Thermal pads leaking, what to do? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 06-18-2019, 03:46 AM - Thread Starter
Top kek
Rep: 110 (Unique: 65)
Quote: Originally Posted by JackCY View Post
They age, overheat and can start leaking.
So your cards runs hot, repaste it, replace leaky pads. They sell them from China for a couple bucks. Same colors and probably even source as those used on retail GPUs, don't dream that they are using some crazy high end thermal pads there. You can buy some better pads, if you believe the marketing, from say Akasa and other more known brands in computer parts shops, some sell these but they cost 10x such as $20 instead of $2 and that's for a 10x10cm piece.
The TCXXX ones are cheap, but the Grizzly ones are hella expensive. Although, they sell them also in 10x200x# sizes, so i guess i can cut them down.
I know that the oil by itself is not an issue. But would a GPU need a thermal pad on the back of it, directly pressing against the PCB and its components (not like VRMs/Memory chips),
Previous Hardware:
Spoiler!
Desktop PC
(19 items)
AMD FX-8320
ASRock Fatal1ty 990FX Killer
Sapphire Nitro+ RX480
XFX RX470 Singlefan
MSI RX580 GamingX 4GB
Mushkin Redline 996996 2x4GB 2133Mhz
Western Digital 160GB 7200RPM 8MB
Maxtor 250GB 7200RPM 8MB
Corsair Force LS
WesternDigital Blue 500GB 7200RPM 16MB
Corsair TX850M
ThermalTake Frio Silent 14
ThermalTake View 27
Operating System
Windows 10 Enterprise 1607
Operating System
Linux Mint 17.3 Rosa
AOC i2267FWH
Keyboard
Logitech K120
Mouse
Bloody V5
Audio
Corsair HS30 Raptor
ku4eto is offline
post #12 of 17 (permalink) Old 06-18-2019, 04:48 AM
I Love this Hobby!
Gunderman456's Avatar
Rep: 588 (Unique: 490)
Backplates are for show. Many cards sell without backplates.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ 1160GHz Core/1350GHz Mem
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Open Water Loop
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Nixeus EDG 27" Freesync 1440p 144Hz
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Microsoft Sidewinder X5
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Intel Core i5-3570K @ 4.5GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990
G.SKILL Ripjaws X DDR3 8GB 1600MHz
Crucial SSD 128GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Corsair Vengeance MM200
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
AMD Athlon II X4 640
ASRock N68C-GS
NVIDIA 6600GT
G. Skill Ripjaws DDR3 1600MHz
WD Caviar Blue 500GB 16MB Cache 7200RPM
Optical Drive
LG Optical Drive
Thermaltake TR2 600W
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Viewsonic 19” Flatscreen CRT
Keyboard
Gigabyte GK-K6800 103
Mouse
Zalman ZM-M300
Mouse
Gunderman456 is online now
post #13 of 17 (permalink) Old 06-18-2019, 05:28 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
You need to change the TIM on the GPU die and replace the thermal pads as needed. backplate thermal pads will dissipate heat off the PCB into the place, but tat only works well if the case has good air flow. The backplate thermal pads is not the overheat issue, its mainly your GPU that needs attention more than anything.
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
Intel i7 7700K
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
EVGA RTX2080 Ultra Gaming XC
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
ezveedub is offline
post #14 of 17 (permalink) Old 06-18-2019, 06:29 AM
Overclocker in training
ThrashZone's Avatar
Rep: 60 (Unique: 47)
Hi,
Yeah I removed my back plates
They do protect the back of the card too but I was just messing around testing and really haven't noticed a difference with or without
But if you have sweating you should remove and redo thermal paste if it does not have cooling fans get a add on air cooler or something.
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #15 of 17 (permalink) Old 06-18-2019, 10:05 AM
Packet Pusher
Renegade5399's Avatar
Rep: 230 (Unique: 145)
It's the paste on the GPU die. The pads on the back are whatever. A card with a back plate typically runs the same temp as one without. It acts as a heat spreader. My Gigabyte 1080Ti only had paste on 2/3 of the GPU. I was amazed when I pulled it apart and saw that. If the damn thing wasn't a golden chip, I would have done an RMA just because. Take the cooler off. I'll bet the paste was poorly applied and now that it's aged some, you're seeing bad performance.
My Sauce Is Much 13373|2 Than Yours
What's in your hardware wallet?
[Gigabyte Aorus 1080 Ti Owner's Club]
Project Blackout
(24 items)
i9 7900X Delidded
ASUS TUF X299 Mark 1
EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING
G.SKILL Trident Z Royal Series 16GB - Samsung B-die DDR4 4000
G.SKILL TridentZ RGB Series 16GB - Samsung B-die DDR4 4000
4x 1TB Western Digital Black
2x 480GB Kingston HyperX Savage SSD
2x ADATA Ultimate SU800 1TB 3D NAND
Intel 660p Series M.2 2280 1TB PCI-Express 3.0 x4
INTEL® RAID ADAPTER RSP3DD080F
2x 2TB Western Digital Green
CORSAIR HX Series HX1000
Custom Water Cooling Setup
Bitspower MonoBlock ASX299TUF RGB-Nickel
Thermaltake Core X71 Tempered Glass Edition Black
Operating System
Winders 10 Pro 64bit
Pixio PX276h 27"
Acer GN276HL 27"
HP EliteDisplay E222 22"
Keyboard
Corsair K95 RGB PLATINUM - Cherry MX Speed - Gunmetal
Mouse
HP Omen Reactor
Mousepad
Corsair Gaming MM800 RGB Polaris
Audio
Sades SA926 Gaming Headset
Renegade5399 is offline
post #16 of 17 (permalink) Old 06-18-2019, 10:11 AM
skupples's Avatar
Rep: 533 (Unique: 302)
Quote: Originally Posted by ku4eto View Post
The thing in question is, the GPU started overheating like crazy. Reaches 81*C according to sensors, and hard crashes, because the ASIC temp is like 100*C.
Do i need the thermal pads on the back of the GPU, on the GPU core backside and the backside of the VRMs?
you need to replace whatever was already there. Sounds like they've more than just jizzed, they've failed.
+ new TIM. Yes, best bet is liquid metal on GPU chips.
back Plates are 90% protection, 10% head spreading, and only heat spreading if you've got memory on the back of the card.
skupples is offline
post #17 of 17 (permalink) Old 06-18-2019, 12:14 PM - Thread Starter
Top kek
Alright, this answers my questions. I will deal with the card on the weekend, and i will test it then.
Thanks for the help folks!
Previous Hardware:
Spoiler!
Desktop PC
(19 items)
AMD FX-8320
XFX RX470 Singlefan
Corsair Force LS
Corsair TX850M
ThermalTake View 27
Operating System
Operating System
AOC i2267FWH
Keyboard
Logitech K120
Mouse
Bloody V5
Audio
Corsair HS30 Raptor
ku4eto is offline
