How to test various GPU on same computer? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 09-22-2019, 09:36 PM - Thread Starter
IMKR's Avatar
Rep: 38 (Unique: 28)
This is probably a dumb question, and I am guessing I know the answer. But it seems very tedious and not effective.
But how does one test multiple GPU using the same computer? (i.e. either personal PC, or a test bench you have)
My current computer (first one i built years back with help from OCN) is a very basic one.
i5 4670 (non K)
H81m-p33
MSI gtx 760 hawk
2x4 gb ram
rosewill capstone 550w
I recently am getting back into PC and I recently bought a bunch of new hardware so i can tinker around.
atm i have 5 GPU that i bought used.
RX 580, RX 470, Radeon HD 7970, Radeon HD 7850, GTX 560 ti
How can i make sure all of these work fine, as well as stress test them to see that they are ACTUALLY working fine?
the only way I can think of is move video to onboard graphics. uninstall all current GPU drivers. put in GPU i want to test, download drivers. connect back to dedicated GPU. see if it posts. then stress test.
but that is very very tedious and i feel like there is a more efficient way to do this. moreso if you are testing both AMD and Nvidia GPUs.
IMKR is offline
post #2 of 14 (permalink) Old 09-22-2019, 09:47 PM
Graphics Junkie
UltraMega's Avatar
Rep: 31 (Unique: 27)
I usually just run furmark for ten minutes or so.
You do not have to uninstall drivers and switch to onboard. You may have to reinstall the driver each time you swap the GPU, but uninstalling and switching to onboard is not needed just to test used GPUs.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #3 of 14 (permalink) Old 09-22-2019, 10:01 PM - Thread Starter
IMKR's Avatar
interesting.
whats the way to do this then?
Do i first uninstall my drivers for my current card (the gtx 760 hawk. Also, this will be my main and future card as well. all the GPU i bought will be for other builds), shut the PC off, switch to the used GPU. once powered on, let the computer find and install drivers itself?
Also, if i uninstall my current GPU drivers, wont my screen just go dark? (which is why i thought you have to switch to onboard)
IMKR is offline
post #4 of 14 (permalink) Old 09-22-2019, 10:02 PM
CravinR1's Avatar
Rep: 983 (Unique: 749)
Install latest amd driver, test your amd cards. Use furmark or OCCT
Driver uninstaller then install nvidia driver and test nvidia cards. I test for 1 hour when buy used from ebay to make sure their fans and clocks are ok
R7 [email protected] EVGA GTX1070ti https://valid.x86.fr/tim79f
R7 [email protected] MSI 980ti https://valid.x86.fr/jxeld9
R7 [email protected] Gigabyte RX480 8gb https://valid.x86.fr/r5kdfu
R5 2600 XFX RX570 4gb (Just waiting on the 2600 to arrive)
Asus G75vw
(9 items)
Finally Ivy
(16 items)
3700x
MSI X470 Gaming Plus
EVGA 1070ti 8gb
G.Skill 16gb FlareX 3200mhz
Samsung 1tb m..2
Samsung 860 EVO 500
WD 3tb
Seasonic 1050x
Gammax 400
Coolermaster Masterbox
i7-3610QM
Asus Laptop
Nvidia GTX 660m 2gb
16 gb 1600mhz (4x4gb)
Samsung 850 EVO 500 gb
Seagate 750gb 7200rpm
Optical Drive
Asus DVDRW
Operating System
Windows 7 x64
17.3" 1080P
Intel 3770K 4.5 ghz 1.29v
Gigabyte GA-Z77X-UD3H
Sapphire Tri-X 290
G.Skill SNiper Gaming Series 16 gb (2x8gb) 1866mhz
G.skill Ares 8 gb (2x4gb) 2400mhz
Samsung 840 EVO 250
Toshiba 3tb x2 (6tb)
Optical Drive
LIte-On 20X DVDRW
Seasonic X-1050
Corsair H90
Cooler Master HAF 912
Operating System
Windows 7 Pro x64
HP w237ld 23" 1080P
Viewsonic VG2230wm 22"
Keyboard
SK-1788
Mouse
Logitech G400
CravinR1 is offline
post #5 of 14 (permalink) Old 09-22-2019, 10:04 PM
Graphics Junkie
UltraMega's Avatar
Quote: Originally Posted by IMKR View Post
interesting.
You do not need to uninstall anything. You can just shut down your PC and swap the GPUs. Your computer may boot to windows in a low resolution until the driver is installed, but that's it. Usually these days you can install the driver through windows update without issue, but if not just install manually and thats is.
People on OCN will tell you to uninstall the driver each time because people here like to be very tidy, but for testing old GPUs there is no reason to do this. You can uninstall any extra driver software at the end.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
post #6 of 14 (permalink) Old 09-22-2019, 10:16 PM - Thread Starter
IMKR's Avatar
awesome thanks for the help. sorry for asking such a basic question. I just never had the chance to dive deep with hands on experience into multiple PC hardware.
last final stupid question if you dont mind.
once im done testing the "new" used GPU, and i swap back to my main one, how can i ensure that i am correctly completely uninstalling the drivers of the tested GPU?
IMKR is offline
post #7 of 14 (permalink) Old 09-22-2019, 10:50 PM
CravinR1's Avatar
I'm still ecstatic I found a MSI 980 ti Armor 2x for under $150 shipped on ebay. I put kryonaut thermal grizzly on it and furmarked it for an hour to make sure it was stable.
I ALWAYS REPLACE THERMAL PASTE ON USED CARDS. AS5 and now Thermal Grizzly
Asus G75vw
(9 items)
Finally Ivy
(16 items)
3700x
EVGA 1070ti 8gb
Samsung 1tb m..2
Samsung 860 EVO 500
WD 3tb
Seasonic 1050x
Gammax 400
i7-3610QM
Asus Laptop
Nvidia GTX 660m 2gb
Optical Drive
Asus DVDRW
Operating System
Windows 7 x64
17.3" 1080P
Sapphire Tri-X 290
Samsung 840 EVO 250
Optical Drive
LIte-On 20X DVDRW
Seasonic X-1050
Corsair H90
Operating System
Windows 7 Pro x64
HP w237ld 23" 1080P
Keyboard
SK-1788
Mouse
Logitech G400
CravinR1 is offline
post #8 of 14 (permalink) Old 09-23-2019, 12:06 AM
Graphics Junkie
UltraMega's Avatar
You should be able to just uninstall them from the apps list. On windows 10, right click on the start button and go to apps and features.
The Nvidia installer will also give you the option to do a clean install, so it will remove any old NVidia drivers during installation. I believe AMD has this feature as well but not sure.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
post #9 of 14 (permalink) Old 09-23-2019, 07:17 AM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Restore a system image.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #10 of 14 (permalink) Old 09-23-2019, 08:13 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
people are still suggesting Furmark? don't use Furmark.
use DDU when you swap cards to completely wipe the driver of the old card. https://www.guru3d.com/files-details...-download.html
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
