I got some artifacts and my pc froze - Page 2 - Overclock.net - An Overclocking Community
post #11 of 21 (permalink) Old 11-14-2019, 08:18 AM - Thread Starter
Rep: 0
Rebooted again. When i was trying to update my drivers it just rebooted and wouldn't install drivers. I did the ram test everything is good, hdd is good. It's probably the gpu. What do you think
StefixMaster is offline
post #12 of 21 (permalink) Old 11-14-2019, 08:21 AM
skupples's Avatar
Rep: 587 (Unique: 329)
i think its that dinky GPU you're using. 1GB vram, wooosh. You're asking a lot of that little bugger.
RMA - request manufacturer assistance, AKA warranty claim.
really though, i'd just pick up a new/used better card.
skupples is online now
post #13 of 21 (permalink) Old 11-14-2019, 11:17 AM
wingman99's Avatar
Rep: 63 (Unique: 46)
Is Your BIOS set to default and graphics card no overclock? I would also do a memtest86 to check for defective memory Link: https://www.memtest86.com/
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #14 of 21 (permalink) Old 11-15-2019, 11:49 AM - Thread Starter
Rep: 0
I did the ram test everything is fine. I don't have RMA. I'm probably going to buy a new one. Thanks guys.
post #15 of 21 (permalink) Old 11-16-2019, 11:33 PM
wingman99's Avatar
Buying a GPU looks like your best option. Post back how it turns out.
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #16 of 21 (permalink) Old 12-04-2019, 04:52 AM - Thread Starter
Rep: 0
Quote: Originally Posted by wingman99 View Post
Buying a GPU looks like your best option. Post back how it turns out.[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Guys i sent my pc to computer repair shop and they tested it and say my ssd has problems and i should return it and get a new one. First i thought it's probably not that but i saw that one guy had the same problem and his ssd died and he used his hdd for everything and it worked. I'm going to send my ssd and see if problem still happens.
post #17 of 21 (permalink) Old 12-05-2019, 04:01 PM - Thread Starter
Rep: 0
I installed windows 10 on my hdd and everything seems fine. It was that chinese ssd probably. I sent it back. Also i'm going to buy a new gpu probably. Wish me luck that everything works
post #18 of 21 (permalink) Old 12-05-2019, 04:11 PM
skupples's Avatar
luck
post #19 of 21 (permalink) Old 12-06-2019, 02:36 AM - Thread Starter
Rep: 0
Unfortunately it happened again without my ssd being connected it's probably my hard disk then since its very old and health is at 25%. I am going to get a new hard disk and see if it helps. No luck this time
post #20 of 21 (permalink) Old 12-06-2019, 02:37 AM - Thread Starter
Rep: 0
Also this time my pc just rebooted without artifacts. And i have a kernel power error 41 in event viewer.
Tags
artifacts
