First time liquid metal + 2080Ti - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 06-25-2019, 11:24 AM - Thread Starter
ntuason's Avatar
Rep: 175 (Unique: 155)
What are the preparation with liquid metal (Thermal Grizzly Conductonaut) to protect the surrounding circuitry? This is the lousy electrical tape protection I have so far, is it enough?
Thank you
i7 980x + CF 6970
(11 items)
i9-9900K @ 5.2GHz 1.39v (Direct-Die)
ASUS ROG Maximus XI Apex
ASUS ROG RTX 2080 Ti O11G
Trident Z Royal @ 4200MHz CL18
970 EVO Plus NVMe M.2 500GB
860 QVO 1TB
BarraCuda 8TB
Cooler Master MasterWatt Maker 1200
Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
Lian Li PC-011 Dynamic (White)
Operating System
Windows 10 19H2-1909 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
ASUS ROG Strix GeForce GTX 1660 Ti
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #2 of 7 (permalink) Old 06-25-2019, 11:47 AM
The last VRM burner
Rep: 46 (Unique: 27)
Put some nail polish on resistors and you're done.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 7 (permalink) Old 06-25-2019, 11:57 AM
Facepalm
Falkentyne's Avatar
Rep: 455 (Unique: 316)
Thank you
Some people simply paint the resistors with conformal coating ( https://www.amazon.com/gp/product/B008O9YIV6/ ) and they're good to go.
Nail polish (transparent, cellulose based only) also works nicely.
If you don't use nail polish, then kapton or electrical tape is a MUST. But I don't recommend the tape you used. The highly recommended tape is Super 33+ tape. It's very strong and thin as well, which is excellent for things like this. Not only is it higher quality than what you used, it may even be cheaper too. https://www.amazon.com/Scotch-Super-...dp/B0000AZ9HG/
It's also highly recommended you ALSO use a foam dam with any insulation you do. The foam dam's job is to protect the PCB from any LM getting off the entire die or heatsink area, not to insulate the SMD's. It's emergency insurance and it's free with no drawbacks as long as your foam is not thick, extremely compressible and cut out correctly. 15 ppi or maybe 20 ppi polyurethane foam works well. This stuff works perfectly:
https://www.amazon.com/gp/product/B002GKC2US/
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is online now
post #4 of 7 (permalink) Old 06-25-2019, 11:59 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1430 (Unique: 725)
I used "MG Chemicals 422B Silicone Modified Conformal Coating" on my 1080 Ti.
Peels off ezpz if you want to take it off.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
The Pook is offline
post #5 of 7 (permalink) Old 06-25-2019, 12:18 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
If you're careful, you don't need anything exotic, I just scotch taped some paper in place during the application. If you have shaky hands use nail polish.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #6 of 7 (permalink) Old 06-25-2019, 01:04 PM - Thread Starter
ntuason's Avatar
Thank you all. Took the nail polish advice would of loved the 422B Silicone since it’s removal. I just got this card no more than 2 weeks ago, is my manufacturer warranty basically gone?
i7 980x + CF 6970
(11 items)
860 QVO 1TB
BarraCuda 8TB
Operating System
Keyboard
Mouse
Mousepad
Logitech G840
Audio
Audio
Audeze LCD-4
Operating System
Keyboard
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #7 of 7 (permalink) Old 06-25-2019, 01:10 PM
9 Cans of Ravioli
The Pook's Avatar
as long as you remove the nail polish/conformal coating before you RMA you'll still have a warranty.
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
WD Blue 4TB SSD
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Keyboard
Mouse
The Pook is offline
