I need help - Overclock.net - An Overclocking Community
I need help
post #1 of 5 (permalink) Old 01-07-2020, 10:30 AM - Thread Starter
Rep: 0
I need help
Warning:Grammar mistakes
I just bought a asus gtx 750 ti and then cried over it because my psu had no 6 pin power connector for it then i heard about the 6 pin to sata and i was overjoyed by the idea and bought it asap but now i have attached it to my gpu and fortunately it was a perfect fit but when i power on my pc it the gpu would not even start no fans running no display nothing.Can anyone help me i just want to know how to run the gpu
THINGS TO BE NOTED
I can not change my psu cuz its the only psu that works with the motherboard neither do i have the money to do so.
I just want the power supply to run even if it costs the whole house to burn down
Saane is offline
post #2 of 5 (permalink) Old 01-12-2020, 03:13 AM
RIP OCN
Rep: 27 (Unique: 21)
It is not possible for your psu to be the only one that works with your motherboard.
What power supply to you have?
anti-clockwize is offline
post #3 of 5 (permalink) Old 01-12-2020, 05:18 AM
skupples's Avatar
Rep: 630 (Unique: 342)
is it an OEM computer? IE: dell, HP, etc?
if so, it's probably too small of a PSU. They also make 4 pin MOLEX >>> PCIe. This is what I used on the first system I ever chucked A PGU in (HP pavilion)
what are you sticking this gpu into? sounds quite a bit like an OEM computer.
I'd recommend trying MOLEX >> PCIE first, then look into if the OEM procured a larger model of the same PSU for a higher end model in the same segment (IE : one that came with a gpu)
skupples is offline
post #4 of 5 (permalink) Old 01-12-2020, 06:11 AM
Graphics Junkie
UltraMega's Avatar
Rep: 38 (Unique: 34)
An underpowered PSU wouldn't prevent the PC from booting since the GPU is basically idle.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #5 of 5 (permalink) Old 01-24-2020, 03:31 PM
Schmuckley's Avatar
Rep: 701 (Unique: 562)
I'd go for the molex to pcie power adapter 1st.
What PSU do you have?
You have to have a proper PSU to run a videocard. That one needs a 450-500w unit.
In b4 traces blow up on the mobo.
Schmuckley is offline
