Correct PSU cables for 2080ti? Pig Tail cables. - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 05-18-2019, 03:17 PM - Thread Starter
Maximos118's Avatar
Rep: 0
I have an MSI 2080ti Trio which needs x2 8 pin AND a 6 pin.
I have just purchased a Corsair 850x PSU with x3 pig tailed 8 pin PCI-E cables. (meaning one side of the cable is normal 8 pin and the other has 8 pin AND another 8 pin of the back of that)
My question is can I effectively use one of these cables to daisy chain the two 8 pins? Meaning I'd only use two cables from the PSU to power the 3 sets of pins on my GPU.
The power draw of the card is quoted 300w.
Maximos118 is offline
post #2 of 3 (permalink) Old 05-18-2019, 04:08 PM
The last VRM burner
Rep: 48 (Unique: 28)
You can do anything you want as long as you won't change cables pinout, as in example, reverse up pins with down pins. Der8auer recently made a good video regarding PCI-E cables, using 2080Ti in furmark.
PC for all
(23 items)
i7 5775c @4.2GHz/3.8GHz
MSI Z97 MPower
Iris Pro 6200 1300MHz
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Front Arctic P14 PWM PST x2
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mouse
Tiger Gaming Arc teflon mouse feet
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #3 of 3 (permalink) Old 05-18-2019, 04:44 PM
Overclocker
JackCY's Avatar
Rep: 364 (Unique: 261)
It's best to use a cable for each connector. Especially if you have cables with inbuilt capacitors. If you like to risk then yes it's possible to push the cables to their limit and use split cables and splitters etc. to only use 1 cable.
2080Ti may be quoted as 300W at default specs but easily pulls +50% OCed and allowed to.
JackCY is offline
