Effects of x16 GPU in x8 slot - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 03-05-2019, 03:47 PM - Thread Starter
Turgin's Avatar
Rep: 10 (Unique: 10)
I'm trying to consolidate the function of 2 of my computers to one but I'm running into some hassles and wanted to get opinions on a couple things.
My primary computer is an i7-4790k with 16GB of RAM and an R9-390X GPU. I use it for typical things along with some occasional gaming like CS:GO, Doom, Kingdoms of Amalur, etc. I also work from home via a VMware VDI session on this computer.
My second system is a workstation class built around a Xeon E5-2690v2 with 128GB of RAM (10c/[email protected]) and a Supermicro workstation board. I use it primarily for VMs where I test and play with various things that interest me but also for testing upgrades and changes to my "production" VMs that I use for my home network and lab.
I'm hoping the Xeon system can do everything I want if I moved the GPU to it, but then I discovered the R9 is a 2.2 slot card which interferes with other expansion cards I have in that system and also derails my plans to add some other things. My planned additions are an Intel dual port 10g NIC and a 1.2TB Fusion IO PICe SSD.
So, I have a spare Supermicro X9SRL-F server board I can use that has plenty of slots for everything including the other cards I want to add. The catch is it doesn't have any electrically x16 slots. Its two x16 slots are only x8. I know I'll have to add expansion cards for USB3 and a sound card.
My first question is, for my use case, will the Xeon at only 3.3 Ghz be an issue for the games I play?
Second, how much will an x8 slot bottleneck my GPU and will it actually be noticeable?
Last, does any of that change if I upgrade to an Nvidia 2060 or 1660 and try Metro Exodus, Anthem, or other newer games?
Turgin is offline
post #2 of 6 (permalink) Old 03-05-2019, 04:09 PM
The last VRM burner
Rep: 4 (Unique: 3)
In case of 390X you'll lose like 3-7FPS total, checked that on my 290X 4GB, can't remember which title I've tested.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
EVGA GeForce GTX660 2048MB DDR5/192bit SuperClocked 1101MHz/1505MHz
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Samsung 850 Pro
Toshiba HDWD10 (P300)
Corsair CS650M
Raijintek Tisis + Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
SteelSeries QCk Mini
Audio
Audio in Motion SC808
Audio
AKG K240 Studio 1st rev
Other
NZXT Hue+
Other
Mayflash F300
BroadPwns is offline
post #3 of 6 (permalink) Old 03-05-2019, 04:23 PM
wingman99's Avatar
Rep: 51 (Unique: 42)
Titan X Performance: PCI-E 3.0 x8 vs x16 https://www.pugetsystems.com/labs/ar...x8-vs-x16-851/
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
wingman99 is offline
post #4 of 6 (permalink) Old 03-05-2019, 04:33 PM - Thread Starter
Turgin's Avatar
So, according to that link plus another one I found I don't think the slot will make a difference. https://www.gamersnexus.net/guides/2...impact-on-gpus
Turgin is offline
post #5 of 6 (permalink) Old 03-05-2019, 05:04 PM
wingman99's Avatar
No it won't make much difference.
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #6 of 6 (permalink) Old 03-05-2019, 05:31 PM
white owl's Avatar
Rep: 126 (Unique: 96)
I have a 1080 in an x16 slot that's stuck running 8x, still gets the results you'd expect.
Having a 3Ghz CPU isn't ideal but you have enough cores that in modern games you should be fine, faster would be better but still probably pretty good.
It really depends on how you play games.
If you play 4k with high settings the CPU might give you 1% less performance than a 9900k.
If you play 1440p with higher framerates the CPU's speed will hold you back some but still pretty good.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
