CPU usage - 5700XT vs 2070 Super - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 03-23-2020, 01:40 AM - Thread Starter
haefen's Avatar
Rep: 4 (Unique: 3)
Hi,
I want to do an upgrade to my computer, GPU and monitor precisely:
1. monitor: 1080p, 144hz => 1440p, 144/165hz (depending, which monitor i will choose - LG 27GL850 or something from the IPS, 1440p, 165hz line-up)
2. gpu: RX580 8GB => 5700XT or 2070 super
I, currently, have i7-4790k running at 4.6ghz (could push to 4.7, but it needs >1.3v in my case, so for now i leave it alone), paired with 2400mhz cl11 RAM.
I've narrowed down my choice to 2 GPUs - 5700xt and 2070s.
Money is not really an issue, as I can afford all the options mentioned, but I'm trying to be reasonable and get the GPU, that will go better with my CPU and has the least problems possible.
My main questions is, since I couldn't find any comperhensive sources: Which of the 2 mentioned GPUs uses more CPU?
I remember a lot of API overhead benchmarks back in 2017 or something, when DX12, Vulkan, etc. were a new big thing and the topic was sexy.
Do you guys know a good source or data for this or canyou simply share you rexperience?
Thanks in advance!
haefen is offline
post #2 of 22 (permalink) Old 03-23-2020, 02:08 AM
Rep: 12 (Unique: 7)
The 2070 super is the more powerful card => will use more of the CPU due to the higher frame rate.
Pro tip: Buy Nvidia. Don't touch Navi with a 10 foot pole.
AMD Bliss
(15 items)
Ryzen 7 3700X - 1900MHz FCLK
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-13-27-40 1T 1.5V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4 Push-Pull
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is online now
post #3 of 22 (permalink) Old 03-23-2020, 03:05 AM - Thread Starter
haefen's Avatar
Rep: 4 (Unique: 3)
Value wise RAdeon seems better (i don't care about ray-tracing), but i read some ppl have some random problems with these radeons.
Main reason I am willing to pay premium for nvidia is to have care-free experience.
Rule of the thumb is more GPU power = more demand on the CPU.
And now, if 5700XT would bottleneck my CPU, then there is no reason to buy even more powerful card.
3 years ago I remember, that AMD cards were putting more stress on the CPU in the similar GPU performance scenario, compared to Nvidia.
I'm wondering if it's still the case, as this would give a bit more headroom for the extra 2070S performance.
Right now I am playing Modern Warfare (frame limit cap off) and with my RX580 i'm getting mostly 100-150 FPS with 100% GPU usage and average of 60% CPU usage. (1080p with 144hz)
I'm targetting similar performance on 1440p with a better graphics details and maybe closer to keeping framerate a bith higher and consistent around 144hz.
Using Variable Refresh probably will be an option, too.
haefen is offline
post #4 of 22 (permalink) Old 03-23-2020, 03:25 AM
rdr09's Avatar
Rep: 878 (Unique: 637)
The 5700XT is about twice as fast as the 580. CPU usage with AMD cards has improved and has been addressed for quite sometime now.
PRO TIP: I own two NAVIs and no issues playing using 1440 single monitor. No HDR, Freesync and such, tho.
EDIT: You might want to also consider the RX 5700. A lot cheaper and should have no problems pushing a 1080 144Hz monitor. Here is comparison to give you an idea.
https://www.3dmark.com/compare/fs/21783796/fs/21816346
Mine is a reference design and the fan is not that loud. Twice as fast but uses less power than my R9 290.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #5 of 22 (permalink) Old 03-23-2020, 04:33 AM
PC Enthusiast
Ashura's Avatar
Rep: 48 (Unique: 36)
CPU utilization should be pretty much same for both 5700XT & 2070S & would also depend on the game.
Both Gpus are almost twice as fast as the Rx580. 5700Xt is generally better value for the money, But you may experience some driver related issues such as the black screen bug or stuttering.
I personally have had the blackscreen bug twice in 4 months. No stutter or any other issues.
Your CPU should be fine @ 1440p
PolaRyz
(15 items)
Venomous FX
(14 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 3000Mhz 32gb
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mouse
Steelseries Qck Mass
AMD FX 8350
MSI 990FXA Gaming
XFX R9 290 DD
G.Skill RipjawsX 16GB [4x4GB] 1600MHz CL9 @1.5v
Seagate ST1000DM003
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
Dell ST2420L
AOC e2243Fwk 21.5"
Mouse
Razer Deathadder Chroma
Mouse
SteelSeries QcK Mass
Ashura is offline
post #6 of 22 (permalink) Old 03-23-2020, 04:34 AM
Why is it smoking?
Mr. Mojo's Avatar
Rep: 361 (Unique: 296)
FWIW, Radeon drivers have come a long way in the past couple of months. With that said, some people are still reporting issues.
Bottom line - if money isn't an issue and you want a hassle-free experience, go with the 2070S. If you want to save a a hundred(ish) bucks or don't mind fiddling with drivers/settings, go with the 5700XT. Either option will be fine for high refresh 1440 with decent settings.
Black Feathers
(22 items)
AMD Ryzen 7 3700x
Gigabyte x570 Aorus Pro Wifi
Sapphire Radeon RX 5700 XT
Crucial Ballistix Elite DDR4 3600
Sabrent Rocket NVMe PCIe 4.0 M.2 2280
Sabrent Rocket NVMe PCIe M.2 2280
Seasonic FOCUS Plus 750
EK-KIT Classic RGB P360
EK-Vector Radeon RX 5700 +XT RGB - Nickel + Plexi
Arctic P12 PWM PST
DEEPCOOL RF120M
XSPC G1/4" Inline 10k Sensor, Chrome
EK-CryoFuel Solid Cloud White (Premix 1000mL)
Lian-Li PC O11 Dynamic (white)
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio Technica ATH-M50x
Audio
Logitech Z333
Intel Core i7 4710HQ
NVIDIA GeForce GTX 970M
16GB DDR3L
Samsung 850 EVO
HGST Travelstar 7K100
Operating System
Windows 10
BenQ XL2720T
Keyboard
Microsoft Sidewinder X4
Mouse
Gigabyte M8000X
Mouse
Steelseries
Audio
Audio-technica ATHM40x
Audio
MTX iX1 Headphones
Mr. Mojo is offline
post #7 of 22 (permalink) Old 03-23-2020, 05:47 AM - Thread Starter
haefen's Avatar
Rep: 4 (Unique: 3)
Yeah, this hassle free experience pushes me towards 2070S.
I have some problems with my RX580 already.
Even tho i have a high-end non-reference version (Aorus XTR), it had some problems with crashes.
The most ridiculous one is that i have to manually bump up core voltage, because the card itself sets the voltage too low to support stock clocks.
Using Afterburner and setting voltage and clocks to my liking there fixes the problem.
I decided to live with it and not RMA, because it pretty much solves this problem, but those are the things.
As for the price, I live in Poland and the price difference is that Gigabyte 2070S Gaming OC (which gets good reviews) costs 25% more (~500 EUR vs ~400 EUR), than good non-reference 5700XT.
So i credit a part of this difference to 10-15% more average performance and I think I'm willing to pay the rest of the premium for good experience and extra features (like RT, if i ever need it), which seems to be the case with 2070S.
Kind of voice of reason I was looking for, thanks Mr. Mojo.
As mentioned above, I had to do a lot of fiddling with my RX580 and sometimes, i.e. after my computer comes up from sleep, Afterburner resets the settings (and voltages).
If I forget to check and apply my Afterburner profile before the game start, I sometimes end up getting a crash, which is frustrating in multiplayer games (getting thrown out of the match or something).
Btw Mojo, great choice for an avatar.
Seen Jinjer live last November, they are incredible. ^^
Thank you guys for clarification.
haefen is offline
post #8 of 22 (permalink) Old 03-23-2020, 06:09 AM
rdr09's Avatar
I have a RX 570 and luckily never have that issue. I keep all my GPUs stock, tho. But, i think you made a good choice.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #9 of 22 (permalink) Old 03-23-2020, 06:13 AM
PC Evangelist
ZealotKi11er's Avatar
Rep: 1803 (Unique: 1177)
I would not pay 25% more for 2070S. You will get 5-10% extra performance at most. Personally have no issues wit 5700 XT. If I had to get Nvidia I would get 2060S.
Yamato
(10 items)
Ishimura
AMD Ryzen 7 3700X
ASUS TUF Gaming X570-Plus (Wi-Fi)
AMD Radeon RX 5700 XT
G.SKILL Trident Z RGB (2x8GB) DDR4 3200MHz CL14
Samsung SM961 512GB
HGST DeskStar NAS 6TB
EVGA SuperNOVA 750 P2
Gamdias Chione M1A-280R
Fractal Design Meshify C TG
Operating System
Microsoft Windows 10 Pro 64 Bit
Intel Core i7-3770K @ 4.8GHz
ASRock Z77E-ITX
AMD Radeon Vega Frontier Edition
AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
SanDisk Ultra II 960GB
Toshiba X300 5TB
EVGA SuperNOVA 750 G3
Corsair H100i GTX
Fractal Design Define Nano S
Operating System
LG OLED55C7P
Keyboard
Cooler Master MasterKeys MK750
Mouse
Finalmouse Air58 Ninja
ZealotKi11er is offline
post #10 of 22 (permalink) Old 03-23-2020, 06:16 AM - Thread Starter
haefen's Avatar
Rep: 4 (Unique: 3)
Yeah.
Even tho it shows default 1150mV for the profile in Radeon Settings, the monitoring shows 1125...
It is not enough to support declared 1439mhz, even not enough to keep 1425 without crashes.
I have to go near 1200mV to support 1439mhz and even when setting +100mV in Afterburner it gives ~1225 max, which allows for a stable OC up to 1460-ish.
At least my memory runs at 9ghz... I bought it right after the relase for the retail price.
Should've sold it for almost twice more, when crypto mining boom started a month later.
But I haven't, because I just want to game in peace, when I feel like it, this is also why I am willing to pay extra, for bigger probability of not having to worry about anything.
haefen is offline
