorting out any circuitry. I've attached a picture with the specific VRM I have in question.
The heatsink coolers I have would stretch across a few of these chipsets (one for every 2) - is there danger in sticking the heatsink on? Do I need to use anti-static tape at all in between the chips?
Appreciate any clarity you guys can provide!
post #2 of 11 (permalink) Old 02-20-2019, 11:54 PM
8051's Avatar
Rep: 20 (Unique: 14)
I'd think you would want to cover the obvious leads on those inductors to the left of the transistors.
I'd make sure the thermal adhesive doesn't bridge the contacts on the sides of the SMD transistors, I put too much thermal adhesive on those transistors on my Gigabyte 1080Ti Gaming OC and bridged those contacts and the card wouldn't boot until I removed all the heatsinks, cleaned off all the thermal adhesive on the leads and re-attached them with a much smaller amount of thermal adhesive/arctic ceramiqe. This issue made me very glad I had mixed in some arctic ceramique in a 50/50 proportion w/the thermal adhesive.
8051 is offline
post #3 of 11 (permalink) Old 02-21-2019, 12:30 AM
poah's Avatar
Rep: 4 (Unique: 3)
use the supplied tape to cover the edges of the mosfets and then place the heatsinks. use a pair of tweezers to make it easier to place.
poah is offline
post #4 of 11 (permalink) Old 02-21-2019, 05:43 AM
mmonnin's Avatar
Rep: 268 (Unique: 129)
Stock coolers stretch across all those MOSFETs. If you're worried if you can short them out, use a multimeter and measure the resistance from MOSFET to MOSFET.
mmonnin is offline
post #5 of 11 (permalink) Old 02-22-2019, 02:39 AM
Iconoclast
Blameless's Avatar
Rep: 3131 (Unique: 1869)
Largely my opinion on this topic.
Most thermal adhesive that doesn't contain actual metallic filler should not be conductive or capacitive when fully cured, but I don't know what's in the stuff Arctic Cooling includes with their coolers.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #6 of 11 (permalink) Old 02-22-2019, 11:32 PM
8051's Avatar
3M posts dielectric strength for at least one of the their thermally conductive epoxy adhesives:
https://www.exdron.co.il/images/Prod...-datasheet.pdf
Wouldn't practically anything increase the permittivity or dielectric constant over air? The contacts of the transistors in my case had been clearly bridged.
8051 is offline
post #7 of 11 (permalink) Old 02-23-2019, 06:01 AM
Iconoclast
Blameless's Avatar
Is that what Arctic includes with their coolers?
Many materials are stronger electrical insulators than dry air (including almost all non-metal filled TIMs) or even a vacuum (things like wax, teflon, or mica). Cured epoxy with only ceramic filler is a fairly strong insulator and has completely negligible effects when bridging low voltage contacts. You could submerge and completely encapsulate a video card PCB in the 3M stuff posted above and not experience issues.
post #8 of 11 (permalink) Old 02-23-2019, 06:38 AM
Overclocker in training
ThrashZone's Avatar
Rep: 42 (Unique: 34)
Hi,
Why would it be any different than the stock 980 air cooler config which most would of had a thermal pad on top of memory and vrm..
Vaper
(4 items)
i9-7900x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #9 of 11 (permalink) Old 02-23-2019, 02:41 PM
8051's Avatar
The dielectric constant of a 3m thermal epoxy (http://multimedia.3m.com/mws/media/2...ive-tc2810.pdf) is 4.1 times greater than air which means it has 4 times the capacitance of air in a parallel plate capacitor: 'The capacitance created by the presence of the material is directly related to the Dielectric Constant of the material.' from:
http://www.clippercontrols.com/pages...nt-Values.html
8051 is offline
post #10 of 11 (permalink) Old 02-24-2019, 01:39 AM
Iconoclast
Blameless's Avatar
Yes, I was thinking dielectric strength, not constant. My mistake.
Regardless, that dielectric constant is on par with the PCB, component packaging, and most forms of underfill. It should be a complete non-issue.
Tags
980 , accelero , Cooling , Nvidia , Vrm
