How To: Unbrick Your Bricked Graphics Card/Fix a Failed BIOS Flash - Page 27 - Overclock.net - An Overclocking Community
post #261 of 306 (permalink) Old 09-02-2017, 06:59 PM
benikens's Avatar
Rep: 0
So I just tried to flash my rx 460 to an unlocked bios and it crashed my PC during the flash. Now I can't boot with the GPU in the PCI-e slot as it gives me 1 long 2 short beeps from the mobo speaker. I have an iGPU and set the default display to that but I can't make it past POST to actually run the bios backup flash. Any ideas?
benikens is offline
post #262 of 306 (permalink) Old 09-02-2017, 09:07 PM
HarryCanuck's Avatar
Rep: 0
I had a RX 480 flashed with RX 580 BIOS working fine for a few weeks and then I ran a burn-in test and the PC froze. Following that the PC was unwilling to post with the RX 480 installed. I have lots of spare old GPUs I can boot with.
It's a dual-BIOS card, the BIOS selector has no impact on the inability to boot, unless I'm supposed to do more than slide the switch and power up the PC?
What are the odds this fix would help a card that didn't brick during a flash?
I'm thinking the VRM may have cooked from some articles I've read about RX 480 flashing risks, but there was def. no burnt electronics smell.
HarryCanuck is offline
post #263 of 306 (permalink) Old 09-02-2017, 09:10 PM
MrTOOSHORT's Avatar
Rep: 1512 (Unique: 1049)
If the other bios is selected and it still won't boot, its probably done.
9980XE  •  APEX VI  •  3600CL15  •  KPE 2080TI HC  • 34GK950F-B • 905P AIC • 1600T2  •  800D
MrTOOSHORT is offline
post #264 of 306 (permalink) Old 09-08-2017, 09:49 AM
CyCloneTSi's Avatar
Rep: 0
I'm sure I have an RX 470 4 gig amour that is bricked,. I have tried the 1+8 method and it follows the steps exactly but when it goes to mine it crashes. I have used the cli reflash method on other cards and been successful but that or the 1+8 method isn't working. It was mining fine when the newest nicehash did a benchmark and hasn't worked since. I have tried for days now with so many different things. It's driving me crazy can some please give me some input or other ideas? I'm not ready to accept it being a bad card for many reasons
CyCloneTSi is offline
post #265 of 306 (permalink) Old 09-08-2017, 10:51 AM
Rep: 0
Do the fans spin on power up? Does anything on the card power up? Was there any 'burnt electronics smell'?
Wouldn't it be nice to find out these boards have a soldered component that gets loose with too much heat and there's a chip bake trick to get the solder to re-seat?
https://www.youtube.com/watch?v=8Xanr4jkmEc (Nice meta video that talks about a guide on this site.. smile.gif )
post #266 of 306 (permalink) Old 09-08-2017, 10:54 AM
CyCloneTSi's Avatar
Rep: 0
Yes that would be great. Everything works as it should. I also have full control with afterburner. I used the 1+8 flash method and it followed all steps correctly. No other errors to report but when I use any miner it crashes.
post #267 of 306 (permalink) Old 09-08-2017, 10:56 AM
CyCloneTSi's Avatar
Rep: 0
Also passes all visual inspection also removed cooling unit and board looks good underneath as well. Always ran at about 120 degrees at 55% fans
post #268 of 306 (permalink) Old 09-08-2017, 12:23 PM
Rep: 0
Oh. That's different. Do you have a tool that will log VRM temps like GPU-z? I'd suspect a component is overheating before the GPU does.
post #269 of 306 (permalink) Old 09-08-2017, 09:38 PM
chris89's Avatar
Rep: 84 (Unique: 62)
So your saying the GPU is working still just crashing? Send me .zip your .rom here and attach here via paperclip.
Do you mind some fan RPM? I can get these cards to run real stable.
Dell Precision T7500 : Dual Xeon X5675 @ 3.536Ghz X 24 Threads : 48 Gigabytes : Cinebench R15 : 1505 : AMD R9 390X 8GB @ 1173Mhz 1350mv 57599 Power Limit @ 1250Mhz memory error free on tight timings / since 1500mhz+ had errors galore
chris89 is offline
post #270 of 306 (permalink) Old 09-10-2017, 11:51 AM
CyCloneTSi's Avatar
Rep: 0
I don't see being able to attach a file
