!VERY strange cooling for graphics card (memory only partially covered): problem? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 03-09-2019, 02:45 PM
8051's Avatar
Rep: 24 (Unique: 18)
Quote: Originally Posted by pulverizor View Post
ok
so what happens with the half covered half bare chips then? like will it be a red/blue hot/cold with one half red hot & the other blue cold (thermal imbalance) or does the chip "balance out" on its own?
I mean chips ain't metal either right? that non-shiny dark grey material that covers all memory chips (whatever it is) looks more like an insulant or something so if a heatsink only touches part of the chip then wont only that part will be cooled & not the whole chip? would the other part still remain hot?
If the whole IC is covered w/the same piece of thermal tape I'd guess the thermal tape would conduct the heat to the heatsink/heat plate even if it weren't directly contacting the heatsink/heat plate so maybe it would be a good idea. The other thing to consider though is that thermal tape is sticky and it will attract dust.
8051 is offline
post #12 of 16 (permalink) Old 03-09-2019, 03:06 PM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
no I meant what happens with the design "as is" (no modification): half covered by thermal pad & heatsink, the other half bare (no pad & no heatsink)
is there a thermal imbalance? would the bare half show as much hotter/red vs the other covered half as cold blue in an IR image?
or instead does the chip by itself "spread out" the heat between the bare half & the covered half?
I ask cause those chips aint metal (dunno what they're made of)
pulverizor is offline
post #13 of 16 (permalink) Old 03-09-2019, 03:32 PM
white owl's Avatar
Rep: 136 (Unique: 103)
Stop feeding the trolls!
https://www.overclock.net/forum/246-...lematic-2.html
They already beat the horse to death in the other thread, they're either trolling or just looking for a problem that was never there. The fact that the GPU works and doesn't throttle should have been enough. The fact that ram barely needs to be cooled should have been enough.
Quote: Originally Posted by ciarlatano View Post
...the memory here requires very little in the way of active cooling, if any at all. As @white owl already pointed out, contact with half the chip will provide some active cooling to the whole chip. Adding more thermal pads will actually be counterproductive, as it will not allow air to move over the chip.
To assume that adding more pad over it would cool better would be about the same as adding paste to a CPU with no cooler and thinking "it'll help transfer heat to the air more good". -or- a CPU with a cooler only cooling half the chip. Obviously that paste isn't helping.
If the chip conducts heat better than the pad (it does), all you're doing is putting a jacket over the other side.
Intel CPUs with factory paste have the same "thermal imbalance" since one or two cores can be 10c hotter than the other which is likely a much higher delta that what's you'd see cooling half of a 5w ram chip.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #14 of 16 (permalink) Old 03-09-2019, 03:39 PM
OG AMD
Redwoodz's Avatar
Rep: 585 (Unique: 459)
Besides, heat transfer will equalize the RAM IC temp regardless if it's covered,half-covered or naked.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #15 of 16 (permalink) Old 03-10-2019, 11:16 AM - Thread Starter
pulverizor's Avatar
Rep: 0
no man I just wanna compare opinions you see some disagree with you apparently that's why I wanna know for certain
for instance:
you absitively SURE about that?
what's the chip made of? the grey rigid covers I mean (looks like something halfway between plastic & metal so how well does that stuff conduct heat compare to thermal pads?)
post #16 of 16 (permalink) Old 04-05-2019, 02:18 AM
Rep: 0
i believe u can leave the thermal pads half attached to the rams and it will still disperse the heat that is accumulated.
nonoh is offline
