How to achieve 140+fps on low-middle cards? - Overclock.net - An Overclocking Community
post #1 of 36 (permalink) Old 06-26-2019, 08:35 AM - Thread Starter
Rep: 0
What do you have to turn down, to get an entry 2060 or Vega 64 to run 1440p and 144fps (for a 144Hz monitor).
I see most tests are run on All High or Ultra settings for results.. just wondering if you have to sacrifice a lot of "eye candy" to get 140+fps?
Northman is offline
post #2 of 36 (permalink) Old 06-26-2019, 08:40 AM
Computer Arsonist
NeoReaper's Avatar
Rep: 89 (Unique: 75)
Depends on the title, AA does tend to be a pretty big hitter on FPS in a lot of titles.
Piledriver Reborn
(20 items)
Intel I7 4770k 4.7Ghz
Asus Z97-P
Gigabyte RX 480 4GB (580 BIOS)
16Gb Corsair Vengeance PRO (4x4Gb) @ 2600Mhz
Kingston A1000 M.2 NVME 240Gb
Seagate Constellation ES 2TB
Western Digital Green 1TB
Corsair Modular RM650X
Corsair ML RGB 120mm x3 With Lighting Node Pro
Corsair H150i Pro
Gamemax Onyx Tempered Glass RGB
Operating System
Windows 10 Pro
Samsung 27" Curved S27D590C
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Dark Core SE RGB
Mousepad
Corsair Polaris RGB
Audio
Corsair Void Pro Wireless 7.1
Audio
Blue Raspberry
Audio
Corsair ST100 RGB
Other
Ikea Corner Desk
NeoReaper is online now
post #3 of 36 (permalink) Old 06-26-2019, 08:40 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 993 (Unique: 605)
depends on the game. you can get ~300 FPS @ 1440p in CS:GO on a GT 1030 with everything on the highest settings.
ignoring resolution, generally AA and shadows make the biggest difference to frame rate.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #4 of 36 (permalink) Old 06-26-2019, 08:43 AM
Zurv's Avatar
Rep: 14 (Unique: 12)
the answer is buy a better card
(but lower rez and shut off AA for the fast eye cancer if the real answer is more than one can spend. Also never use the entry level version. For example, the 3gig 2060. You want the 6.)
Zurv is offline
post #5 of 36 (permalink) Old 06-26-2019, 10:48 AM
Rocklin's Avatar
Rep: 6 (Unique: 6)
( Unconventional advice )
If one is savvy, can banish bloat and see true potentials.
For starters, i install GPU drivers manually in devmgmt.msc. I prune the unpacked folder beforehand & none of the extra software gets installed; then i use Nvidia Inspector 3.50 as a control panel.
Process has only been working on Beta/DCH drivers lately for me; Temps do plummet and everything is lightning fast.
Requires several additional steps of course (wall of text); Brute install is possible on both cards last i checked. PM me with a specific NV or AMD GPU setup, i would help.
Also- This elevated cmd is a favorite, makes past updates permanent (vet wisely) but makes it super fast.
dism /online /Cleanup-Image /StartComponentCleanup /ResetBase
Light OS helps too; 1Gb footprint. I like to toolkit my own OS from Techbench images, like this Gaming/Internet/Defender edition i made from 1809v2. (sorry can't share, diy!)
sf
(7 items)
i9-9900k
Phantom SLi/ac
1660 SC Ultra
16Gb G-skill
970 Evo
660p
Corsair CX650
Rocklin is offline
post #6 of 36 (permalink) Old 06-29-2019, 11:43 AM
MilesK's Avatar
Rep: 4 (Unique: 4)
Shadows are generally more CPU intensive than GPU intensive assuming you aren't using advanced shadowing techniques. Its generally the first thing you should disable if you have a CPU bottleneck.
AA is generally a huge tax, disabling it first is always the right way to go. Toss some FXAA or similar low cost solution that reduces image quality if the jaggies are too much to bare.
You should identify first and foremost what is "limiting" your fps when you need it most.
1440p is still a fairly large resolution which means you're most likely GPU limited but depending on the game and situation where you feel you need more FPS it could be a CPU limitation.
The first thing you should do here is figure out if you are GPU limit or CPU limited when you want/need more fps.
Also it needs to be said but anything above 60 fps becomes a gimmick in a lot of ways. Your eyes will be hard pressed to notice the difference between 60 and 120 let along 80 and 144. FPS doesn't tell the entire story all you really need is enough fps to make the game feel smooth, anything after that is gravy.
MilesK is offline
post #7 of 36 (permalink) Old 06-29-2019, 11:53 AM
9 Cans of Ravioli
The Pook's Avatar
bUt ThE hUmAn EyE cAnT sEe OvEr 30FpS
the difference between 60 and 100-144 is night and day.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
post #8 of 36 (permalink) Old 06-29-2019, 12:12 PM
Overclocker
JackCY's Avatar
Rep: 319 (Unique: 231)
Nothing, depends on a game/application. Lots of this high, ultra nonsense candy has almost no visual impact either, setup each game one setting by another and know how much each impacts performance. Some games even look better at lower settings because you get soft shadows instead of the ultra sharp unrealistic shadows that cost a fortune to render too.
Other games it doesn't matter what you set GPU wise because they are CPU limited.
Or they are a complete disaster and fps is limited by server performance when playing online.
JackCY is online now
post #9 of 36 (permalink) Old 06-29-2019, 12:19 PM
MilesK's Avatar
Rep: 4 (Unique: 4)
Maybe for you, jet fighter pilot but for the average person the benefits of fps past 60 diminish quickly.
Maybe the OP can see the difference between 120 and 144, if so sucks to be you but you gotta do what you gotta do.
For everyone else once you hit smooth there is no "more smoother".
MilesK is offline
post #10 of 36 (permalink) Old 06-29-2019, 12:23 PM
9 Cans of Ravioli
The Pook's Avatar
Yes, everyone buys high refresh rate monitors because they're fighter pilots.
You can't tell the difference =/= there is no difference.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
