How To: Unbrick Your Bricked Graphics Card/Fix a Failed BIOS Flash - Page 25 - Overclock.net - An Overclocking Community
post #241 of 306 (permalink) Old 01-10-2017, 11:29 AM
MegaDeivs's Avatar
Rep: 0
Originally Posted by mikhan View Post
pins 1 and 8, picture is correct... pins are not counted counter-clockwise always
Based on flash chip pinout. For pm25ld020 it's 1 and 5 pins on picture smile.gif
MegaDeivs is offline
post #242 of 306 (permalink) Old 01-20-2017, 08:08 AM
MegaDeivs's Avatar
Rep: 0
Can I flash reference XFX rx 480 XXX Black edition bios to reference XFX RX480 XXX OC edition?
post #243 of 306 (permalink) Old 03-07-2017, 04:43 PM
TriniPapii's Avatar
Rep: 0
TriniPapii is offline
post #244 of 306 (permalink) Old 04-05-2017, 07:10 PM
s2kallday's Avatar
Rep: 0
Hey guys. Stumbled upon this thread and this seems to be the closest topic to what I'm looking for... I've tried just about every single method possible that my Google-Fu has lead me to, but I still seem to be unable to flash a stock BIOS back onto my XFX reference rx480.
I've attached a screenshot of what I'm dealing with. I've tried the -F switch to no avail. I've tried moving ATIflash to my C: drive to attempt to minimize user error. I've tried mutliple file renames, and I have been running the command prompt in administrative mode as well. I receive the exact same error every time, regardless of which method I attempt-- ERROR: 0FL01
Anyone have any ideas/tips/tricks? I'm at my wits end with this. The custom BIOS was flashed successfully and was working (mostly). I have tried flashing with the rx480 as my primary adapter and with the IGD as my primary and both times I receive the same error. FWIW, the rx480 is recognized in the device manager when booting on IGD.
Any input is greatly appreciated... I didn't budget for an rx580 so soon :'(
s2kallday is offline
post #245 of 306 (permalink) Old 04-05-2017, 07:45 PM
TriniPapii's Avatar
Rep: 0
hey i just got a notification that you wrote a reply to this thread. the same happened to me approximately a month ago & i fixed it with a bit of help. Look at my thread & follow the directions on how i fixed my GPU : https://www.overclock.net/t/1624992/hd-6970-bios-flashing-gone-wrong
post #246 of 306 (permalink) Old 04-14-2017, 08:02 PM
stephenn82's Avatar
Rep: 47 (Unique: 36)
talk to @chris89 he can probably coach you through your woes. he is a bios modding machine for nvidia and amd cards. thumb.gif
Cubic Beast
(19 items)
Dakine Server
(9 items)
i7 6700k
Asus Maximus VIII Hero
1080 FTW Hybrid
Corsair Vengeance LED 16GB
Samsung 950 Pro 256GB
samsung 850 evo
Corsair AX860
Corsair H115i
Corsair ML140 x2
Corsair AF140L x3
corsair commander pro
Corsair Carbide Series Air 740
Operating System
Windows 10
Acer G257Hu
Keyboard
Corsair K70 RGB Rapidfire
Mouse
Corsair M65 Pro RGB
Mouse
Corsair MM300 - Extended
Audio
stock Realtek AC1150
Other
Corsair Void
i5 4670
Asrock H87M Pro4
G.Skill Trident x
Raid 0
Raid 1
revo
earthwatts 430
cooler master storm trooper
Operating System
server 2008 r2
pentium g3220
MSI H81M‑P33
XFX HD 7870 Gigahertz edition
G.skill DDR3 1333
patriot blaze
Western Digital
Optical Drive
asus 24x dvd burner
antec earthwatts 430
Intel 775 cooler
Operating System
windows 10 pro
acer 19
Keyboard
cheapy
stephenn82 is offline
post #247 of 306 (permalink) Old 04-30-2017, 09:42 AM
n1kobg's Avatar
Rep: 1 (Unique: 1)
I just flashed my Palit GTX970 Jetstream sevral times and I get almost the same results as before. What might be the rason? Are Palit cards hard locked or what? In benchmarks i have higher scores but in BF4 my core was 1515mhz now is 1519mhz or maybe 15130 -something. WHAT IS THE REASON ????
The screen shows 1605mhz but it crashes. i give a link to the BIOS i edited:
https://mega.nz/#!4hZknLYL!_ZR8yANMLDEOrD30ePV5TFyUfggvXOhNKM0b-hRdzBQ
n1kobg is offline
post #248 of 306 (permalink) Old 06-20-2017, 03:07 AM
Screemi's Avatar
Rep: 4 (Unique: 4)
Hi
i already posted in the polaris bios mod thread but found this one while googling. maybe it's the better place to discuss my problem
Originally Posted by Screemi View Post
Hi Guys
I have a "little" problem. Yesterday i wanted to flash a modified rom with better ram timings onto my Asus Strix 480 and afterwards i decided to "reflash" it to a 580 Strix.
I used the 580 Strix Bios provided by Hellm and something went terribly wrong.
After i rebooted my PC doesn't even Post anymore and i had to organize an other pci-e gpu. So today i switched my strix to Slot 3 and inserted an old g92 to slot 1.
I had bad flashes before starting with atis 9500 but never got stuck the way i am now.
All i can get atiflash to tell me is the following:
Don't know what to do else. Tried multiple Bios-Files. Starting with: https://www.techpowerup.com/vgabios/185508/asus-rx480-8192-160628
and some official Asus files:
But nothing worked.
Maybe someone can help me getting my card working again.
Thx a lot!
Today i organized an other pcie-gpu and but the Strix into Slot 3 of my Board. There is a gts210
rebooted multiple times with no avail. sadly atiflash 2.74 seems to not work from a freedos usb stick anymore. it always tells me that "This program cannot be run in DOS mode". Did anybody encounter that problem as well?
the card seems to be recognized at some sort because gpu-z tells me it found a card:
and the card seems to work because i get solid 29MH/s with Claymore eh-smiley.gif
***? didn't test that yesterday because i assumed the card was dead.
no i found the following quote in the comments of the 8-1 pin method:
Another kind of brick is that the system doesn't start at all with dead card inside, no boot or smth. If 1+8 is applied, the system starts to boot normally
that seems to be the case for my card. does anybody have an idea how to fix it apart of the pin shortening?
if not i have to go the pin route. does anybody have an idea where the bioschip of the strix 480 is located? after some googling i found a picture of the back of the pcb but the resolution is not that high. i marked the ic i suspect to be the bios.
€dit:
I tried atiflash 4.17 from 2013 but i get a "adapter not found". any other dos versions i can try?
€dit: i used every force string available with atiflash and what can i tell you: The freaking Card is up and running again!!!! should have tried that earlier. already got my solder iron ready biggrin.gif
Screemi is offline
post #249 of 306 (permalink) Old 07-15-2017, 04:09 AM
iahoo's Avatar
Rep: 0
It is my rx460 gigabyte wf 4g. Where are the pin 1 an 8?
https://ibb.co/ma5N2v IMG_20170715_151815.jpg 219k .jpg file
iahoo is offline
post #250 of 306 (permalink) Old 07-28-2017, 10:09 AM
ploy's Avatar
Rep: 0
Hi
€dit:
Was that the correct chip? Which is pin 1 and pin 8?
ploy is offline
