whatever happened to DX12 multi-GPU? - Overclock.net - An Overclocking Community
post #1 of 30 (permalink) Old 05-26-2020, 04:24 AM - Thread Starter
8051's Avatar
Rep: 30 (Unique: 21)
It seemed to work well with AMD cards in Deus Ex: Mankind Divided:
https://www.youtube.com/watch?time_c...ature=emb_logo
But is this only because AMD backed up Eidos in developing it?
Were there any other games that supported DX12 multi-gpu?
8051 is offline
post #2 of 30 (permalink) Old 05-26-2020, 04:59 AM
Top kek
Rep: 121 (Unique: 72)
The issue with Crossfire/SLI in was, that the game devs had to make it possible to work.
Then, AMD and NV had to make it possible to work as well, with a new driver.
DX12 multi-GPU differs from this, by putting all of the work on the game developer instead.
And you know, unless there is some very good reason to do so, game companies wont spend time (time = money) on a technology, thats going to see about 5% utilization with their customer base (5% is a VERY generous share of a dual-GPU systems).
Previous Hardware:
Spoiler!
Main rig
(16 items)
Parents (2nd) PC
AMD R7 1700
ASRock X570 Fatal1ty Gaming K4
Sapphire RX480 4GB Nitro+
Corsair Vengeance LPX 2x8GB 3200Mhz
Corsair ForceLS SSD
250GB Maxtor SATA 7200RPM 8MB
250GB Seagate Baracuda SATA 7200RPM 8MB
500GB WesternDigital Blue 7200RPM 16MB
Corsair TX850M
Cooler Master 212 EVO
Thermaltake View 27
Operating System
Windows 10 x64 1607
AOC i2267FWH 21.5" 1080p IPS
Keyboard
Logitech K120
Mouse
A4 Tech Bloody v5
Audio
Corsair HS30 Raptor
AMD FX-8320
ASRock Fatal1ty 990FX Killer
XFX RX470 4GB SingleFan
Mushkin Redline 996996 2x4GB 2133Mhz
Western Digital Green 500GB 7200RPM 8MB
120GB Kingston SSD
Optical Drive
ASUS DVD+RW x52
Corsair VS650
ThermalTake Frio Silent 14
DeepCool Tesseract
Operating System
Windows 10 Enterprise 1607
ASUS VS228H 21.5"
Keyboard
Logitech K120
ku4eto is offline
post #3 of 30 (permalink) Old 05-26-2020, 05:52 AM
Gandyman's Avatar
Rep: 1 (Unique: 1)
As far as I know TAA can't be enabled in sli/crossfire due to it using the information from the previous frame to downscale the next frame, and many modern games are using TAA as the performance hit is usually positive. Gone are the crysis 3 days of choosing your AA method.
AC:Oddesy is a good example of this, fps will be higher on low or medium AA than with AA off due to the temporal nature of the TAA, and seeing as we are late into console generation any extra performance would presumably be a must for a dev.
I run a tech shop so have come into contact with a lot of enthusiasts over the years, and from my experience at least, after Pascal (1080ti specifically) the amount of dual gpu systems I see has significantly reduced, almost to the point of non existence. Even myself. I had usually started with one mid range card I could afford when younger, then added another. I had dual HD 5770, dual GTX 560, dual GTX 660, dual GTX 760, ended up upgrading them to dual 780 strix, dual 980ti classys, then single 1080ti, then single 2080ti. ( you could plot a graph of how successful I have been financially in my life by using my current rigs gpu )
Then there's the sheer price of cards, I recently found a invoice for a client who purchased a 780ti off me in 2014, "Gigabyte GeForce GTX 780 Ti GHz Edition 3GB -- $599.00" That's AUD. The equivalent 2080ti today is $2249 AUD ( https://www.pccasegear.com/products/...gaming-oc-11gb ) That's a 275.5% increase from the top of the line GPU in 2014 to 2020. I would hazard a guess that dual GPU is completely priced out for more people then ever.
Due to all these factors I doubt its very profitable or even sensible for devs to support multi gpu, whether its via DX12 or otherwise.
Gandyman is offline
post #4 of 30 (permalink) Old 05-26-2020, 06:15 AM
Rep: 54 (Unique: 42)
Multi-gpu is only really starting to make sense with 4K120Hz on the horizon & 8K TV capability...
I already use 4K60hz with Freesync & HDR and would have loved to try multi-gpu solutions but there is no support, so it's dead end. All I can do is try and get a second Vega 64 and go for Legacy Crossfire instead, but no new gpu's have support for multi-gpu or new games have profiles for crossfire for the older cards.
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X PBO boost, 2x8GB 4866/1900 18.27.24.48.90.tRFC 680 1T 1.650V [Micron Rev.J]
4x8GB 3800/1900 13.23.17.30.66.tRFC 600 1T 1.700V Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron Rev.E 19nm [D9VPP]),
2x8GB Kingston HX436C17FB3K2/16 3600C17 1.35V (Micron Rev.J 17nm),
2x8GB 3866/1933 15.21.20.32.60.tRFC 448 1T 1.590V Kingston HX436C17FB3K2/16 3600C17 1.35V (Hynix DJR 17nm)
Nighthog is offline
post #5 of 30 (permalink) Old 05-29-2020, 04:41 AM
SirCanealot's Avatar
Rep: 0
FYI, I know at least for the low setting (not 100% sure about medium), AC:Oddesy actually runs the game at a slightly lower resolution and upscales back up with some form of AA. Pretty random, but that's why FPS is higher on low (so either run high or turn it off).
SirCanealot is offline
post #6 of 30 (permalink) Old 05-29-2020, 04:56 AM
Nvidia Enthusiast
philhalo66's Avatar
Rep: 270 (Unique: 211)
multi gpu is dead. Lazy devs killed it, they didnt want to be bothered adding support for it so now there are no games that support it aside from a few older ones.
gaming rig
(18 items)
Intel Core i9 9900K 5GHz 1.25V
ASUS Maximus XI Hero
EVGA RTX 2080 Ti FTW3 Ultra Hybrid
G.SKILL Ripjaws V DDR4 3600MHz 32GB
HGST 2TB
Seagate 2.5 Inch 2TB
Samsung 860 EVO 1TB
Intel 660p NVME 512GB
Optical Drive
LG Blu Ray drive
Corsair RM850i 850W
EVGA CLC 360MM Corsair LL120
Corsair Graphite 780T White
Operating System
windows 10 Pro
MSI OPTIX MAG24C
Acer XFA240 bmjdpr
Keyboard
G.SKILL RIPJAWS KM780 MX
Mouse
Razer Deathadder Elite
Audio
Sound Blaster Z
philhalo66 is offline
post #7 of 30 (permalink) Old 05-29-2020, 04:57 AM
Not a linux lobbyist
rluker5's Avatar
Rep: 59 (Unique: 43)
Shadow of the TR worked great for me with sli 1080tis, but I hear it has problems with AMD.
L5
(16 items)
Lea2
(11 items)
L7
(11 items)
5775c
Maximus VII Hero
Aorus 1080ti Waterforce
16 Gb Gskill Trident @ 2400,cas10,1.575v
Team 16GB [email protected]
1Tb Team sata+1TB Team sata+1TB 42mm msata
seagate barracuda 3T
Optane 900p 480G OS
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design C (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear, Nova 40, 598se, M1060, DT990pro, Fidelio2
Audio
SoundbasterX AE-5, onboard
4770k
Asus Z87 Deluxe
Fury Nitro
8Gb klevv urbane 2133
ROG Raidr 240Gb pcie
1Tb WD blue
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
DIYPC P48-W
Operating System
W10 64 pro
40"tv
4980hq
Asus H81T/CSM
16GB Samsung cheap
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
24" samsung 1080p
Keyboard
Logitech K400+
Other
Intel wifi ac card and noname antennas
rluker5 is offline
post #8 of 30 (permalink) Old 05-29-2020, 04:59 AM
Tank destroyer and a god
Offler's Avatar
Rep: 88 (Unique: 69)
I would ask about feasibility...
MultiGPU configurations meant for end-user few things:
a) Possibility of 80% increase of graphic performance on average.
b) Increased power draw, increased heat generation, need for extra cooling.
Or when the game was not supporting it, no benefit at all...
From my experience, the multiGPU solutions are not feasible for gamers, and even enthusiasts.
--- Building in progress * AMD Threadripper 1900x * Asrock X399M Taichi * Radeon VII * Gskill Xflare / Samsung B-die 3200 14-14-14-32 * Samsung 970 PRO 512gb * Fractal Design Node 804 * Seasonic Prime Ultra 850 Titanium *
--- Desktop * AMD Phenom II x6 1090t @ 3,8GHz * ASUS M5A99FX PRO R2.0 * Gigabyte R9 FuryX * A-Data XPG 2.0 / Elpida Hyper MNH 1866 @ 1600 6-6-6-18 * LSI 9211-8i / Raid 0 / 5x Corsair Force 3 GS * Creative Xfi Fatal1ty * Intel I210-T1 * Steelseries 6Gv2 * Logitech MX518 * Samsung U28E590D *
Offler is offline
post #9 of 30 (permalink) Old 05-29-2020, 06:31 AM
The IT guy...
OrionBG's Avatar
Rep: 10 (Unique: 8)
Guys, haven't you heard of SLI CFR mode? It has a lot of potential if Nvidia actually put some effort into it. In this rendering mode the frame is cut into small blocks and odd blocks are rendered by one of the cards and even blocks by the second one. This way you get double the memory as only the blocks that needs to rendered by the card are stored in its RAM.
There are some games that don't even work in the normal SLI modes but work quite well in CFR mode.
T.I.T.A.N.
(14 items)
Threadripper 3960x
Aorus TRx40 Xtreme
EVGA RTX2080Ti XC
EVGA RTX2080Ti XC Ultra
G.Skill TridentZ RGB 8x8GB 3200MHz CAS14
SP P34A80
SP P34A80
Samsung PM961
Corsair AX1600i
Custom Loop Water Cooling
Raijintek Enyo
Operating System
Windows 10
LG 55" OLED B9
Audio
Creative SoundBlaster Omni 5.1
OrionBG is offline
post #10 of 30 (permalink) Old 05-29-2020, 06:34 AM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 164 (Unique: 128)
tl;dr
game devs are lazy bastards
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
PC 1
(6 items)
Ryzen 9 3950X 1900FCLK
Crosshair VIII Hero Wi-Fi
B-die 2x16 3800MHz F4-3600C16D-32GTZN
Samsung 960 Pro 512GB
EVGA 750G2
NH D15
TK421 is offline
