Vertical GPU Kits - Overclock.net - An Overclocking Community
Vertical GPU Kits
post #1 of 2 (permalink) Old 06-24-2019, 06:55 PM - Thread Starter
wirefox's Avatar
Rep: 30 (Unique: 28)
Vertical GPU Kits
was thinking about adding a vertical mount fro my gpu to my rig.
Was looking at this on Amazon:
https://www.amazon.com/Graphics-vert...ustomerReviews
Anyone have a vertical mount?
Are their any significant cooling benefits for the mobo, cpu etc.. as the gpu is farther from the mobo?
or perhaps heat doesn't rise as well b/c the gpu core isn't on top?
Rig is a tight build so I'm not entirely sure if it would look better or not
aorus xtreme z390, i9900k 5.1 - nxzt x62... , aorus waterforce 2080ti @ 2130 - enermax pump, 3x120 ek rad on the gpu loop 48-51C, gskill trident rgb 3600 16, 17, 16, 36, 1.36v
wirefox is offline
post #2 of 2 (permalink) Old 08-27-2019, 09:58 PM
R.D.BID's Avatar
Rep: 24 (Unique: 17)
My GPU is mounted vertically and I don't have any issues or benefits from doing it.
Really the only issue with vertical mounting is for air cooled cards that get mounted too close to the side panel and you lose the ability to plug anything else into your motherboards PCI slots. Since you're watercooled the heat won't matter.
Other than that, there really isn't any benefit to it other than looks.
R.D.BID is offline
