How To: Unbrick Your Bricked Graphics Card/Fix a Failed BIOS Flash - Page 24 - Overclock.net - An Overclocking Community
post #231 of 306 (permalink) Old 08-23-2016, 11:05 PM
mikhan's Avatar
Rep: 1 (Unique: 1)
if you brick your RX480 (in my case ref one) with wrong bios flash so the system even doesn't start with the card in, the famous 1-8 method still works:
1. enable IGPU or other videocard as the first in bios, connect monitor to it
2, make sure the system starts correctly without rx480
3. turn off the system, insert "dead" rx480, connect 1 and 8 pins on its bios somehow (soldering, paperclip or whatever, I used a paperclip), power on
4. if the system turns on, go to windows or dos, disconnect 1 and 8 pins on rx480 bios, check if "atiflash -i" sees the card then reflash it with proper bios file. Otherwise check if 1 and 8 are properly connected at startup.
rx480_bios_restore.jpg 247k .jpg file
mikhan is offline
post #232 of 306 (permalink) Old 08-24-2016, 04:47 PM
mikelanding's Avatar
Rep: 1 (Unique: 1)
Would like to thank you for this tip. You just save my HIS RX480 ref from dead. Thank you!!
mikelanding is offline
post #233 of 306 (permalink) Old 09-19-2016, 05:45 AM
micairvas's Avatar
Rep: 0
Can you please explain me 4th part.
Do I need to disconnect 1-8 pin connector if from gpu if bricked card is recognized while system is running? Or I need first to flash factory bios if bricked card is recognized and after that turn off system and than disconnect 1-8 pin connection from gpu?
micairvas is offline
post #234 of 306 (permalink) Old 09-20-2016, 09:28 PM
mikhan's Avatar
Rep: 1 (Unique: 1)
disconnect 1+8 directly after system initialises
mikhan is offline
post #235 of 306 (permalink) Old 09-23-2016, 08:40 PM
leetrung's Avatar
Rep: 0
Thank for shared
Your text is connect 1 and 8 pins but in the picture is 1 and 5 pins. Which is true?
leetrung is offline
post #236 of 306 (permalink) Old 09-25-2016, 06:51 PM
mikhan's Avatar
Rep: 1 (Unique: 1)
pins 1 and 8, picture is correct... pins are not counted counter-clockwise always
mikhan is offline
post #237 of 306 (permalink) Old 10-05-2016, 05:36 AM
Linux Lobbyist
Guys if you brick the RX 480 with an incorrect bios flash does the fan stop working ? Does it also not get recognized in windows anymore?
PunkX 1 is offline
post #238 of 306 (permalink) Old 10-20-2016, 06:05 AM
Rep: 0
I bricked my RX480, ATIflash won't recognize it and I can't even start Windows when the GPU is connected! I'm desperate here, please help!
4GHz is offline
post #239 of 306 (permalink) Old 10-20-2016, 01:39 PM
willyz9's Avatar
Rep: 0
Hello, I could help me, I'm desperate. I have a 4gb Nitro Sapphire RX 480, I made the method of 8 + 1 pin that mensiona for the reference model, but not worked for me.
I indicates "Adapter not Found". From already thank you very much.
willyz9 is offline
post #240 of 306 (permalink) Old 10-22-2016, 10:34 AM
Rep: 0
I bought a second RX 480 and managed to flash the original BIOS, but it still doesn't work. It does get recognized by the system though.
4GHz is offline
