What are the best (cheapest) gpu for Adobe? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 02-26-2019, 02:40 AM - Thread Starter
Rep: 0
Hello guys, I am new here and this is my first post
So my rig is done and out and running good abd perfect
R7 2700x
Asus B450 f-gaming
Corsair 16gb C16 RGB PRO
NZXT H500
Samsung 970 Evo 500gb M.2 SSD
3TB Seagate HDD
Zotac GTX 1050 ti OC edition
HP 1080p monitor 27"
So here is the deal. I built this system for Adove Photoshop and Adobe Illustrator (ONLY)
I will never use this system for any gaming at all even in the future, and will not change the monitor also. So i dont want to pay any premium for gaming.
Then i started thinking: I can return the card and get another one if I want. So my question is: is the 1050 ti able to run these 2 programs to a place where getting a higher end gpu would be useless gains? I just want a gpu that that goes to the sweat spot where it is useless to get better. I went fast and got this I know but if it ok and wont cause any problems i will keep it. if not i will think of the better one. however, if it is a bit of overkill, then that is ok i will keep it. i dont have a proble with a bit overkill bcs i dont want to be on the edge obviously. i just dont want to regret it on the future for not changing it now while i still can.
My goal is to run these 2 programs only as smooth as possible without causing and lag or stutter when putting any effect or or zooming that is gpu bound.
Just please forget about my other components.
Thank you a lot
Sent from my SM-N950F using Tapatalk
Supernaturaal is offline
post #2 of 4 (permalink) Old 02-26-2019, 03:36 AM
Storage Nut
Sean Webster's Avatar
Rep: 1660 (Unique: 967)
That GTX 1050 Ti is plenty: https://www.pugetsystems.com/labs/ar...rformance-899/
SSD GURU
Storage Essentials | My Server Build Log
"Some say he once took a backup of the entire NSA database. Others say he lays SSDs like chickens lay eggs. All we know is, it's Sean Webster!"
Main Rig
(15 items)
Terrorbyte V2
(16 items)
i7-6700K @4.6GHz
ASRock Z170 OC Formula
Gigabyte GTX 960 WindForce 2X OC
32GB Patriot Viper Elite @2666MHz
480GB ADATA SX8200
1TB Samsung 960 EVO
2TB HP EX950
Corsair RM650
Thermaltake Silver Arrow
Fractal Design R5
Operating System
Windows 10 Pro 64-Bit
BenQ GW2765HT
BenQ GW2765HT
Keyboard
Patriot Viper V760
Mouse
Patriot Viper V560
Intel Core i7 4790K
ASUS Maximux IV Extreme
32GB (2x 16GB) Corsair Vengeance Pro @2.4GHz
2TB WD Red
2TB Samung Spinpoint F4
2TB Hitachi Deskstar 7K3000
1TB Samsung Spinpoint F3
3TB Toshiba DT01ACA300
3TB Seagate Barracuda 7200.14
8TB HGST Ultrastar He8
4TB Seagate Barracuda
Corsair 650TX
Norco RPC 4224
Operating System
Windows 10 Pro 64-bit
Other
LSI 9261-8i
Other
Intel RES2CV240
Intel Core i7 9700K @5GHz
ASRock Z390 Taichi Ultimate
16GB (2x 8GB) Kingston HyperX Predator RGB @3.6GHz
Intel Optane SSD 905P 1.5TB
EVGA 500W
Noctua NH-U14S
Operating System
Other
ASRock TB3 AiC
Sean Webster is offline
post #3 of 4 (permalink) Old 02-26-2019, 03:59 AM - Thread Starter
Rep: 0
Quote: Originally Posted by Sean Webster View Post
Thank you for your response,
So in other words: there is no noticeable difference that I will see in these 2 programs if I compare it to GTX 1660 ti or RTX 2060? Even After 5-7 years of use?
post #4 of 4 (permalink) Old 02-26-2019, 05:21 AM
OG AMD
Redwoodz's Avatar
Rep: 588 (Unique: 461)
Adobe does use some GPU acceleration, and has been increasing GPU use year by year. Yes there is not much difference in most scenarios now. Do you want the ability to work with 4k/8K images with no stuttering? Do you want the ability to support 10 bit color? If you are not gaming I think a Radeon Pro WX5100 with 8GB VRAM is enticing. It uses even less power than your 1050Ti by the way, only using 75 watts.And produces more accurate imaging. $329 is not too bad for a system you plan on using for the next 10 years.
https://www.newegg.com/Product/Produ...82E16814105068
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
